I'm having problems running Intel® Quick Sync Video H.264 Encoder MFT. The setup, ProcessInput and ProcessOutput are all returning S_OK but the sample from ProcessOutput is NULL and the status is MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE. Any idea what could be wrong?
This is the output:
Start encoding
ProcessInput frame 1
ProcessInput frame 2
ProcessInput frame 3
ProcessInput frame 4
ProcessOutput MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE
from the following code (ignore any leaks that are unrelated to my issue):
void main() { HRESULT hr = S_OK; hr = CoInitializeEx(NULL, COINIT_APARTMENTTHREADED); if (FAILED(hr)) { OutputDebugString(L"CoInitializeEx failed\n"); return; } hr = MFStartup(MF_VERSION); if (FAILED(hr)) { OutputDebugString(L"MFStartup failed\n"); return; } IMFActivate **devices = NULL; IMFTransform *encoder = NULL; IMFMediaEventGenerator *eventGenerator = NULL; GUID inFormat = MFVideoFormat_NV12; GUID outFormat = MFVideoFormat_H264; MFT_REGISTER_TYPE_INFO inputInfo = { MFMediaType_Video, inFormat }; MFT_REGISTER_TYPE_INFO outputInfo = { MFMediaType_Video, outFormat }; uint32_t flags = MFT_ENUM_FLAG_HARDWARE; uint32_t count; uint32_t fps = 25; uint32_t width = 1280; uint32_t height = 720; IMFAttributes *attributes; uint32_t asynch; uint32_t len = 0; MFCalculateImageSize(inFormat, width, height, &len); hr = MFTEnumEx(MFT_CATEGORY_VIDEO_ENCODER, flags, &inputInfo, &outputInfo, &devices, &count); if (FAILED(hr)) { OutputDebugString(L"MFTEnumEx failed\n"); return; } if (count == 0) { OutputDebugString(L"No devices\n"); return; } LPWSTR szFriendlyName = NULL; hr = devices[0]->GetAllocatedString(MFT_FRIENDLY_NAME_Attribute, &szFriendlyName, NULL); OutputDebugString(szFriendlyName); OutputDebugString(L"\n"); hr = devices[0]->ActivateObject(IID_PPV_ARGS(&encoder)); if (FAILED(hr)) { OutputDebugString(L"ActivateObject failed\n"); return; } for (size_t idx = 0; idx < count; ++idx) { devices[idx]->Release(); } CoTaskMemFree(devices); encoder->QueryInterface(&eventGenerator); hr = encoder->GetAttributes(&attributes); if (FAILED(hr)) { return; } hr = attributes->GetUINT32(MF_TRANSFORM_ASYNC, &asynch); hr = attributes->SetUINT32(MF_TRANSFORM_ASYNC_UNLOCK, TRUE); attributes->Release(); if (FAILED(hr)) { return; } DWORD inputCount = 0, outputCount = 0, inputId = 0, outputId = 0; hr = encoder->GetStreamCount(&inputCount, &outputCount); if (FAILED(hr)) { return; } if (inputCount == 0 || outputCount == 0) { return; } DWORD *inputIds = new DWORD[inputCount]; DWORD *outputIds = new DWORD[outputCount]; hr = encoder->GetStreamIDs(inputCount, inputIds, outputCount, outputIds); auto cleanStreamIds = [&inputIds, &outputIds] { delete[] inputIds; inputIds = NULL; delete[] outputIds; outputIds = NULL; }; if (FAILED(hr)) { if (hr != E_NOTIMPL) { OutputDebugString(L"GetStreamIDs failed\n"); cleanStreamIds(); return; } } else { inputId = inputIds[0]; outputId = outputIds[0]; } cleanStreamIds(); IMFMediaType *outputType = NULL; hr = MFCreateMediaType(&outputType); if (FAILED(hr)) { OutputDebugString(L"MFCreateMediaType outputType failed\n"); return; } hr = outputType->SetGUID(MF_MT_MAJOR_TYPE, MFMediaType_Video); hr = outputType->SetGUID(MF_MT_SUBTYPE, outFormat); hr = outputType->SetUINT32(MF_MT_AVG_BITRATE, 10000000); hr = MFSetAttributeSize(outputType, MF_MT_FRAME_SIZE, width, height); hr = MFSetAttributeRatio(outputType, MF_MT_FRAME_RATE, fps, 1); hr = outputType->SetUINT32(MF_MT_INTERLACE_MODE, MFVideoInterlace_Progressive); hr = outputType->SetUINT32(MF_MT_MPEG2_PROFILE, eAVEncH264VProfile_High); hr = outputType->SetUINT32(MF_MT_MPEG2_LEVEL, eAVEncH264VLevel3_1); hr = outputType->SetUINT32(CODECAPI_AVEncCommonRateControlMode, eAVEncCommonRateControlMode_CBR); hr = encoder->SetOutputType(outputId, outputType, 0); if (FAILED(hr)) { OutputDebugString(L"SetOutputType failed\n"); return; } IMFMediaType *inputType = NULL; hr = MFCreateMediaType(&inputType); if (FAILED(hr)) { OutputDebugString(L"MFCreateMediaType inputType failed\n"); return; } hr = inputType->SetGUID(MF_MT_MAJOR_TYPE, MFMediaType_Video); hr = inputType->SetGUID(MF_MT_SUBTYPE, inFormat); hr = inputType->SetUINT32(MF_MT_INTERLACE_MODE, MFVideoInterlace_Progressive); hr = MFSetAttributeSize(inputType, MF_MT_FRAME_SIZE, width, height); hr = MFSetAttributeRatio(inputType, MF_MT_FRAME_RATE, fps, 1); hr = MFSetAttributeRatio(inputType, MF_MT_PIXEL_ASPECT_RATIO, 1, 1); hr = encoder->SetInputType(inputId, inputType, 0); if (FAILED(hr)) { OutputDebugString(L"SetInputType failed\n"); return; } hr = encoder->ProcessMessage(MFT_MESSAGE_COMMAND_FLUSH, 0); hr = encoder->ProcessMessage(MFT_MESSAGE_NOTIFY_BEGIN_STREAMING, 0); hr = encoder->ProcessMessage(MFT_MESSAGE_NOTIFY_START_OF_STREAM, 0); OutputDebugString(L"Start encoding\n"); uint32_t frame = 1; IMFMediaEvent *event = NULL; MediaEventType type; do { hr = eventGenerator->GetEvent(0, &event); hr = event->GetType(&type); switch (type) { case METransformNeedInput: { IMFSample *newSample = NULL; IMFMediaBuffer *buffer; hr = MFCreateMemoryBuffer(len, &buffer); byte *bufferData; hr = buffer->Lock(&bufferData, NULL, NULL); memset(bufferData, 0, len); hr = buffer->Unlock(); hr = buffer->SetCurrentLength(len); hr = MFCreateSample(&newSample); hr = newSample->AddBuffer(buffer); uint64_t sampleDuration = 0; MFFrameRateToAverageTimePerFrame(fps, 1, &sampleDuration); newSample->SetSampleDuration(sampleDuration); hr = encoder->ProcessInput(0, newSample, 0); if (FAILED(hr)) { OutputDebugString(L"ProcessInput failed\n"); return; } else { WCHAR outMessage[128]; memset(outMessage, 0, 128 * sizeof(WCHAR)); wsprintf(outMessage, L"ProcessInput frame %u\n", frame); OutputDebugString(outMessage); ++frame; } break; } case METransformHaveOutput: { MFT_OUTPUT_DATA_BUFFER data = { outputId, NULL, 0, NULL }; MFT_OUTPUT_STREAM_INFO outInfo; hr = encoder->GetOutputStreamInfo(outputId, &outInfo); if (!(outInfo.dwFlags & MFT_OUTPUT_STREAM_PROVIDES_SAMPLES)) { OutputDebugString(L"!MFT_OUTPUT_STREAM_PROVIDES_SAMPLES not handled\n"); return; } DWORD status = 0; hr = encoder->ProcessOutput(MFT_OUTPUT_STREAM_PROVIDES_SAMPLES, 1, &data, &status); if (FAILED(hr)) { OutputDebugString(L"ProcessOutput failed\n"); return; } if (data.dwStatus == MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE) { OutputDebugString(L"ProcessOutput MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE\n"); return; } break; } default: break; } } while (true); }
Also, here is the output from mediasdk_ss_analyzer:
The following versions of Media SDK API are supported by platform/driver
[opportunistic detection of MSDK API > 1.16]:
Version Target Supported Dec Enc
1.0 HW Yes X X
1.0 SW Yes X X
