i add timestamp to sample_encoder demo.
but the decodetimestamp is non-monotonous.
command line is:
./sample_encode h264 -i '/home/centos/work/transcode/IntelCodecTest/1920X1080_i420.yuv' -o enc.h264 -w 1920 -h 1080
following is the code..
Copyright (c) 2005-2016, Intel Corporation
All rights reserved.
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
3. Neither the name of the copyright holder nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
This sample was distributed or derived from the Intel's Media Samples package.
The original version of this sample may be obtained from https://software.intel.com/en-us/intel-media-server-studio
or https://software.intel.com/en-us/media-client-solutions-support.
#include "mfx_samples_config.h"
#include "pipeline_encode.h"
#include "sysmem_allocator.h"
#if D3D_SURFACES_SUPPORT
#include "d3d_allocator.h"
#include "d3d11_allocator.h"
#include "d3d_device.h"
#include "d3d11_device.h"
#endif
#ifdef LIBVA_SUPPORT
#include "vaapi_allocator.h"
#include "vaapi_device.h"
#endif
#include "plugin_loader.h"
#if defined (ENABLE_V4L2_SUPPORT)
#include <pthread.h>
#endif
/* obtain the clock tick of an uninterrupted master clock */
msdk_tick time_get_tick(void)
return msdk_time_get_tick();
LARGE_INTEGER t1;
QueryPerformanceCounter(&t1);
return t1.QuadPart;*/
} /* vm_tick vm_time_get_tick(void) */
/* obtain the clock resolution */
msdk_tick time_get_frequency(void)
return msdk_time_get_frequency();
LARGE_INTEGER t1;
QueryPerformanceFrequency(&t1);
} /* vm_tick vm_time_get_frequency(void) */
CEncTaskPool::CEncTaskPool()
m_pTasks = NULL;
m_pmfxSession = NULL;
m_nTaskBufferStart = 0;
m_nPoolSize = 0;
CEncTaskPool::~CEncTaskPool()
Close();
mfxStatus CEncTaskPool::Init(MFXVideoSession* pmfxSession, CSmplBitstreamWriter* pWriter, mfxU32 nPoolSize, mfxU32 nBufferSize, CSmplBitstreamWriter *pOtherWriter)
MSDK_CHECK_POINTER(pmfxSession, MFX_ERR_NULL_PTR);
MSDK_CHECK_POINTER(pWriter, MFX_ERR_NULL_PTR);
MSDK_CHECK_ERROR(nPoolSize, 0, MFX_ERR_UNDEFINED_BEHAVIOR);
MSDK_CHECK_ERROR(nBufferSize, 0, MFX_ERR_UNDEFINED_BEHAVIOR);
// nPoolSize must be even in case of 2 output bitstreams
if (pOtherWriter && (0 != nPoolSize % 2))
return MFX_ERR_UNDEFINED_BEHAVIOR;
m_pmfxSession = pmfxSession;
m_nPoolSize = nPoolSize;
m_pTasks = new sTask [m_nPoolSize];
MSDK_CHECK_POINTER(m_pTasks, MFX_ERR_MEMORY_ALLOC);
mfxStatus sts = MFX_ERR_NONE;
if (pOtherWriter) // 2 bitstreams on output
for (mfxU32 i = 0; i < m_nPoolSize; i+=2)
sts = m_pTasks[i+0].Init(nBufferSize, pWriter);
sts = m_pTasks[i+1].Init(nBufferSize, pOtherWriter);
MSDK_CHECK_RESULT(sts, MFX_ERR_NONE, sts);
