SDK2015PreviewEvaluation16.4 installed
zhu_j_1
Hi
Installed MSDK 2015R2, Preview Evaluation 16.4,  on Centos 7, 3.10.0-123.el7.x86_64, with Intel(R) Core(TM) i3-4330T CPU @ 3.00GHz. While building the sample transcode example, I am getting the follwing error:
[root@localhost samples]# pwd
/home/gotron/gotron/IMSDK2015/MediaSamples_Linux_5.0.1604371.71/samples
[root@localhost samples]# perl build.pl --cmake=intel64.make.release -build
/home/gotron/gotron/IMSDK2015/MediaSamples_Linux_5.0.1604371.71/samples/sample_common/src/plugin_utils.cpp:98:24: error: \u2018MFX_PLUGINID_HEVCE_FEI_HW\u2019 was not declared in this scope
                 return MFX_PLUGINID_HEVCE_FEI_HW;   // HEVC FEI uses ENC interface
gmake[2]: *** [sample_common/CMakeFiles/sample_common_drm.dir/src/plugin_utils.cpp.o] Error 1
gmake[2]: Leaving directory `/home/gotron/gotron/IMSDK2015/MediaSamples_Linux_5.0.1604371.71/samples/__cmake/intel64.make.release'
gmake[1]: *** [sample_common/CMakeFiles/sample_common_drm.dir/all] Error 2
gmake[1]: Leaving directory `/home/gotron/gotron/IMSDK2015/MediaSamples_Linux_5.0.1604371.71/samples/__cmake/intel64.make.release'
gmake: *** [all] Error 2
[ intel64.make.release                               State: FAIL ]
 Here is my install process:
From SDK2015PreviewEvaluation16.4 directory
  1. ./install_sdk_UMD.sh
  2. ./install_KMD.sh
  3. reboot to 3.10.0MSSr2
  4. Copied over mfxhei.h to /opt/intel/mediasdk/include
  5. cd /home/gotron/gotron/IMSDK2015/MediaServerStudioProfessionalEvaluation2015R2/HEVCEvaluation2015
  6. ./install.sh
  7. Then builded the samples: perl build.pl --cmake=intel64.make.release -build
[root@localhost samples]# lsmod |grep 'i915'
i915                  730175  2
i2c_algo_bit           13413  1 i915
drm_kms_helper         52758  1 i915
drm                   297577  2 i915,drm_kms_helper
i2c_core               40325  5 drm,i915,i2c_i801,drm_kms_helper,i2c_algo_bit
video                  19267  1 i915
Did I do something wrong ?
Thanks in advance !
Nina_K_Intel
Hi Zhu,
Could you please try the latest release of Media Server Studio - 2015 R3 - it has been released very recently and is available as eval version on the web. If the problem still exists, please report back and we will look into it.
Nina
zhu_j_1
Nina Kurina (Intel) wrote:
Hi Zhu,
Nina
Hi Nina. Thanks for reply. I tried another sample packages MediaSamples-Linux-5.0.1603344.93446, then builded it with no errors.
export MFX_HOME=/opt/intel/mediasdk
export LD_LIBRARY_PATH=$MFX_HOME/lib64
SAMPLE_BIN="/home/gotron/gotron/IMSDK2015/MediaSamples-Linux-5.0.1603344.93446/samples/__cmake/intel64.make.release/__bin/release"
export PATH=$SAMPLE_BIN:$PATH
Actually , I don't known if these Envionments above are necessary.
[root@localhost gotron]# uname -ar
Linux localhost.localdomain 3.10.0MSSr2 #1 SMP Tue Dec 23 02:59:08 EST 2014 x86_64 x86_64 x86_64 GNU/Linux
[root@localhost gotron]# sample_multi_transcode_drm -i::h264 f.h264 -o::h264 test_out.h264 -hw
Intel(R) Media SDK Multi Transcoding Sample Version 0.0.000.0000
terminate called after throwing an instance of 'std::bad_alloc'
  what():  std::bad_alloc
Aborted (core dumped)
Here is my dmesg:
There seems to be something wrong with it.
I didn't found any device under /dev/dri/
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.0MSSr2 (root@localhost.localdomain) (gcc version 4.8.2 20140120 (Red Hat 4.8.2-16) (GCC) ) #1 SMP Tue Dec 23 02:59:08 EST 2014
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-3.10.0MSSr2 root=/dev/mapper/centos-root ro rd.lvm.lv=centos/swap nomodeset crashkernel=auto vconsole.keymap=us vconsole.font=latarcyrheb-sun16 rd.lvm.lv=centos/root rhgb quiet LANG=en_US.UTF-8
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000ad7dafff] usable
[    0.000000] BIOS-e820: [mem 0x00000000ad7db000-0x00000000ad7e1fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000ad7e2000-0x00000000ae2b7fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000ae2b8000-0x00000000ae810fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ae811000-0x00000000c0e36fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000c0e37000-0x00000000c0ecefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000c0ecf000-0x00000000c0f14fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000c0f15000-0x00000000c0fccfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000c0fcd000-0x00000000c2ffefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000c2fff000-0x00000000c2ffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000c3800000-0x00000000df9fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000011f5fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: Gigabyte Technology Co., Ltd. Z87M-D3H/Z87M-D3H, BIOS F11 08/12/2014
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] No AGP bridge found
[    0.000000] e820: last_pfn = 0x11f600 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CFFFF write-protect
[    0.000000]   D0000-E7FFF uncachable
[    0.000000]   E8000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 0000000000 mask 7F00000000 write-back
[    0.000000]   1 base 0100000000 mask 7FE0000000 write-back
[    0.000000]   2 base 00E0000000 mask 7FE0000000 uncachable
[    0.000000]   3 base 00D0000000 mask 7FF0000000 uncachable
[    0.000000]   4 base 00C8000000 mask 7FF8000000 uncachable
[    0.000000]   5 base 00C4000000 mask 7FFC000000 uncachable
[    0.000000]   6 base 00C3800000 mask 7FFF800000 uncachable
[    0.000000]   7 base 011F800000 mask 7FFF800000 uncachable
[    0.000000]   8 base 011F600000 mask 7FFFE00000 uncachable
[    0.000000]   9 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] original variable MTRRs
[    0.000000] reg 0, base: 0GB, range: 4GB, type WB
[    0.000000] reg 1, base: 4GB, range: 512MB, type WB
[    0.000000] reg 2, base: 3584MB, range: 512MB, type UC
[    0.000000] reg 3, base: 3328MB, range: 256MB, type UC
[    0.000000] reg 4, base: 3200MB, range: 128MB, type UC
[    0.000000] reg 5, base: 3136MB, range: 64MB, type UC
[    0.000000] reg 6, base: 3128MB, range: 8MB, type UC
[    0.000000] reg 7, base: 4600MB, range: 8MB, type UC
[    0.000000] reg 8, base: 4598MB, range: 2MB, type UC
[    0.000000] total RAM covered: 3630M
[    0.000000] Found optimal setting for mtrr clean up
[    0.000000]  gran_size: 64K 	chunk_size: 16M 	num_reg: 7  	lose cover RAM: 0G
[    0.000000] New variable MTRRs