1.1 HW Yes X X
1.1 SW Yes X X
1.2 HW Yes X X
1.2 SW Yes X X
1.3 HW Yes X X
1.3 SW Yes X X
1.4 HW Yes X X
1.4 SW Yes X X
1.5 HW Yes X X
1.5 SW Yes X X
1.6 HW Yes X X
1.6 SW Yes X X
1.7 HW Yes X X
1.7 SW Yes X X
1.8 HW Yes X X
1.8 SW Yes X X
1.9 HW Yes X X
1.9 SW Yes X X
1.10 HW Yes X X
1.10 SW Yes X X
1.11 HW Yes X X
1.11 SW Yes X X
1.12 HW Yes X X
1.12 SW Yes X X
1.13 HW Yes X X
1.13 SW Yes X X
1.14 HW Yes X X
1.14 SW Yes X X
1.15 HW Yes X X
1.15 SW Yes X X
1.16 HW Yes X X
1.16 SW Yes X X
1.17 HW Yes X X
1.17 SW Yes X X
Graphics Devices:
Name Version State
Intel(R) HD Graphics 20.19.15.4320 Active
System info:
CPU: Intel(R) Pentium(R) CPU N3700 @ 1.60GHz
OS: Microsoft Windows 10 Home Single Language
Arch: 64-bit
Installed Media SDK packages (be patient...processing takes some time):
Intel(R) Media Samples 6.0.0.68
Intel(R) Media SDK 2016
Analysis complete... [press ENTER]
Hi Bogdan,
Thank you for sharing the detailed log of your system. Looking into issue and based on our investigation, the status returned "MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE" is not specifically due to hardware MFT (Intel® Quick Sync Video H.264 Encoder MFT) but due to no MFT sample ready for this stream.
For MSFT website reference here: https://technet.microsoft.com/es-es/ms704014, "If the MFT has multiple output streams, the streams might produce output at different rates, so some streams might have output while other streams do not. If a stream did not any produce output, the MFT sets the MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE flag in the dwStatus member of the MFT_OUTPUT_DATA_BUFFER structure for that stream". I suggest checking with MSFT support team on this issue. Hope this information helps.
Hi Harsh,
Thank you for your answer.
The MFT has only 1 output stream (only 1 input stream too).
Also, running the same code with an NVIDIA hardware MFT, I have no issues on getting encoded frames (below is the output from it):
NVIDIA H.264 Encoder MFT
Start encoding
ProcessOutput Got output
Bogdan
Hi Bogdan,
Thank you for sharing this information. If the MFT has only 1 output stream, then further investigation is needed. Can you please share a log from mediasdk_tracer (https://software.intel.com/en-us/articles/media-sdk-tools). Also, I have shared a tool via private message. Please share the logs from the tools, where logs could provide us more visibility into this issue.
Hi Bogdan,
Thank you for the log. Please check you inbox for Intel forum messages and I did re-send the message again too. Also, after brief look at the code (above) I suspect the issue is caused by MFT_OUTPUT_STREAM_PROVIDES_SAMPLES flag as it is not supported by Intel H.264 Encoder HMFT. Please try and remove this flag to isolate the problem, let me know how it goes.
EDIT: Never mind. In my case it was a problem with the encoder wanting to renegotiate the output format and my code miscounting the METransformHaveOutput callbacks.
Hey,
I have the exact same problem, and it's clearly not related to the MFT_OUTPUT_STREAM_PROVIDES_SAMPLES flag - providing a sample in the MFT_OUTPUT_DATA_BUFFER structure doesn't help.
My code is completely independent from Bogdan's, and it's working flawlessly on NVidia/AMD GPUs and Microsoft's software encoder MFT, so there's definitely something fishy going on there.
