how to disable B frame of HEVC?
qiufang_l_
I run sample_encode on windows. I set the command arguments as follows:
h265 -i D:\yuv\rpd_720p_slow.yuv -o output.h265 -w 1280 -h 720 -b 10000 -nobref -x 1 -u speed -p e5400a06c74d41f5b12d430bbaa23d0b
I expect hevc encoder output I P P P P P P...., but it's output is I BBBBBB. and the number of reference frame is not 1.
I saw the document Intel® Media Server Studio 2016 - HEVC Decoder and Encoder Release Notes, it says:
 H.265 MAIN SP profile is not supported in current implementation.
 Real-time encoding not guaranteed.
My question is :
Is p frame supported by Hevc encoder ? Or how can i set the number of reference frames of B frame to 1?
Jeffrey_M_Intel1
I've replicated the behavior you've described.  Hope to get back to you in a day or two with some updates and recommendations.
Surbhi_M_Intel
Hi qiufang
We don't have a public API to not encode B frames for HEVC codec, included as a new feature in our next release. we have a workaround at the moment, will send you that by end of the day.
Surbhi
qiufang_l_
Hi, Jeffrey and Surbhi.
Thank both of you.
Jeffrey_M_Intel1
Glad to help!  Just wanted to add, on the subject of reference counts:
The NumRefFrame parameter works differently for H264 and HEVC.  With HEVC, references are based on pyramid hierarchy, not the NumRefFrame setting.
qiufang_l_
Thanks for your information and for being helpful.
Silviu_B
Any update for this? Right now, the HEVC encoder marks all the P frames as B frames. The only indication that you have a P frame is that the slice_pic_order_cnt_lsb value jumps ahead for P frames.
For example, if I indicate I want a GOP size of 5 and distance between reference frame of 2:
GopPicSize=5
GopRefDist=2
I get the following output (I listed the values of slice type and slice_pic_order_cnt_lsb from the output):
slice type     slice_pic_order_cnt_lsb
I                   0
B                  2
B                  1
B                  4
B                  3
I                   5
But I should get
I                   0
P                  2
B                  1
P                  4
B                  3
I                   5
Erwan_L_1
I use last Media sdk (MediaServerStudioEssentials2017R2) under linux .
This is a bug..
in mediasdk-man.pdf we are advised to configure GopOptFlag value to MFX_GOP_STRICT . It does not work for to configure my hevc encoder.
The encoder must strictly follow the given GOP structure as
defined by parameter GopPicSize, GopRefDist
How fix it ? thank in avance
马__域
Have you solved this problem?
cedronius__anders
I'm experiencing the same 'problem'
Media SDK 20.5.1
Installed like this ->
https://github.com/Unit-X/Intel-MSDK-Ubuntu20-04-Installer
System Ubuntu 20.04
$uname -a
5.4.0-59-generic #65-Ubuntu SMP Thu Dec 10 12:01:51 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
$cat /proc/cpuinfo ->
model name : Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
I set
IdrInterval = 0
GopOptFlag = 0
GopRefDist = 1-4 (meaning I changed this parameter from 1 to 4)
GopPicSize = 30
This produces as expected a IDR with a distance of 30 frames however when looking at the codestream all other pictures are marked as slice_type==0 meaning B frame slice.
Is that correct behaviour for coding HEVC? What parameter in the codestream should I look for indicating there is a reference frame according to the setting GopRefDist?
Is there a better or updated example for controlling the GOP structure apart from 'example 17' as referred too in the documentation.
Thanks for helping.
/Anders
