I try install MSS 2015 R6 on old RHEL 6.4 based distro with partial success. Encode work only with -vaapi option:
./sample_encode_drm h264 -i ./1280x720x420p.yuv -o ./out.h264 -w 1280 -h 720 -async 1 -vaapi
libva info: VA-API version 0.35.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Encoding Sample Version 6.0.16043175.175
Input file format YUV420
Output video AVC
Source picture:
Resolution 1280x720
Crop X,Y,W,H 0,0,1280,720
Destination picture:
Resolution 1280x720
Frame rate 30.00
Bit rate(Kbps) 3231
Target usage balanced
Memory type d3d
Media SDK impl hw
Media SDK version 1.16
Processing started
Frame number: 1439
Processing finished
But without -vaapi encode process never end and with -async 1 next error:
Return on error: error code -17, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK3/git/mdp_msdk-samples/samples/sample_encode/src/pipeline_encode.cpp 1212
Return on error: error code -17, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK3/git/mdp_msdk-samples/samples/sample_encode/src/pipeline_encode.cpp 1367
ERROR: Hardware device was lost or returned an unexpected error. Recovering...
And another problem -mss option dont worked with -vaapi:
./sample_encode_drm h264 -i ./1280x720x420p.yuv -o ./out.h264 -w 1280 -h 720 -async 1 -vaapi -mss 1200
Return on error: error code -1, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK3/git/mdp_msdk-samples/samples/sample_encode/src/pipeline_encode.cpp 1165
I try install on this platform Centos 7.2 and all work perfectly. But for some reasons i need use this rhel 6.4 based os. Where can be problem?
Warp.
Hi Alexey,
There might be possibility that your system has multiple libva and libdrm which can cause random failures. Make sure you have Intel libva and libdrm.
If you don't, the clear libva before recompiling libva with “find /usr -name "libva*" | xargs sudo rm –rf” and with “./configure --prefix=/usr” before run “make”. Check the article on install on secondary OS -https://software.intel.com/en-us/articles/how-to-setup-media-server-studio-on-secondary-os-of-linux to make sure you have followed all the steps. Are you on Kernel 3.14.5? What is your system configuration?
Hope it helps.
Surbhi
Hi Surbhi,
Yes i remove all other libdrm and libva, kernel is 3.14.5 patched from generic directory patches. Cpu is Intel(R) Core(TM) i7-4770R CPU @ 3.20GHz . Same kernel version i setup in Centos 7.2 for verify all work fine.
ldd --version
ldd (GNU libc) 2.12
Error comming from MFXVideoCORE_SyncOperation function in kernel traces i see
[drm:drm_ioctl], pid=11079, dev=0xe200, auth=1, I915_GEM_USERPTR
[drm:drm_ioctl], ret = -19
Maybe some specific options in kernel need not only drm and i915? I use minimal kernel configuration without unused modules.
Alexey.
Hi Alexey,
Thanks for providing information. Your system is supported by MediaServer Studio so is the glibc. Can you send the o/p of few test and more info asked below -
1. add strace to the cmd - strace ./sample_encode_drm h264 -i ./1280x720x420p.yuv -o ./out.h264 -w 1280 -h 720 -async 1 -vaapi
2. By default async value is 4, can you try not to set async value and check if the issue exits.
Send o/p of following cmds
$ vainfo
$ ls -l /dev/dri
$ lspci -nn | grep VGA
Just to set the expectations clear we support CentOS 7.1 as a gold OS configuration and provide generic package with kernel 3.14.5 patches as a option to work on other Linux distributions as preferred by customer and any issues raise on other than gold OS(CentOS7.1) needs to be replicated on CentOS7.1 for us to look at. We can try to help you this issue because of the interest but can't escalate it to experts unless replicate on CentOS7.1.
FYI - Media Server Studio 2016 release is out, in case you would like to update. This might not solve the issue you are experiencing but it will be best to see if the issue is reproducible on the latest release.
Surbhi
Hi Surbhi,
I update to 2016 and you right nothing change.
1. I attach strace.txt
2.