[    0.000000] reg 0, base: 0GB, range: 2GB, type WB
[    0.000000] reg 1, base: 2GB, range: 1GB, type WB
[    0.000000] reg 2, base: 3GB, range: 64MB, type WB
[    0.000000] reg 3, base: 3128MB, range: 8MB, type UC
[    0.000000] reg 4, base: 4GB, range: 512MB, type WB
[    0.000000] reg 5, base: 4598MB, range: 2MB, type UC
[    0.000000] reg 6, base: 4600MB, range: 8MB, type UC
[    0.000000] e820: update [mem 0xc3800000-0xffffffff] usable ==> reserved
[    0.000000] e820: last_pfn = 0xc3000 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fd6e0-0x000fd6ef] mapped at [ffff8800000fd6e0]
[    0.000000] Base memory trampoline at [ffff880000097000] 97000 size 24576
[    0.000000] Using GB pages for direct mapping
[    0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[    0.000000]  [mem 0x00000000-0x000fffff] page 4k
[    0.000000] BRK [0x01e20000, 0x01e20fff] PGTABLE
[    0.000000] BRK [0x01e21000, 0x01e21fff] PGTABLE
[    0.000000] BRK [0x01e22000, 0x01e22fff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0x11f400000-0x11f5fffff]
[    0.000000]  [mem 0x11f400000-0x11f5fffff] page 2M
[    0.000000] BRK [0x01e23000, 0x01e23fff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0x11c000000-0x11f3fffff]
[    0.000000]  [mem 0x11c000000-0x11f3fffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x100000000-0x11bffffff]
[    0.000000]  [mem 0x100000000-0x11bffffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x00100000-0xad7dafff]
[    0.000000]  [mem 0x00100000-0x001fffff] page 4k
[    0.000000]  [mem 0x00200000-0x3fffffff] page 2M
[    0.000000]  [mem 0x40000000-0x7fffffff] page 1G
[    0.000000]  [mem 0x80000000-0xad5fffff] page 2M
[    0.000000]  [mem 0xad600000-0xad7dafff] page 4k
[    0.000000] init_memory_mapping: [mem 0xad7e2000-0xae2b7fff]
[    0.000000]  [mem 0xad7e2000-0xad7fffff] page 4k
[    0.000000]  [mem 0xad800000-0xae1fffff] page 2M
[    0.000000]  [mem 0xae200000-0xae2b7fff] page 4k
[    0.000000] BRK [0x01e24000, 0x01e24fff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0xae811000-0xc0e36fff]
[    0.000000]  [mem 0xae811000-0xae9fffff] page 4k
[    0.000000]  [mem 0xaea00000-0xc0dfffff] page 2M
[    0.000000]  [mem 0xc0e00000-0xc0e36fff] page 4k
[    0.000000] BRK [0x01e25000, 0x01e25fff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0xc0ecf000-0xc0f14fff]
[    0.000000]  [mem 0xc0ecf000-0xc0f14fff] page 4k
[    0.000000] init_memory_mapping: [mem 0xc2fff000-0xc2ffffff]
[    0.000000]  [mem 0xc2fff000-0xc2ffffff] page 4k
[    0.000000] RAMDISK: [mem 0x33699000-0x35b44fff]
[    0.000000] Reserving 161MB of memory at 656MB for crashkernel (System RAM: 3582MB)
[    0.000000] ACPI: RSDP 00000000000f0490 00024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 00000000c0f99078 0006C (v01 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI: FACP 00000000c0fa5e08 0010C (v05 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI: DSDT 00000000c0f99178 0CC8D (v02 ALASKA    A M I 00000088 INTL 20091112)
[    0.000000] ACPI: FACS 00000000c0fcb080 00040
[    0.000000] ACPI: APIC 00000000c0fa5f18 00072 (v03 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI: FPDT 00000000c0fa5f90 00044 (v01 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 00000000c0fa5fd8 00539 (v01  PmRef  Cpu0Ist 00003000 INTL 20120711)
[    0.000000] ACPI: SSDT 00000000c0fa6518 00AD8 (v01  PmRef    CpuPm 00003000 INTL 20120711)
[    0.000000] ACPI: MCFG 00000000c0fa6ff0 0003C (v01 ALASKA    A M I 01072009 MSFT 00000097)
[    0.000000] ACPI: HPET 00000000c0fa7030 00038 (v01 ALASKA    A M I 01072009 AMI. 00000005)
[    0.000000] ACPI: SSDT 00000000c0fa7068 0036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[    0.000000] ACPI: SSDT 00000000c0fa73d8 034E1 (v01 SaSsdt  SaSsdt  00003000 INTL 20091112)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000011f5fffff]
[    0.000000] Initmem setup node 0 [mem 0x00000000-0x11f5fffff]
[    0.000000]   NODE_DATA [mem 0x11f5d4000-0x11f5fafff]
[    0.000000]  [ffffea0000000000-ffffea00047fffff] PMD -> [ffff88011b200000-ffff88011ebfffff] on node 0
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x00001000-0x00ffffff]
[    0.000000]   DMA32    [mem 0x01000000-0xffffffff]
[    0.000000]   Normal   [mem 0x100000000-0x11f5fffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00001000-0x0009cfff]
[    0.000000]   node   0: [mem 0x00100000-0xad7dafff]
[    0.000000]   node   0: [mem 0xad7e2000-0xae2b7fff]
[    0.000000]   node   0: [mem 0xae811000-0xc0e36fff]
[    0.000000]   node   0: [mem 0xc0ecf000-0xc0f14fff]
[    0.000000]   node   0: [mem 0xc2fff000-0xc2ffffff]
[    0.000000]   node   0: [mem 0x100000000-0x11f5fffff]
[    0.000000] On node 0 totalpages: 917178
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3996 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 12261 pages used for memmap
[    0.000000]   DMA32 zone: 784670 pages, LIFO batch:31
[    0.000000]   Normal zone: 2008 pages used for memmap
[    0.000000]   Normal zone: 128512 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x1808
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xad7db000-0xad7e1fff]
[    0.000000] PM: Registered nosave memory: [mem 0xae2b8000-0xae810fff]
[    0.000000] PM: Registered nosave memory: [mem 0xc0e37000-0xc0ecefff]
[    0.000000] PM: Registered nosave memory: [mem 0xc0f15000-0xc0fccfff]
[    0.000000] PM: Registered nosave memory: [mem 0xc0fcd000-0xc2ffefff]
[    0.000000] PM: Registered nosave memory: [mem 0xc3000000-0xc37fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xc3800000-0xdf9fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xdfa00000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] e820: [mem 0xdfa00000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] setup_percpu: NR_CPUS:5120 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] PERCPU: Embedded 29 pages/cpu @ffff88011f200000 s86656 r8192 d23936 u524288
[    0.000000] pcpu-alloc: s86656 r8192 d23936 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 902824
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-3.10.0MSSr2 root=/dev/mapper/centos-root ro rd.lvm.lv=centos/swap nomodeset crashkernel=auto vconsole.keymap=us vconsole.font=latarcyrheb-sun16 rd.lvm.lv=centos/root rhgb quiet LANG=en_US.UTF-8
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] xsave: enabled xstate_bv 0x7, cntxt size 0x340
[    0.000000] Checking aperture...
