I have built Gstreamer 1.24 on below platform.
GPU: Meteor Lake-P [Intel Arc Graphics] CPU: Intel® Core™ Ultra 7 Processor 155HL Kernel: Linux 6.7.12+bpo-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.7.12-1~bpo12+1 (2024-05-06) x86_64 GNU/Linux
Meson build command:
run meson setup . .. \ --buildtype release --unity off --strip \ --default-library shared \ --wrap-mode=nofallback \ -Dorc-source=system \ -Dgpl=enabled \ -Drs=enabled \ -Dcpp_args="-std=c++20" \ -Dexamples=disabled -Dtests=enabled -Dgtk_doc=disabled \ -Dpackage-origin="$Gxx" $OPTS "
OS Details:
- OS: Ubuntu-22.04
- libva version: 2.17
- libva-utils version: 2.17
The build was successful. Additionally I checked and the Video card is present under /dev/dri . I set LIBVA_DRIVER_NAME=iHD and the appropriate path of LIBVA_DRIVERS_PATH However, when I do gst-inspect-1.0 va I can only see decoders present and only two encoders. I am specifically looking for the vapostproc element and vah264enc encoders. Is there any step or a process I’m missing. Please suggest.
Hello npawar,
We'll check on this query and we will post an update once it's available.
Jeanette C.
Hello npawar,
I have reviewed your concern and wanted to let you know that we have a dedicated forum for this type of issue, where you can get faster answers. I am moving this to the "Intel® Video Processing Library, Intel Media SDK" Forum for you.
Sincerely,
JeanetteC.
![](/skins/images/3CECF0550DB8BF54496C114A1FF06FE9/responsive_peak/images/icon_anonymous_message.png)