else
for (mfxU32 i = 0; i < m_nPoolSize; i++)
sts = m_pTasks.Init(nBufferSize, pWriter);
return MFX_ERR_NONE;
mfxStatus CEncTaskPool::SynchronizeFirstTask()
m_statOverall.StartTimeMeasurement();
MSDK_CHECK_POINTER(m_pTasks, MFX_ERR_NOT_INITIALIZED);
MSDK_CHECK_POINTER(m_pmfxSession, MFX_ERR_NOT_INITIALIZED);
// non-null sync point indicates that task is in execution
if (NULL != m_pTasks[m_nTaskBufferStart].EncSyncP)
sts = m_pmfxSession->SyncOperation(m_pTasks[m_nTaskBufferStart].EncSyncP, MSDK_WAIT_INTERVAL);
if (MFX_ERR_NONE == sts)
m_statFile.StartTimeMeasurement();
sts = m_pTasks[m_nTaskBufferStart].WriteBitstream();
m_statFile.StopTimeMeasurement();
sts = m_pTasks[m_nTaskBufferStart].Reset();
// move task buffer start to the next executing task
// the first transform frame to the right with non zero sync point
m_nTaskBufferStart = (m_nTaskBufferStart + 1) % m_nPoolSize;
break;
else if (MFX_ERR_ABORTED == sts)
while (!m_pTasks[m_nTaskBufferStart].DependentVppTasks.empty())
// find out if the error occurred in a VPP task to perform recovery procedure if applicable
sts = m_pmfxSession->SyncOperation(*m_pTasks[m_nTaskBufferStart].DependentVppTasks.begin(), 0);
m_pTasks[m_nTaskBufferStart].DependentVppTasks.pop_front();
sts = MFX_ERR_ABORTED; // save the status of the encode task
continue; // go to next vpp task
else
break;
return sts;
else
sts = MFX_ERR_NOT_FOUND; // no tasks left in task buffer
m_statOverall.StopTimeMeasurement();
return sts;
mfxU32 CEncTaskPool::GetFreeTaskIndex()
mfxU32 off = 0;
if (m_pTasks)
for (off = 0; off < m_nPoolSize; off++)
if (NULL == m_pTasks[(m_nTaskBufferStart + off) % m_nPoolSize].EncSyncP)
break;
if (off >= m_nPoolSize)
return m_nPoolSize;
return (m_nTaskBufferStart + off) % m_nPoolSize;
mfxStatus CEncTaskPool::GetFreeTask(sTask **ppTask)
MSDK_CHECK_POINTER(ppTask, MFX_ERR_NULL_PTR);
mfxU32 index = GetFreeTaskIndex();
if (index >= m_nPoolSize)
return MFX_ERR_NOT_FOUND;
// return the address of the task
*ppTask = &m_pTasks[index];
void CEncTaskPool::Close()
if (m_pTasks)
m_pTasks.Close();
MSDK_SAFE_DELETE_ARRAY(m_pTasks);
m_nPoolSize = 0;
sTask::sTask()
: EncSyncP(0)
, pWriter(NULL)
MSDK_ZERO_MEMORY(mfxBS);
mfxStatus sTask::Init(mfxU32 nBufferSize, CSmplBitstreamWriter *pwriter)
Close();
pWriter = pwriter;
mfxStatus sts = Reset();
sts = InitMfxBitstream(&mfxBS, nBufferSize);
MSDK_CHECK_RESULT_SAFE(sts, MFX_ERR_NONE, sts, WipeMfxBitstream(&mfxBS));
return sts;
mfxStatus sTask::Close()
WipeMfxBitstream(&mfxBS);
EncSyncP = 0;
DependentVppTasks.clear();
mfxStatus sTask::WriteBitstream()
if (!pWriter)
return MFX_ERR_NOT_INITIALIZED;