[    0.000000] Memory: 3325384k/4708352k available (6109k kernel code, 1039640k absent, 343328k reserved, 4070k data, 1584k init)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=5120 to nr_cpu_ids=4.
[    0.000000] 	Experimental no-CBs for all CPUs
[    0.000000] 	Experimental no-CBs CPUs: 0-3.
[    0.000000] NR_IRQS:327936 nr_irqs:712 16
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] allocated 15204352 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.001000] spurious 8259A interrupt: IRQ7.
[    0.002000] tsc: Detected 2992.983 MHz processor
[    0.000002] Calibrating delay loop (skipped), value calculated using timer frequency.. 5985.96 BogoMIPS (lpj=2992983)
[    0.000005] pid_max: default: 32768 minimum: 301
[    0.000025] Security Framework initialized
[    0.000031] SELinux:  Initializing.
[    0.000038] SELinux:  Starting in permissive mode
[    0.000287] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.001133] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.001491] Mount-cache hash table entries: 4096
[    0.001669] Initializing cgroup subsys memory
[    0.001677] Initializing cgroup subsys devices
[    0.001679] Initializing cgroup subsys freezer
[    0.001680] Initializing cgroup subsys net_cls
[    0.001681] Initializing cgroup subsys blkio
[    0.001682] Initializing cgroup subsys perf_event
[    0.001684] Initializing cgroup subsys hugetlb
[    0.001712] CPU: Physical Processor ID: 0
[    0.001713] CPU: Processor Core ID: 0
[    0.003419] mce: CPU supports 7 MCE banks
[    0.003437] CPU0: Thermal monitoring enabled (TM1)
[    0.003451] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0
tlb_flushall_shift: 6
[    0.003535] Freeing SMP alternatives: 24k freed
[    0.004398] ACPI: Core revision 20130517
[    0.010300] ACPI: All ACPI Tables successfully acquired
[    0.010745] ftrace: allocating 23394 entries in 92 pages
[    0.019937] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[    0.029936] smpboot: CPU0: Intel(R) Core(TM) i3-4330T CPU @ 3.00GHz (fam: 06, model: 3c, stepping: 03)
[    0.029943] TSC deadline timer enabled
[    0.029949] Performance Events: PEBS fmt2+, 16-deep LBR, Haswell events, full-width counters, Intel PMU driver.
[    0.029955] ... version:                3
[    0.029956] ... bit width:              48
[    0.029956] ... generic registers:      4
[    0.029957] ... value mask:             0000ffffffffffff
[    0.029958] ... max period:             0000ffffffffffff
[    0.029958] ... fixed-purpose events:   3
[    0.029959] ... event mask:             000000070000000f
[    0.046038] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.031042] smpboot: Booting Node   0, Processors  #1 #2 #3 OK
[    0.076072] Brought up 4 CPUs
[    0.076076] smpboot: Total of 4 processors activated (23943.86 BogoMIPS)
[    0.080088] devtmpfs: initialized
[    0.080681] EVM: security.selinux
[    0.080682] EVM: security.ima
[    0.080683] EVM: security.capability
[    0.080735] PM: Registering ACPI NVS region [mem 0xad7db000-0xad7e1fff] (28672 bytes)
[    0.080737] PM: Registering ACPI NVS region [mem 0xc0f15000-0xc0fccfff] (753664 bytes)
[    0.081296] atomic64 test passed for x86-64 platform with CX8 and with SSE
[    0.081328] NET: Registered protocol family 16
[    0.081433] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.081435] ACPI: bus type PCI registered
[    0.081436] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.081475] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.081477] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.086254] PCI: Using configuration type 1 for base access
[    0.086810] bio: create slab <bio-0> at 0
[    0.086909] ACPI: Added _OSI(Module Device)
[    0.086910] ACPI: Added _OSI(Processor Device)
[    0.086912] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.086913] ACPI: Added _OSI(Processor Aggregator Device)
[    0.088199] ACPI: EC: Look up EC in DSDT
[    0.089772] ACPI: Executed 1 blocks of module-level executable AML code
[    0.091735] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[    0.094944] ACPI: SSDT 00000000c0ec4c18 003D3 (v01  PmRef  Cpu0Cst 00003001 INTL 20120711)
[    0.095265] ACPI: Dynamic OEM Table Load:
[    0.095267] ACPI: SSDT           (null) 003D3 (v01  PmRef  Cpu0Cst 00003001 INTL 20120711)
[    0.097039] ACPI: SSDT 00000000c0ec4618 005AA (v01  PmRef    ApIst 00003000 INTL 20120711)
[    0.097414] ACPI: Dynamic OEM Table Load:
[    0.097415] ACPI: SSDT           (null) 005AA (v01  PmRef    ApIst 00003000 INTL 20120711)
[    0.099943] ACPI: SSDT 00000000c0ec3d98 00119 (v01  PmRef    ApCst 00003000 INTL 20120711)
[    0.100261] ACPI: Dynamic OEM Table Load:
[    0.100262] ACPI: SSDT           (null) 00119 (v01  PmRef    ApCst 00003000 INTL 20120711)
[    0.102391] ACPI: Interpreter enabled
[    0.102397] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_] (20130517/hwxface-571)
[    0.102402] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20130517/hwxface-571)
[    0.102414] ACPI: (supports S0 S3 S4 S5)
[    0.102415] ACPI: Using IOAPIC for interrupt routing
[    0.102435] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.102536] ACPI: No dock devices found.
