3085 Discussions
MSDK decode , switch video stream problem, memory leak? and restart failure?
andy_l_
when is decoding with IPC A's stream(1080p), and I want to close it and start decode IPC B's stream(720p).
which operation is correct in the follow:
1.    Release Pipeline
      Pipeline.Init(&Params);
      for (;;)      {  sts = Pipeline.RunDecoding();...}
2  or:  use ResetDecoder()
      for (;;)      {  sts = Pipeline.RunDecoding();....}
When used first method,  restart success.  But memery will grow much.   Is it memery leak?
When used second method,restart failure. But if IPC B's stream also 1080p,restart will success.
what's wrong?
Harshdeep_B_Intel
Hi Andy,
I do need more details to understand the complete operation of your scenario. Please share a log of system analyzer from https://software.intel.com/en-us/articles/media-sdk-tools and code snippet of you application, so we can take a closer look. You might be interested in taking a look at this article: https://software.intel.com/en-us/articles/framework-for-developing-applications-using-media-sdk