printf("out pts: %d \t %d\n",mfxBS.TimeStamp, mfxBS.DecodeTimeStamp);
return pWriter->WriteNextFrame(&mfxBS);
mfxStatus sTask::Reset()
// mark sync point as free
EncSyncP = NULL;
// prepare bit stream
mfxBS.DataOffset = 0;
mfxBS.DataLength = 0;
mfxStatus CEncodingPipeline::AllocAndInitMVCSeqDesc()
// a simple example of mfxExtMVCSeqDesc structure filling
// actually equal to the "Default dependency mode" - when the structure fields are left 0,
// but we show how to properly allocate and fill the fields
mfxU32 i;
// mfxMVCViewDependency array
m_MVCSeqDesc.NumView = m_nNumView;
m_MVCSeqDesc.NumViewAlloc = m_nNumView;
m_MVCSeqDesc.View = new mfxMVCViewDependency[m_MVCSeqDesc.NumViewAlloc];
MSDK_CHECK_POINTER(m_MVCSeqDesc.View, MFX_ERR_MEMORY_ALLOC);
for (i = 0; i < m_MVCSeqDesc.NumViewAlloc; ++i)
MSDK_ZERO_MEMORY(m_MVCSeqDesc.View);
m_MVCSeqDesc.View.ViewId = (mfxU16) i; // set view number as view id
// set up dependency for second view
m_MVCSeqDesc.View[1].NumAnchorRefsL0 = 1;
m_MVCSeqDesc.View[1].AnchorRefL0[0] = 0; // ViewId 0 - base view
m_MVCSeqDesc.View[1].NumNonAnchorRefsL0 = 1;
m_MVCSeqDesc.View[1].NonAnchorRefL0[0] = 0; // ViewId 0 - base view
// viewId array
m_MVCSeqDesc.NumViewId = m_nNumView;
m_MVCSeqDesc.NumViewIdAlloc = m_nNumView;
m_MVCSeqDesc.ViewId = new mfxU16[m_MVCSeqDesc.NumViewIdAlloc];
MSDK_CHECK_POINTER(m_MVCSeqDesc.ViewId, MFX_ERR_MEMORY_ALLOC);
for (i = 0; i < m_MVCSeqDesc.NumViewIdAlloc; ++i)
m_MVCSeqDesc.ViewId = (mfxU16) i;
// create a single operation point containing all views
m_MVCSeqDesc.NumOP = 1;
m_MVCSeqDesc.NumOPAlloc = 1;
m_MVCSeqDesc.OP = new mfxMVCOperationPoint[m_MVCSeqDesc.NumOPAlloc];
MSDK_CHECK_POINTER(m_MVCSeqDesc.OP, MFX_ERR_MEMORY_ALLOC);
for (i = 0; i < m_MVCSeqDesc.NumOPAlloc; ++i)
MSDK_ZERO_MEMORY(m_MVCSeqDesc.OP);
m_MVCSeqDesc.OP.NumViews = (mfxU16) m_nNumView;
m_MVCSeqDesc.OP.NumTargetViews = (mfxU16) m_nNumView;
m_MVCSeqDesc.OP.TargetViewId = m_MVCSeqDesc.ViewId; // points to mfxExtMVCSeqDesc::ViewId
mfxStatus CEncodingPipeline::AllocAndInitVppDoNotUse()
m_VppDoNotUse.NumAlg = 4;
m_VppDoNotUse.AlgList = new mfxU32 [m_VppDoNotUse.NumAlg];
MSDK_CHECK_POINTER(m_VppDoNotUse.AlgList, MFX_ERR_MEMORY_ALLOC);
m_VppDoNotUse.AlgList[0] = MFX_EXTBUFF_VPP_DENOISE; // turn off denoising (on by default)
m_VppDoNotUse.AlgList[1] = MFX_EXTBUFF_VPP_SCENE_ANALYSIS; // turn off scene analysis (on by default)
m_VppDoNotUse.AlgList[2] = MFX_EXTBUFF_VPP_DETAIL; // turn off detail enhancement (on by default)
m_VppDoNotUse.AlgList[3] = MFX_EXTBUFF_VPP_PROCAMP; // turn off processing amplified (on by default)
} // CEncodingPipeline::AllocAndInitVppDoNotUse()