[    0.108571] ACPI: Power Resource [FN00] (off)
[    0.108620] ACPI: Power Resource [FN01] (off)
[    0.108668] ACPI: Power Resource [FN02] (off)
[    0.108713] ACPI: Power Resource [FN03] (off)
[    0.108758] ACPI: Power Resource [FN04] (off)
[    0.109306] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.109311] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.109473] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
[    0.109561] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[    0.109904] PCI host bridge to bus 0000:00
[    0.109907] pci_bus 0000:00: root bus resource [bus 00-3e]
[    0.109909] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7]
[    0.109910] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff]
[    0.109911] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[    0.109912] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
[    0.109913] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[    0.109914] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[    0.109915] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[    0.109916] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[    0.109917] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[    0.109918] pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff]
[    0.109926] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[    0.109998] pci 0000:00:02.0: [8086:0412] type 00 class 0x030000
[    0.110011] pci 0000:00:02.0: reg 0x10: [mem 0xf7800000-0xf7bfffff 64bit]
[    0.110018] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.110023] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.110086] pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300
[    0.110093] pci 0000:00:03.0: reg 0x10: [mem 0xf7d14000-0xf7d17fff 64bit]
[    0.110183] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[    0.110201] pci 0000:00:14.0: reg 0x10: [mem 0xf7d00000-0xf7d0ffff 64bit]
[    0.110262] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.110293] pci 0000:00:14.0: System wakeup disabled by ACPI
[    0.110315] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[    0.110334] pci 0000:00:16.0: reg 0x10: [mem 0xf7d1e000-0xf7d1e00f 64bit]
[    0.110398] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.110457] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[    0.110476] pci 0000:00:1a.0: reg 0x10: [mem 0xf7d1c000-0xf7d1c3ff]
[    0.110564] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.110608] pci 0000:00:1a.0: System wakeup disabled by ACPI
[    0.110633] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[    0.110647] pci 0000:00:1b.0: reg 0x10: [mem 0xf7d10000-0xf7d13fff 64bit]
[    0.110717] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.110749] pci 0000:00:1b.0: System wakeup disabled by ACPI
[    0.110769] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[    0.110834] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.110867] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.110887] pci 0000:00:1c.2: [8086:8c14] type 01 class 0x060400
[    0.110957] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.110990] pci 0000:00:1c.2: System wakeup disabled by ACPI
[    0.111011] pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400
[    0.111076] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.111109] pci 0000:00:1c.3: System wakeup disabled by ACPI
[    0.111137] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[    0.111156] pci 0000:00:1d.0: reg 0x10: [mem 0xf7d1b000-0xf7d1b3ff]
[    0.111244] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.111286] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.111310] pci 0000:00:1f.0: [8086:8c44] type 00 class 0x060100
[    0.111456] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[    0.111471] pci 0000:00:1f.2: reg 0x10: [io  0xf0b0-0xf0b7]
[    0.111478] pci 0000:00:1f.2: reg 0x14: [io  0xf0a0-0xf0a3]
[    0.111485] pci 0000:00:1f.2: reg 0x18: [io  0xf090-0xf097]
[    0.111492] pci 0000:00:1f.2: reg 0x1c: [io  0xf080-0xf083]
[    0.111499] pci 0000:00:1f.2: reg 0x20: [io  0xf060-0xf07f]
[    0.111506] pci 0000:00:1f.2: reg 0x24: [mem 0xf7d1a000-0xf7d1a7ff]
[    0.111541] pci 0000:00:1f.2: PME# supported from D3hot
[    0.111585] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[    0.111599] pci 0000:00:1f.3: reg 0x10: [mem 0xf7d19000-0xf7d190ff 64bit]
[    0.111619] pci 0000:00:1f.3: reg 0x20: [io  0xf040-0xf05f]
[    0.111731] acpiphp: Slot [1] registered
[    0.111736] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.111807] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[    0.111823] pci 0000:02:00.0: reg 0x10: [io  0xe000-0xe0ff]
[    0.111852] pci 0000:02:00.0: reg 0x18: [mem 0xf7c00000-0xf7c00fff 64bit]
[    0.111871] pci 0000:02:00.0: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref]
[    0.111965] pci 0000:02:00.0: supports D1 D2
[    0.111966] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.111996] pci 0000:02:00.0: System wakeup disabled by ACPI
[    0.113922] pci 0000:00:1c.2: PCI bridge to [bus 02]
[    0.113925] pci 0000:00:1c.2:   bridge window [io  0xe000-0xefff]
[    0.113928] pci 0000:00:1c.2:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.113932] pci 0000:00:1c.2:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.114000] pci 0000:03:00.0: [8086:244e] type 01 class 0x060401
[    0.114133] pci 0000:03:00.0: supports D1 D2
[    0.114134] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.114158] pci 0000:03:00.0: System wakeup disabled by ACPI
[    0.114175] pci 0000:00:1c.3: PCI bridge to [bus 03-04]
[    0.114303] pci 0000:03:00.0: PCI bridge to [bus 04] (subtractive decode)
[    0.114325] pci 0000:03:00.0:   bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[    0.114326] pci 0000:03:00.0:   bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[    0.114327] pci 0000:03:00.0:   bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[    0.114328] pci 0000:03:00.0:   bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[    0.114355] acpi PNP0A08:00: Disabling ASPM (FADT indicates it is unsupported)
[    0.114980] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.115015] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.115047] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.115079] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.115111] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.115142] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.115174] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 10 11 12 14 15)
[    0.115206] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.115469] ACPI: Enabled 4 GPEs in block 00 to 3F
[    0.115475] ACPI: \_SB_.PCI0: notify handler is installed
[    0.115524] Found 1 acpi root devices
[    0.115585] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.115587] vgaarb: loaded
[    0.115588] vgaarb: bridge control possible 0000:00:02.0
[    0.115629] SCSI subsystem initialized
[    0.115644] ACPI: bus type USB registered
[    0.115654] usbcore: registered new interface driver usbfs
[    0.115658] usbcore: registered new interface driver hub
[    0.115683] usbcore: registered new device driver usb
[    0.115738] PCI: Using ACPI for IRQ routing
[    0.117119] PCI: pci_cache_line_size set to 64 bytes
[    0.117163] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
[    0.117164] e820: reserve RAM buffer [mem 0xad7db000-0xafffffff]
[    0.117165] e820: reserve RAM buffer [mem 0xae2b8000-0xafffffff]
[    0.117166] e820: reserve RAM buffer [mem 0xc0e37000-0xc3ffffff]
[    0.117167] e820: reserve RAM buffer [mem 0xc0f15000-0xc3ffffff]
[    0.117168] e820: reserve RAM buffer [mem 0xc3000000-0xc3ffffff]
[    0.117169] e820: reserve RAM buffer [mem 0x11f600000-0x11fffffff]
[    0.117236] NetLabel: Initializing
[    0.117237] NetLabel:  domain hash size = 128
