Intel Media SDK use d3d11 and sw to vpp failed!
X_T_1
when use simple_vpp_d3d11.exe in the sdk mediasdk-tutorials-0.0.3 and set sw to vpp, It reports failed:
Unsupported feature/library load error. mediasdk-tutorials-0.0.3\common\common_utils_windows.cpp 35
Unsupported feature/library load error. mediasdk-tutorials-0.0.3\simple_4_vpp_resize_denoise_vmem\src\simple_vpp_vmem.cpp 80
It seem to use MFX_IMPL_SOFTWARE | MFX_IMPL_VIA_D3D11 to init SDK Session failed!
Does media sdk not support d3d11 and sw setting feature? How to fix this failed?
When I use the d3d11 and hw setting , it can work.
When use simple_vpp_d3d.exe, set sw or hw, it also can work.
My System is win10(15063),cpu i5-6500
I use the SDK version is Intel(R)_Media_SDK_2016.0.2.
Mark_L_Intel1
Hi X.T
Could you post your full command so I will try to reproduce it?
If you use the Skylake, you might try to use the lated Media SDK release instead of the release from the last year.
Mark