void CEncodingPipeline::FreeMVCSeqDesc()
MSDK_SAFE_DELETE_ARRAY(m_MVCSeqDesc.View);
MSDK_SAFE_DELETE_ARRAY(m_MVCSeqDesc.ViewId);
MSDK_SAFE_DELETE_ARRAY(m_MVCSeqDesc.OP);
void CEncodingPipeline::FreeVppDoNotUse()
MSDK_SAFE_DELETE_ARRAY(m_VppDoNotUse.AlgList);
mfxStatus CEncodingPipeline::InitMfxEncParams(sInputParams *pInParams)
m_mfxEncParams.mfx.CodecId = pInParams->CodecId;
m_mfxEncParams.mfx.TargetUsage = pInParams->nTargetUsage; // trade-off between quality and speed
m_mfxEncParams.mfx.RateControlMethod = pInParams->nRateControlMethod;
m_mfxEncParams.mfx.GopRefDist = pInParams->nGopRefDist;
m_mfxEncParams.mfx.GopPicSize = pInParams->nGopPicSize;
m_mfxEncParams.mfx.NumRefFrame = pInParams->nNumRefFrame > 0?pInParams->nNumRefFrame : 1;
m_mfxEncParams.mfx.IdrInterval = pInParams->nIdrInterval;
if (m_mfxEncParams.mfx.RateControlMethod == MFX_RATECONTROL_CQP)
m_mfxEncParams.mfx.QPI = pInParams->nQPI;
m_mfxEncParams.mfx.QPP = pInParams->nQPP;
m_mfxEncParams.mfx.QPB = pInParams->nQPB;
else
m_mfxEncParams.mfx.TargetKbps = pInParams->nBitRate; // in Kbps
m_mfxEncParams.mfx.NumSlice = pInParams->nNumSlice;
ConvertFrameRate(pInParams->dFrameRate, &m_mfxEncParams.mfx.FrameInfo.FrameRateExtN, &m_mfxEncParams.mfx.FrameInfo.FrameRateExtD);
m_mfxEncParams.mfx.EncodedOrder = 0; // binary flag, 0 signals encoder to take frames in display order
// specify memory type
if (D3D9_MEMORY == pInParams->memType || D3D11_MEMORY == pInParams->memType)
m_mfxEncParams.IOPattern = MFX_IOPATTERN_IN_VIDEO_MEMORY;
else
m_mfxEncParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY;
// frame info parameters
m_mfxEncParams.mfx.FrameInfo.FourCC = MFX_FOURCC_NV12;
m_mfxEncParams.mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420;
m_mfxEncParams.mfx.FrameInfo.PicStruct = pInParams->nPicStruct;
// set frame size and crops
if(pInParams->CodecId==MFX_CODEC_HEVC && !memcmp(pInParams->pluginParams.pluginGuid.Data,MFX_PLUGINID_HEVCE_HW.Data,sizeof(MFX_PLUGINID_HEVCE_HW.Data)))
// In case of HW HEVC decoder width and height must be aligned to 32 pixels. This limitation is planned to be removed in later versions of plugin
m_mfxEncParams.mfx.FrameInfo.Width = MSDK_ALIGN32(pInParams->nDstWidth);
m_mfxEncParams.mfx.FrameInfo.Height = MSDK_ALIGN32(pInParams->nDstHeight);
else
// width must be a multiple of 16
// height must be a multiple of 16 in case of frame picture and a multiple of 32 in case of field picture
m_mfxEncParams.mfx.FrameInfo.Width = MSDK_ALIGN16(pInParams->nDstWidth);
m_mfxEncParams.mfx.FrameInfo.Height = (MFX_PICSTRUCT_PROGRESSIVE == m_mfxEncParams.mfx.FrameInfo.PicStruct)?