[    0.117238] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.117245] NetLabel:  unlabeled traffic allowed by default
[    0.117273] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.117276] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.119288] Switching to clocksource hpet
[    0.122767] pnp: PnP ACPI init
[    0.122777] ACPI: bus type PNP registered
[    0.122844] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.122847] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.122856] pnp 00:01: [dma 4]
[    0.122867] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[    0.122878] pnp 00:02: Plug and Play ACPI device, IDs INT0800 (active)
[    0.122957] pnp 00:03: Plug and Play ACPI device, IDs PNP0103 (active)
[    0.122991] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[    0.123070] system 00:05: [io  0x0680-0x069f] has been reserved
[    0.123072] system 00:05: [io  0xffff] has been reserved
[    0.123073] system 00:05: [io  0xffff] has been reserved
[    0.123074] system 00:05: [io  0xffff] has been reserved
[    0.123075] system 00:05: [io  0x1c00-0x1cfe] has been reserved
[    0.123076] system 00:05: [io  0x1d00-0x1dfe] has been reserved
[    0.123078] system 00:05: [io  0x1e00-0x1efe] has been reserved
[    0.123079] system 00:05: [io  0x1f00-0x1ffe] has been reserved
[    0.123080] system 00:05: [io  0x1800-0x18fe] could not be reserved
[    0.123081] system 00:05: [io  0x164e-0x164f] has been reserved
[    0.123083] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.123098] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.123129] system 00:07: [io  0x1854-0x1857] has been reserved
[    0.123131] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.123211] system 00:08: [io  0x0a00-0x0a0f] has been reserved
[    0.123212] system 00:08: [io  0x0a30-0x0a3f] has been reserved
[    0.123214] system 00:08: [io  0x0a20-0x0a2f] has been reserved
[    0.123215] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.123403] pnp 00:09: [dma 0 disabled]
[    0.123433] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.123626] pnp 00:0a: [dma 0 disabled]
[    0.123698] pnp 00:0a: Plug and Play ACPI device, IDs PNP0400 (active)
[    0.123729] system 00:0b: [io  0x04d0-0x04d1] has been reserved
[    0.123731] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.124028] system 00:0c: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.124030] system 00:0c: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.124031] system 00:0c: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.124032] system 00:0c: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.124034] system 00:0c: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.124035] system 00:0c: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.124036] system 00:0c: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.124037] system 00:0c: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.124038] system 00:0c: [mem 0xff000000-0xffffffff] has been reserved
[    0.124040] system 00:0c: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.124041] system 00:0c: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[    0.124042] system 00:0c: [mem 0xf7fe0000-0xf7feffff] has been reserved
[    0.124044] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.124205] pnp: PnP ACPI: found 13 devices
[    0.124206] ACPI: bus type PNP unregistered
[    0.130134] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.130146] pci 0000:00:1c.2: PCI bridge to [bus 02]
[    0.130148] pci 0000:00:1c.2:   bridge window [io  0xe000-0xefff]
[    0.130152] pci 0000:00:1c.2:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.130156] pci 0000:00:1c.2:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.130161] pci 0000:03:00.0: PCI bridge to [bus 04]
[    0.130181] pci 0000:00:1c.3: PCI bridge to [bus 03-04]
[    0.130192] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7]
[    0.130193] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff]
[    0.130195] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[    0.130196] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
[    0.130197] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
[    0.130198] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
[    0.130199] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
[    0.130200] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff]
[    0.130201] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff]
[    0.130202] pci_bus 0000:00: resource 13 [mem 0xdfa00000-0xfeafffff]
[    0.130203] pci_bus 0000:02: resource 0 [io  0xe000-0xefff]
[    0.130204] pci_bus 0000:02: resource 1 [mem 0xf7c00000-0xf7cfffff]
[    0.130206] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.130229] NET: Registered protocol family 2
[    0.130370] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.130439] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.130528] TCP: Hash tables configured (established 32768 bind 32768)
[    0.130552] TCP: reno registered
[    0.130558] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.130576] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.130629] NET: Registered protocol family 1
[    0.130638] pci 0000:00:02.0: Boot video device
[    0.160365] PCI: CLS 64 bytes, default 64
[    0.160404] Unpacking initramfs...
[    0.626365] Freeing initrd memory: 37552k freed
[    0.632604] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.632607] software IO TLB [mem 0xbce37000-0xc0e37000] (64MB) mapped at [ffff8800bce37000-ffff8800c0e36fff]
[    0.632953] microcode: CPU0 sig=0x306c3, pf=0x2, revision=0x19
[    0.632960] microcode: CPU1 sig=0x306c3, pf=0x2, revision=0x19
[    0.632968] microcode: CPU2 sig=0x306c3, pf=0x2, revision=0x19
[    0.632975] microcode: CPU3 sig=0x306c3, pf=0x2, revision=0x19
[    0.633000] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    0.633167] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.633178] Initialise system trusted keyring
[    0.633209] audit: initializing netlink socket (disabled)
[    0.633219] type=2000 audit(1419407435.623:1): initialized
[    0.649661] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.650394] zbud: loaded
[    0.650507] VFS: Disk quotas dquot_6.5.2
[    0.650530] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.650646] msgmni has been set to 6568
[    0.650685] Key type big_key registered
[    0.650686] SELinux:  Registering netfilter hooks
[    0.651325] alg: No test for stdrng (krng)
[    0.651332] NET: Registered protocol family 38
[    0.651335] Key type asymmetric registered
[    0.651336] Asymmetric key parser 'x509' registered
[    0.651360] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.651393] io scheduler noop registered
[    0.651394] io scheduler deadline registered (default)
[    0.651409] io scheduler cfq registered
[    0.651754] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.651765] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.651806] intel_idle: MWAIT substates: 0x42120
[    0.651807] intel_idle: v0.4 model 0x3C
[    0.651808] intel_idle: lapic_timer_reliable_states 0xffffffff
[    0.651890] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[    0.651894] ACPI: Power Button [PWRB]
[    0.651917] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.651919] ACPI: Power Button [PWRF]
[    0.651966] ACPI: Fan [FAN0] (off)
[    0.651981] ACPI: Fan [FAN1] (off)
[    0.651996] ACPI: Fan [FAN2] (off)
[    0.652008] ACPI: Fan [FAN3] (off)
[    0.652023] ACPI: Fan [FAN4] (off)
[    0.652061] ACPI: Requesting acpi_cpufreq
[    0.652537] thermal LNXTHERM:00: registered as thermal_zone0
[    0.652539] ACPI: Thermal Zone [TZ00] (28 C)
[    0.652678] thermal LNXTHERM:01: registered as thermal_zone1
[    0.652679] ACPI: Thermal Zone [TZ01] (30 C)
[    0.652702] GHES: HEST is not enabled!
