Items with no label
3338 Discussions
"Could not open OpenGL window, please check your graphic drivers or use the textual SDK tools" error when rs-measure is run from SDK build
nnain1
Follow the instructions from this link for installing librealsense2-dkms. Things are fine and can install and run all realsense examples installed into /usr/local/.
I need to modify code so build SDK from source. Follow the link for manula installation.
Run all commands like
./scripts/setup_udev_rules.sh
./scripts/patch-realsense-ubuntu-lts.sh
modinfo uvcvideo | grep "version:" gave
version:       1.1.2.realsense-1.3.11
srcversion:    DDEE98EBF0181C7A35FC63
Build from source is installed in another separate user level folder.
When run ./rs-measure, I have error as "Could not open OpenGL window, please check your graphic drivers or use the textual SDK tools".
Tested the code in this link to test opengl in my system. It worked well.
So what could be issue in manual build from SDK?