MSDK_ALIGN16(pInParams->nDstHeight) : MSDK_ALIGN32(pInParams->nDstHeight);
m_mfxEncParams.mfx.FrameInfo.CropX = 0;
m_mfxEncParams.mfx.FrameInfo.CropY = 0;
m_mfxEncParams.mfx.FrameInfo.CropW = pInParams->nDstWidth;
m_mfxEncParams.mfx.FrameInfo.CropH = pInParams->nDstHeight;
// we don't specify profile and level and let the encoder choose those basing on parameters
// we must specify profile only for MVC codec
if (MVC_ENABLED & m_MVCflags)
m_mfxEncParams.mfx.CodecProfile = MFX_PROFILE_AVC_STEREO_HIGH;
// configure and attach external parameters
if (MVC_ENABLED & pInParams->MVC_flags)
m_EncExtParams.push_back((mfxExtBuffer *)&m_MVCSeqDesc);
if (MVC_VIEWOUTPUT & pInParams->MVC_flags)
// ViewOuput option requested
m_CodingOption.ViewOutput = MFX_CODINGOPTION_ON;
m_EncExtParams.push_back((mfxExtBuffer *)&m_CodingOption);
// configure the depth of the look ahead BRC if specified in command line
if (pInParams->nLADepth || pInParams->nMaxSliceSize || pInParams->nBRefType)
m_CodingOption2.LookAheadDepth = pInParams->nLADepth;
m_CodingOption2.MaxSliceSize = pInParams->nMaxSliceSize;
m_CodingOption2.BRefType = pInParams->nBRefType;
m_EncExtParams.push_back((mfxExtBuffer *)&m_CodingOption2);
// In case of HEVC when height and/or width divided with 8 but not divided with 16
// add extended parameter to increase performance
if ( ( !((m_mfxEncParams.mfx.FrameInfo.CropW & 15 ) ^ 8 ) ||
!((m_mfxEncParams.mfx.FrameInfo.CropH & 15 ) ^ 8 ) ) &&
(m_mfxEncParams.mfx.CodecId == MFX_CODEC_HEVC) )
m_ExtHEVCParam.PicWidthInLumaSamples = m_mfxEncParams.mfx.FrameInfo.CropW;
m_ExtHEVCParam.PicHeightInLumaSamples = m_mfxEncParams.mfx.FrameInfo.CropH;
m_EncExtParams.push_back((mfxExtBuffer*)&m_ExtHEVCParam);
if (!m_EncExtParams.empty())
m_mfxEncParams.ExtParam = &m_EncExtParams[0]; // vector is stored linearly in memory
m_mfxEncParams.NumExtParam = (mfxU16)m_EncExtParams.size();
// JPEG encoder settings overlap with other encoders settings in mfxInfoMFX structure
if (MFX_CODEC_JPEG == pInParams->CodecId)
m_mfxEncParams.mfx.Interleaved = 1;
m_mfxEncParams.mfx.Quality = pInParams->nQuality;
m_mfxEncParams.mfx.RestartInterval = 0;
MSDK_ZERO_MEMORY(m_mfxEncParams.mfx.reserved5);
m_mfxEncParams.AsyncDepth = pInParams->nAsyncDepth;
mfxStatus CEncodingPipeline::InitMfxVppParams(sInputParams *pInParams)
MSDK_CHECK_POINTER(pInParams, MFX_ERR_NULL_PTR);
m_mfxVppParams.IOPattern = MFX_IOPATTERN_IN_VIDEO_MEMORY | MFX_IOPATTERN_OUT_VIDEO_MEMORY;
else
m_mfxVppParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY | MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
// input frame info
if (isV4L2InputEnabled)
m_mfxVppParams.vpp.In.FourCC = v4l2Pipeline.ConvertToMFXFourCC(pInParams->v4l2Format);
#else
m_mfxVppParams.vpp.In.FourCC = MFX_FOURCC_NV12;
#endif
m_mfxVppParams.vpp.In.PicStruct = pInParams->nPicStruct;;
ConvertFrameRate(pInParams->dFrameRate, &m_mfxVppParams.vpp.In.FrameRateExtN, &m_mfxVppParams.vpp.In.FrameRateExtD);
m_mfxVppParams.vpp.In.Width = MSDK_ALIGN16(pInParams->nWidth);
m_mfxVppParams.vpp.In.Height = (MFX_PICSTRUCT_PROGRESSIVE == m_mfxVppParams.vpp.In.PicStruct)?
MSDK_ALIGN16(pInParams->nHeight) : MSDK_ALIGN32(pInParams->nHeight);
// set crops in input mfxFrameInfo for correct work of file reader
// VPP itself ignores crops at initialization
m_mfxVppParams.vpp.In.CropW = pInParams->nWidth;
m_mfxVppParams.vpp.In.CropH = pInParams->nHeight;
// fill output frame info
MSDK_MEMCPY_VAR(m_mfxVppParams.vpp.Out,&m_mfxVppParams.vpp.In, sizeof(mfxFrameInfo));
m_mfxVppParams.vpp.Out.FourCC = MFX_FOURCC_NV12;
#endif
// only resizing is supported
m_mfxVppParams.vpp.Out.Width = MSDK_ALIGN16(pInParams->nDstWidth);
m_mfxVppParams.vpp.Out.Height = (MFX_PICSTRUCT_PROGRESSIVE == m_mfxVppParams.vpp.Out.PicStruct)?