[    0.652749] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.673319] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.673718] Non-volatile memory driver v1.3
[    0.673719] Linux agpgart interface v0.103
[    0.673775] crash memory driver: version 1.1
[    0.673792] rdac: device handler registered
[    0.673827] hp_sw: device handler registered
[    0.673829] emc: device handler registered
[    0.673829] alua: device handler registered
[    0.673851] libphy: Fixed MDIO Bus: probed
[    0.673884] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.673886] ehci-pci: EHCI PCI platform driver
[    0.673960] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    0.673997] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    0.674009] ehci-pci 0000:00:1a.0: debug port 2
[    0.677899] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[    0.677913] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7d1c000
[    0.683108] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    0.683142] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.683143] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.683144] usb usb1: Product: EHCI Host Controller
[    0.683145] usb usb1: Manufacturer: Linux 3.10.0MSSr2 ehci_hcd
[    0.683146] usb usb1: SerialNumber: 0000:00:1a.0
[    0.683219] hub 1-0:1.0: USB hub found
[    0.683223] hub 1-0:1.0: 2 ports detected
[    0.683359] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    0.683391] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    0.683402] ehci-pci 0000:00:1d.0: debug port 2
[    0.687295] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[    0.687308] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7d1b000
[    0.693100] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    0.693124] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    0.693126] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.693127] usb usb2: Product: EHCI Host Controller
[    0.693128] usb usb2: Manufacturer: Linux 3.10.0MSSr2 ehci_hcd
[    0.693129] usb usb2: SerialNumber: 0000:00:1d.0
[    0.693209] hub 2-0:1.0: USB hub found
[    0.693213] hub 2-0:1.0: 2 ports detected
[    0.693293] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.693294] ohci-pci: OHCI PCI platform driver
[    0.693299] uhci_hcd: USB Universal Host Controller Interface driver
[    0.693379] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.693418] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    0.693514] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    0.693532] xhci_hcd 0000:00:14.0: irq 40 for MSI/MSI-X
[    0.693588] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    0.693589] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.693590] usb usb3: Product: xHCI Host Controller
[    0.693591] usb usb3: Manufacturer: Linux 3.10.0MSSr2 xhci_hcd
[    0.693592] usb usb3: SerialNumber: 0000:00:14.0
[    0.693655] hub 3-0:1.0: USB hub found
[    0.693672] hub 3-0:1.0: 14 ports detected
[    0.696154] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.696184] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[    0.696213] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    0.696214] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.696215] usb usb4: Product: xHCI Host Controller
[    0.696216] usb usb4: Manufacturer: Linux 3.10.0MSSr2 xhci_hcd
[    0.696217] usb usb4: SerialNumber: 0000:00:14.0
[    0.696281] hub 4-0:1.0: USB hub found
[    0.696292] hub 4-0:1.0: 6 ports detected
[    0.702142] usbcore: registered new interface driver usbserial
[    0.702147] usbcore: registered new interface driver usbserial_generic
[    0.702151] usbserial: USB Serial support registered for generic
[    0.702169] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    0.702532] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.702535] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.702604] mousedev: PS/2 mouse device common for all mice
[    0.702745] rtc_cmos 00:06: RTC can wake from S4
[    0.702865] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[    0.702892] rtc_cmos 00:06: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.702903] Intel P-state driver initializing.
[    0.702914] Intel pstate controlling: cpu 0
[    0.702927] Intel pstate controlling: cpu 1
[    0.702939] Intel pstate controlling: cpu 2
[    0.702950] Intel pstate controlling: cpu 3
[    0.703020] cpuidle: using governor menu
[    0.703193] hidraw: raw HID events driver (C) Jiri Kosina
[    0.703244] usbcore: registered new interface driver usbhid
[    0.703244] usbhid: USB HID core driver
[    0.703277] drop_monitor: Initializing network drop monitor service
[    0.703336] TCP: cubic registered
[    0.703338] Initializing XFRM netlink socket
[    0.703398] NET: Registered protocol family 10
[    0.703513] NET: Registered protocol family 17
[    0.703702] Loading compiled-in X.509 certificates
[    0.704303] Loaded X.509 cert 'Magrathea: Glacier signing key: dc81fd4e343172520400f6632336d3afaed9bb1f'
[    0.704311] registered taskstats version 1
[    0.705726] Key type trusted registered
[    0.707020] Key type encrypted registered
[    0.708323] IMA: No TPM chip found, activating TPM-bypass!
[    0.708714] rtc_cmos 00:06: setting system clock to 2014-12-24 07:50:35 UTC (1419407435)
[    0.709208] Freeing unused kernel memory: 1584k freed
[    0.711661] systemd[1]: systemd 208 running in system mode. (+PAM +LIBWRAP +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ)
[    0.711800] systemd[1]: Running in initial RAM disk.
[    0.711847] systemd[1]: Set hostname to <localhost.localdomain>.
[    0.730165] systemd[1]: Expecting device dev-mapper-centos\x2droot.device...
[    0.730177] systemd[1]: Starting -.slice.
[    0.730291] systemd[1]: Created slice -.slice.
[    0.730328] systemd[1]: Starting System Slice.
[    0.730384] systemd[1]: Created slice System Slice.
[    0.730411] systemd[1]: Starting Slices.
[    0.730418] systemd[1]: Reached target Slices.
[    0.730437] systemd[1]: Starting Timers.
[    0.730445] systemd[1]: Reached target Timers.
[    0.730465] systemd[1]: Starting Journal Socket.
[    0.730508] systemd[1]: Listening on Journal Socket.
[    0.730626] systemd[1]: Starting dracut cmdline hook...
[    0.730968] systemd[1]: Started Load Kernel Modules.
[    0.730982] systemd[1]: Starting Setup Virtual Console...
[    0.731288] systemd[1]: Starting Journal Service...
[    0.731693] systemd[1]: Started Journal Service.
[    0.736648] systemd-journald[105]: Vacuuming done, freed 0 bytes
[    0.858281] device-mapper: uevent: version 1.0.3
[    0.858365] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com
[    0.887140] systemd-udevd[261]: starting version 208
[    0.938559] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    0.938572] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[    0.938856] r8169 0000:02:00.0: irq 41 for MSI/MSI-X
[    0.939058] r8169 0000:02:00.0 eth0: RTL8168evl/8111evl at 0xffffc90000630000, 74:d4:35:83:2a:b8, XID 0c900800 IRQ 41
[    0.939060] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    0.951338] ACPI: bus type ATA registered
[    0.951437] libata version 3.00 loaded.
[    0.962346] ahci 0000:00:1f.2: version 3.0
[    0.962502] ahci 0000:00:1f.2: irq 42 for MSI/MSI-X
[    0.962563] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x4 impl SATA mode
[    0.962566] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[    0.963545] scsi0 : ahci
[    0.963663] scsi1 : ahci
[    0.963991] scsi2 : ahci
[    0.964084] scsi3 : ahci
[    0.964154] scsi4 : ahci
[    0.964228] scsi5 : ahci
[    0.964337] ata1: DUMMY
[    0.964339] ata2: DUMMY
[    0.964341] ata3: SATA max UDMA/133 abar m2048@0xf7d1a000 port 0xf7d1a200 irq 42
[    0.964343] ata4: DUMMY
[    0.964344] ata5: DUMMY
[    0.964345] ata6: DUMMY
[    0.993035] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    0.993187] [drm] Initialized drm 1.1.0 20060810
[    1.106745] [drm:drm_pci_agp_init] *ERROR* Cannot initialize the agpgart module.
