Intel Gfx driver is not found
RySAP
Hi
I'd like to decode RTP H.264 video stream received from Network camera.
But installation of Media SDK failed.
Downloaded libva, libva-utils, Gmmlib, media-driver, and MediaSDK from Github.
Build by gcc 8.3.1 (devtoolset-8)and installed.
  libva: https://github.com/intel/libva/releases/tag/2.7.0
     libva-utils: https://github.com/intel/libva-utils/releases/tag/2.7.1
      Gmmlib: https://github.com/intel/gmmlib/releases/tag/intel-gmmlib-20.1.1
     Driver: https://github.com/intel/media-driver/releases/tag/intel-media-20.1.1
     Media SDK and Samples: https://github.com/Intel-Media-SDK/MediaSDK/releases/tag/intel-mediasdk-20.1.0
# vainfo
     error: XDG_RUNTIME_DIR not set in the environment.
     error: can't connect to X server!
     libva info: VA-API version 1.7.0
     libva info: User environment variable requested driver 'iHD'
     libva info: Trying to open /usr/local/lib/dri/iHD_drv_video.so
     libva info: Found init function __vaDriverInit_1_7
     DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument
     Assuming 131072kB available aperture size.
     May lead to reduced performance or incorrect rendering.
     get chip id failed: -1 [22]
    param: 4, val: 0
    libva error: /usr/local/lib/dri/iHD_drv_video.so init failed
    libva info: va_openDriver() returns 18
    vaInitialize failed with error code 18 (invalid parameter),exit
I added option "--display drm --device /dev/dri/renderD129", but it was same error message.
I made following initialize code.  But the device file is not found.
int open_intel_adapter()
std::string adapterPath = "/dev/dri/renderD";
char driverName[5] = {};
mfxU32 nodeIndex = 128;
for (mfxU32 i = 0; i < 16; ++i) {
std::string curAdapterPath = adapterPath + std::to_string(nodeIndex + i);
int fd = open(curAdapterPath.c_str(), O_RDWR);
if (fd < 0) continue;
drm_version_t version = {};
version.name_len = 32;
version.name = driverName;
ioctl(fd, DRM_IOWR(0, drm_version), &version);
if(!strcmp(driverName, "i915")) return fd;
close(fd);
return -1;
my  environment is;
- OS       CentOS Linux release 7.6.1810
- CPU   Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
- GPU    NVIDIA GeForce GTX 1080
         Following Nvidia driver is installed/
 NVRM version: NVIDIA UNIX x86_64 Kernel Module 450.80.02 Wed Sep 23 01:13:39 UTC 2020
I disabled Nouveau driver.
 # sudo mv /boot/initramfs-$(uname -r).img /boot/initramfs-$(uname -r)-nouveau.img
 # sudo dracut --force --omit-drivers nouveau /boot/initramfs-$(uname -r).img $(uname -r)
 # echo "blacklist nouveau" | sudo tee /etc/modprobe.d/modprobe.conf
 # echo "blacklist nouveau" | sudo tee /etc/modprobe.d/nouveau-blacklist.conf
- DRI
# ls /dev/dri
card0 card1 renderD128 renderD129
# cat /sys/kernel/debug/dri/*/name
nvidia-drm dev=0000:03:00.0 unique=0000:03:00.0
nvidia-drm dev=0000:04:00.0 unique=0000:04:00.0
Question
Could you tell me why intel Gfx driver is not found?
And I 'm planning to try another PC.   Its CPU is Intel(R) Xeon(R) W-2133 CPU @ 3.60GHz.
Does Media SDK support   Xeon W-2133 ?
JaideepK_Intel
Thanks for reaching out to us,
Since this is a duplicate thread of https://community.intel.com/t5/Media-Intel-oneAPI-Video/I-cannot-find-Intel-gfx-driver/m-p/1317732#M13961, we will no longer monitor this thread. We will continue addressing this issue in the other thread.
Jaideep
RySAP
HI Jaideep、
Yes,  this issue was marked as SPAM.  So, I tried again.
Please ignore this thread.
