3085 Discussions
Fails to encode with ROI in Intel Media SDK 20217 R1 For Windows
Hang_L_Intel
I encountered one problem while using the mfxExtEncoderROI in the Media SDK, the problem is after the ROI information have been set, the Query() function failed with MFX_ERR_UNSUPPORTED, I wonder is this feature supported in my current development environment.
The Media SDK version I am using is: Intel Media SDK 2017 R1, the API version is 1.23.
I am using a NUC (https://www.amazon.com/Intel-NUC6i7KYK-Mini-i7-6770HQ-Windows/dp/B01FLDS5SO) with a i7-6770HQ CPU with Iris Pro Graphics 580. My OS is Windows 10 Enterprise 64Bit.
Some parts of the code are listed as follows:
m_mfxROI.NumROI = 1;
m_mfxROI.ROI[0].Left = 480;
m_mfxROI.ROI[0].Right = 1440;
m_mfxROI.ROI[0].Top = 270;
m_mfxROI.ROI[0].Bottom = 810;
m_mfxROI.ROI[0].Priority = -50; // CQP mode
m_EncExtParams.push_back((mfxExtBuffer*)&m_mfxROI);
the failed function is:
 sts = GetFirstEncoder()->Query(&m_mfxEncParams, &m_mfxEncParams);
 MSDK_CHECK_STATUS(sts, "Query (for encoder) failed");
I attached pipeline_encode.h and pipeline_encode.cpp which can be directly put to the sample_encode example solution in the latest Media SDK samples for Windows.