[    1.106788] DRM: Fill_in_dev failed.
[    1.107300] usb 1-1: New USB device found, idVendor=8087, idProduct=8008
[    1.107302] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.107437] hub 1-1:1.0: USB hub found
[    1.107544] hub 1-1:1.0: 6 ports detected
[    1.110117] systemd-udevd[266]: renamed network interface eth0 to enp2s0
[    1.209956] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    1.268924] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.269662] ata3.00: ATA-9: WDC WD10JPVX-22JC3T0, 01.01A01, max UDMA/133
[    1.269664] ata3.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    1.270385] ata3.00: configured for UDMA/133
[    1.270541] scsi 2:0:0:0: Direct-Access     ATA      WDC WD10JPVX-22J 01.0 PQ: 0 ANSI: 5
[    1.282352] sd 2:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[    1.282355] sd 2:0:0:0: [sda] 4096-byte physical blocks
[    1.282412] sd 2:0:0:0: [sda] Write Protect is off
[    1.282414] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.282435] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.324241] usb 2-1: New USB device found, idVendor=8087, idProduct=8000
[    1.324244] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.324385] hub 2-1:1.0: USB hub found
[    1.324475] hub 2-1:1.0: 8 ports detected
[    1.387269]  sda: sda1 sda2 < sda5 > sda3 sda4
[    1.387649] sd 2:0:0:0: [sda] Attached SCSI disk
[    1.478857] usb 3-9: new low-speed USB device number 2 using xhci_hcd
[    1.493693] usb 3-9: New USB device found, idVendor=15d9, idProduct=0a4c
[    1.493696] usb 3-9: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.493698] usb 3-9: Product:  USB OPTICAL MOUSE
[    1.493817] usb 3-9: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[    1.496541] input:  USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0/input/input2
[    1.496639] hid-generic 0003:15D9:0A4C.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:14.0-9/input0
[    1.633769] tsc: Refined TSC clocksource calibration: 2993.069 MHz
[    1.633772] Switching to clocksource tsc
[    1.648794] usb 3-10: new low-speed USB device number 3 using xhci_hcd
[    1.669834] usb 3-10: New USB device found, idVendor=1c4f, idProduct=0002
[    1.669837] usb 3-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.669838] usb 3-10: Product: USB Keykoard
[    1.669839] usb 3-10: Manufacturer: USB
[    1.669925] usb 3-10: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[    1.669928] usb 3-10: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[    1.672397] input: USB USB Keykoard as /devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10:1.0/input/input3
[    1.672473] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [USB USB Keykoard] on usb-0000:00:14.0-10/input0
[    1.675088] input: USB USB Keykoard as /devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10:1.1/input/input4
[    1.675156] hid-generic 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [USB USB Keykoard] on usb-0000:00:14.0-10/input1
[    2.029805] bio: create slab <bio-1> at 1
[    2.473734] SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled
[    2.474714] XFS (dm-1): Mounting Filesystem
[    2.581541] XFS (dm-1): Ending clean mount
[    2.895247] systemd-journald[105]: Received SIGTERM
[    3.439966] type=1404 audit(1419407438.231:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[    3.607993] SELinux: 2048 avtab hash slots, 106409 rules.
[    3.619502] SELinux: 2048 avtab hash slots, 106409 rules.
[    3.646236] SELinux:  8 users, 86 roles, 4801 types, 280 bools, 1 sens, 1024 cats
[    3.646240] SELinux:  83 classes, 106409 rules
[    3.649770] SELinux:  Completing initialization.
[    3.649772] SELinux:  Setting up existing superblocks.
[    3.649780] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[    3.649783] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
[    3.649791] SELinux: initialized (dev bdev, type bdev), uses genfs_contexts
[    3.649795] SELinux: initialized (dev proc, type proc), uses genfs_contexts
[    3.649819] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    3.649834] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
[    3.650468] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
[    3.650472] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
[    3.651348] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
[    3.651355] SELinux: initialized (dev anon_inodefs, type anon_inodefs), uses genfs_contexts
[    3.651357] SELinux: initialized (dev aio, type aio), not configured for labeling
[    3.651359] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
[    3.651375] SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses transition SIDs
[    3.651381] SELinux: initialized (dev mqueue, type mqueue), uses transition SIDs
[    3.651387] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
[    3.651397] SELinux: initialized (dev securityfs, type securityfs), uses genfs_contexts
[    3.651401] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[    3.651717] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    3.651724] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    3.651802] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    3.651828] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    3.651835] SELinux: initialized (dev pstore, type pstore), uses genfs_contexts
[    3.651837] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    3.651841] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    3.651845] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    3.651851] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    3.651855] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    3.651857] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    3.651859] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    3.651866] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    3.651868] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    3.651872] SELinux: initialized (dev configfs, type configfs), uses genfs_contexts
[    3.651877] SELinux: initialized (dev dm-1, type xfs), uses xattr
[    3.661320] type=1403 audit(1419407438.452:3): policy loaded auid=4294967295 ses=4294967295
[    3.666457] systemd[1]: Successfully loaded SELinux policy in 261.128ms.
[    3.887598] systemd[1]: Relabelled /dev and /run in 20.934ms.
[    6.209185] SELinux: initialized (dev autofs, type autofs), uses genfs_contexts
[    6.784758] SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses transition SIDs
[    6.943318] systemd-journald[523]: Vacuuming done, freed 0 bytes
[    7.573786] systemd-udevd[557]: starting version 208
[    8.611620] RPC: Registered named UNIX socket transport module.
[    8.611624] RPC: Registered udp transport module.
[    8.611624] RPC: Registered tcp transport module.