./sample_encode h264 -i ./f.yuv -o ./ff.h264 -w 1280 -h 720
libva info: VA-API version 0.99.0
Encoding Sample Version 6.0.16043361.361
Output video AVC
Source picture:
Resolution
1280x720
Resolution 1280x720
Frame rate 30.00
Bit rate(Kbps) 3231
Gop size 0
Ref dist 0
Ref number 1
Idr Interval 0
Memory type system
Media SDK impl hw
Media SDK version 1.17
Processing started
ERROR: No free surfaces in pool (during long period)
Return on error: error code -4, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK1/git/mdp_msdk-samples/samples/sample_encode/src/pipeline_encode.cpp 1291
Return on error: error code 1, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK1/git/mdp_msdk-samples/samples/sample_encode/src/sample_encode.cpp 766
Frame number: 0
With vaapi:
/sample_encode h264 -i ./f.yuv -o ./ff.h264 -w 1280 -h 720 -vaapi
Output video AVC
Source picture:
Resolution 1280x720
Resolution 1280x720
Frame rate 30.00
Bit rate(Kbps) 3231
Gop size 0
Ref dist 0
Ref number 1
Idr Interval 0
Memory type d3d
Media SDK impl hw
Processing started
Frame number: 1439
Processing finished
With vaapi and mss:
./sample_encode h264 -i ./f.yuv -o ./ff.h264 -w 1280 -h 720 -vaapi -mss 1200
Return on error: error code -1, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK1/git/mdp_msdk-samples/samples/sample_encode/src/pipeline_encode.cpp 1202
Return on error: error code -1, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK1/git/mdp_msdk-samples/samples/sample_encode/src/pipeline_encode.cpp 1117
Return on error: error code 1, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK1/git/mdp_msdk-samples/samples/sample_encode/src/sample_encode.cpp 744
Frame number: 0
vainfo:
vainfo
error: can't connect to X server!
vainfo: VA-API version: 0.99 (libva 1.67.0.pre1)
vainfo: Driver version: 16.4.4.47109-ubit
vainfo: Supported profile and entrypoints
VAProfileH264Baseline : VAEntrypointEncSlice
VAProfileH264Baseline : <unknown entrypoint>
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: <unknown entrypoint>
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264Main : <unknown entrypoint>
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264High : <unknown entrypoint>
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Simple : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileVP8Version0_3 : VAEntrypointEncSlice
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileVP8Version0_3 : <unknown entrypoint>
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileVP9Profile0 : VAEntrypointEncSlice
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile0 : <unknown entrypoint>
<unknown profile> : VAEntrypointVideoProc
VAProfileNone : VAEntrypointVideoProc
VAProfileNone : <unknown entrypoint>
ls -l /dev/dri
total 0
crw-rw---- 1 root video 226, 0 Feb 23 12:09 card0
crw-rw---- 1 root video 226, 64 Feb 23 12:09 controlD64
crw-rw---- 1 root video 226, 128 Feb 23 12:09 renderD128
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:0d22] (rev 08)
uname -a
Linux alt 3.14.5 #13 SMP PREEMPT Sat Feb 20 17:06:52 MSK 2016 x86_64 x86_64 x86_64 GNU/Linux
Alexey.
Hi Alexey,
Thanks for sending in the information. All the above info sent in your last post looks right, so I discussed your case with an expert and these msgs doesn't look right -
So, would like to confirm if you have rebuild the libdrm last when we discussed to remove multiple libva and libdrm. If not, please remove the libdrm, recompile and install them. Also, what version of gcc version do you have? Please update to 4.7 or higher as this is a pre-requisite. You can refer to this article to find the cmds for rebuilding kernel and updating gcc.
Surbhi
Hi Surbhi,
gcc already updated to 5.3.0 version:
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0/lto-wrapper
Target: x86_64-unknown-linux-gnu
Configured with: ./configure --prefix=/usr --disable-multilib
Thread model: posix
gcc version 5.3.0 (GCC)
libdrm and libva recompilled from generic directory, nothing change. Previously i use precompilled from installation with identicall results.
Alexey.
Hi Alexey,
Have you merge the MSS patches to kernel when you build the kernel 3.14.5 ?
How did you build your kernel ?
which gcc version used when you build the kernel ?
I suggest you build kernel with RHEL build-in gcc and following "How to setup MSS on CentOS 6.5" in How to setup Media Server Studio on Secondary OS of Linux
Zachary
Hi Zachary,
Yes i applyed patches with command
for i in ../intel-kernel-patches/*.patch; do patch -p1 < $i; done
I attached my config for 3.14.5
Build with next commands make -j 8 next make modules_install and make install. Gcc version for build kernel same 5.3.0
Alexey.
Hi Alexey,
Have you tried to use "make olddefconfig" for configure your kernel before run "make -j 8" ?
And, I suggest you use RHEL 6.4 build-in gcc to compile your kernel. following command line can help to restore your gcc
[user@host]# yum remove gcc gcc-c++
[user@host]# yum install gcc gcc-c++
Because some upgrade gcc version may cause run issue. after build and install kernel you can use 5.3.0.
And can you share how did you upgrade gcc to 5.3.0 ?
Zachary
Hi Zachary,
After some studing installation manuals i found decission. Its "
Important Note: With using own kernel configuration please make sure CONFIG_MMU_NOTIFIERS=y is enabled. It can be disable implicitly with disabling virtualization support.
Virtualisation disabled in my config and notifiers not setted. After i set him and recompile kernel all work great. Documentation not quite right parameter must be named CONFIG_MMU_NOTIFIER not CONFIG_MMU_NOTIFIERS.
Anyway thanx for help.
Alexey.
Hi Alexey,
Good to know it worked for you. and Thank you for share your knowledge. It will help to others.
Zachary
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