[    8.611625] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    8.612698] SELinux: initialized (dev rpc_pipefs, type rpc_pipefs), uses genfs_contexts
[    9.133345] parport_pc 00:0a: reported by Plug and Play ACPI
[    9.133400] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
[    9.230873] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182f conflicts with OpRegion 0x0000000000001800-0x000000000000187f (\PMIO) (20130517/utaddress-254)
[    9.230882] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    9.230886] ACPI Warning: SystemIO range 0x0000000000001c30-0x0000000000001c3f conflicts with OpRegion 0x0000000000001c00-0x0000000000001c3f (\GPRL) (20130517/utaddress-254)
[    9.230889] ACPI Warning: SystemIO range 0x0000000000001c30-0x0000000000001c3f conflicts with OpRegion 0x0000000000001c00-0x0000000000001fff (\GPR_) (20130517/utaddress-254)
[    9.230893] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    9.230894] ACPI Warning: SystemIO range 0x0000000000001c00-0x0000000000001c2f conflicts with OpRegion 0x0000000000001c00-0x0000000000001c3f (\GPRL) (20130517/utaddress-254)
[    9.230897] ACPI Warning: SystemIO range 0x0000000000001c00-0x0000000000001c2f conflicts with OpRegion 0x0000000000001c00-0x0000000000001fff (\GPR_) (20130517/utaddress-254)
[    9.230901] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    9.230902] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    9.289089] mei_me 0000:00:16.0: irq 43 for MSI/MSI-X
[    9.340177] input: PC Speaker as /devices/platform/pcspkr/input/input5
[    9.396783] i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003)
[    9.396873] ACPI Warning: SystemIO range 0x000000000000f040-0x000000000000f05f conflicts with OpRegion 0x000000000000f040-0x000000000000f04f (\_SB_.PCI0.SBUS.SMBI) (20130517/utaddress-254)
[    9.396878] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    9.615327] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    9.615678] SELinux: initialized (dev nfsd, type nfsd), uses genfs_contexts
[    9.656014] ppdev: user-space parallel port driver
[    9.667397] iTCO_vendor_support: vendor-support=0
[    9.671766] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.10
[    9.671791] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[    9.852582] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   11.094195] alg: No test for __gcm-aes-aesni (__driver-gcm-aes-aesni)
[   11.102529] alg: No test for crc32 (crc32-pclmul)
[   11.105582] Adding 3555324k swap on /dev/mapper/centos-swap.  Priority:-1 extents:1 across:3555324k FS
[   11.522448] ------------[ cut here ]------------
[   11.522472] WARNING: at drivers/gpu/drm/i915/intel_pm.c:5348 i915_request_power_well+0x97/0xa0 [i915]()
[   11.522473] Modules linked in: snd_hda_intel(+) snd_hda_codec snd_hwdep snd_seq snd_seq_device crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel lrw snd_pcm gf128mul glue_helper ablk_helper snd_page_alloc snd_timer cryptd snd soundcore shpchp iTCO_wdt iTCO_vendor_support ppdev nfsd i2c_i801 pcspkr mei_me mei serio_raw lpc_ich mfd_core mperf parport_pc parport auth_rpcgss nfs_acl lockd sunrpc uinput xfs libcrc32c sd_mod crc_t10dif crct10dif_common i915 i2c_algo_bit drm_kms_helper drm ahci libahci libata r8169 mii i2c_core video dm_mirror dm_region_hash dm_log dm_mod
[   11.522493] CPU: 0 PID: 43 Comm: kworker/0:1 Not tainted 3.10.0MSSr2 #1
[   11.522494] Hardware name: Gigabyte Technology Co., Ltd. Z87M-D3H/Z87M-D3H, BIOS F11 08/12/2014
[   11.522498] Workqueue: events azx_probe_work [snd_hda_intel]
[   11.522500]  0000000000000000 000000005ac69646 ffff880119207d50 ffffffff815e27bb
[   11.522502]  ffff880119207d88 ffffffff8105dee1 ffff880111a45228 ffff8801191e4380
[   11.522503]  0000000000000000 ffff880111a45000 0000000000000000 ffff880119207d98
[   11.522505] Call Trace:
[   11.522512]  [<ffffffff815e27bb>] dump_stack+0x19/0x1b
[   11.522517]  [<ffffffff8105dee1>] warn_slowpath_common+0x61/0x80
[   11.522520]  [<ffffffff8105e00a>] warn_slowpath_null+0x1a/0x20
[   11.522530]  [<ffffffffa01647e7>] i915_request_power_well+0x97/0xa0 [i915]
[   11.522534]  [<ffffffffa048f952>] hda_display_power+0x32/0x40 [snd_hda_intel]
[   11.522536]  [<ffffffffa048ee59>] azx_probe_continue+0x49/0x8a0 [snd_hda_intel]
[   11.522539]  [<ffffffffa048f6c5>] azx_probe_work+0x15/0x20 [snd_hda_intel]
[   11.522543]  [<ffffffff8107e03b>] process_one_work+0x17b/0x460
[   11.522545]  [<ffffffff8107ee0b>] worker_thread+0x11b/0x400
[   11.522547]  [<ffffffff8107ecf0>] ? rescuer_thread+0x400/0x400
[   11.522549]  [<ffffffff81085aff>] kthread+0xcf/0xe0
[   11.522551]  [<ffffffff81085a30>] ? kthread_create_on_node+0x140/0x140
[   11.522554]  [<ffffffff815f2dec>] ret_from_fork+0x7c/0xb0
[   11.522556]  [<ffffffff81085a30>] ? kthread_create_on_node+0x140/0x140
[   11.522557] ---[ end trace 6aa0da9469b17c69 ]---
[   11.522591] snd_hda_intel 0000:00:03.0: irq 44 for MSI/MSI-X
[   11.522711] snd_hda_intel 0000:00:1b.0: irq 45 for MSI/MSI-X
[   11.541153] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input6
[   11.541319] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input7
[   11.541398] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input8
[   11.561997] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input9
[   11.562422] input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card1/input10
[   11.562999] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card1/input11
[   11.563732] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card1/input12
[   11.564504] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card1/input13
[   11.564573] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card1/input14
[   11.565151] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input15
[   11.565266] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input16
[   12.511097] Adding 7811068k swap on /dev/sda5.  Priority:-2 extents:1 across:7811068k FS
[   13.194832] XFS (sda3): Mounting Filesystem
[   13.812067] XFS (sda3): Ending clean mount
[   13.812079] SELinux: initialized (dev sda3, type xfs), uses xattr
[   14.245555] XFS (dm-2): Mounting Filesystem
[   15.633377] XFS (dm-2): Ending clean mount
[   15.633388] SELinux: initialized (dev dm-2, type xfs), uses xattr
[   15.642662] systemd-journald[523]: Received request to flush runtime journal from PID 1
[   15.854959] type=1305 audit(1419407450.650:4): audit_pid=716 old=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:auditd_t:s0 res=1
[   16.356227] sd 2:0:0:0: Attached scsi generic sg0 type 0
[   20.531407] ip_tables: (C) 2000-2006 Netfilter Core Team
[   20.849988] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   21.168553] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   21.978150] Ebtables v2.0 registered
[   22.289695] Bridge firewalling registered
[   23.772927] r8169 0000:02:00.0 enp2s0: link down
[   23.772938] r8169 0000:02:00.0 enp2s0: link down
[   23.772984] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[   25.322004] r8169 0000:02:00.0 enp2s0: link up
[   25.322013] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[   33.657942] fuse init (API version 7.22)
[   33.664007] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
[   33.679010] SELinux: initialized (dev fusectl, type fusectl), uses genfs_contexts
[   42.196317] Adjusting tsc more than 11% (6227876 vs 6221945)
Regards.
zhu_j_1
Hi Nina ,
I tried  MSS 2015 R3 ,and it works fine.
Regards.
Nina_K_Intel
Hi Zhu,
Great to hear that!
Nina