AllocAndInitVppDoNotUse();
m_VppExtParams.push_back((mfxExtBuffer *)&m_VppDoNotUse);
m_VppExtParams.push_back((mfxExtBuffer *)&m_MVCSeqDesc);
m_mfxVppParams.ExtParam = &m_VppExtParams[0]; // vector is stored linearly in memory
m_mfxVppParams.NumExtParam = (mfxU16)m_VppExtParams.size();
m_mfxVppParams.AsyncDepth = pInParams->nAsyncDepth;
mfxStatus CEncodingPipeline::CreateHWDevice()
#if MFX_D3D11_SUPPORT
if (D3D11_MEMORY == m_memType)
m_hwdev = new CD3D11Device();
else
#endif // #if MFX_D3D11_SUPPORT
m_hwdev = new CD3D9Device();
if (NULL == m_hwdev)
return MFX_ERR_MEMORY_ALLOC;
sts = m_hwdev->Init(
NULL,
0,
MSDKAdapter::GetNumber(GetFirstSession()));
#elif LIBVA_SUPPORT
m_hwdev = CreateVAAPIDevice();
sts = m_hwdev->Init(NULL, 0, MSDKAdapter::GetNumber(GetFirstSession()));
#endif
mfxStatus CEncodingPipeline::ResetDevice()
if (D3D9_MEMORY == m_memType || D3D11_MEMORY == m_memType)
return m_hwdev->Reset();
mfxStatus CEncodingPipeline::AllocFrames()
MSDK_CHECK_POINTER(GetFirstEncoder(), MFX_ERR_NOT_INITIALIZED);
mfxFrameAllocRequest EncRequest;
mfxFrameAllocRequest VppRequest[2];
mfxU16 nEncSurfNum = 0; // number of surfaces for encoder
mfxU16 nVppSurfNum = 0; // number of surfaces for vpp
MSDK_ZERO_MEMORY(EncRequest);
MSDK_ZERO_MEMORY(VppRequest[0]);
MSDK_ZERO_MEMORY(VppRequest[1]);
// Calculate the number of surfaces for components.
// QueryIOSurf functions tell how many surfaces are required to produce at least 1 output.
// To achieve better performance we provide extra surfaces.
// 1 extra surface at input allows to get 1 extra output.
sts = GetFirstEncoder()->QueryIOSurf(&m_mfxEncParams, &EncRequest);
if (EncRequest.NumFrameSuggested < m_mfxEncParams.AsyncDepth)
// The number of surfaces shared by vpp output and encode input.
nEncSurfNum = EncRequest.NumFrameSuggested;
if (m_pmfxVPP)
// VppRequest[0] for input frames request, VppRequest[1] for output frames request
sts = m_pmfxVPP->QueryIOSurf(&m_mfxVppParams, VppRequest);
// The number of surfaces for vpp input - so that vpp can work at async depth = m_nAsyncDepth
nVppSurfNum = VppRequest[0].NumFrameSuggested;
// If surfaces are shared by 2 components, c1 and c2. NumSurf = c1_out + c2_in - AsyncDepth + 1
nEncSurfNum += nVppSurfNum - m_mfxEncParams.AsyncDepth + 1;
// prepare allocation requests
EncRequest.NumFrameSuggested = EncRequest.NumFrameMin = nEncSurfNum;
MSDK_MEMCPY_VAR(EncRequest.Info, &(m_mfxEncParams.mfx.FrameInfo), sizeof(mfxFrameInfo));
if (m_pmfxVPP)
EncRequest.Type |= MFX_MEMTYPE_FROM_VPPOUT; // surfaces are shared between vpp output and encode input
// alloc frames for encoder
sts = m_pMFXAllocator->Alloc(m_pMFXAllocator->pthis, &EncRequest, &m_EncResponse);
// alloc frames for vpp if vpp is enabled
if (m_pmfxVPP)
VppRequest[0].NumFrameSuggested = VppRequest[0].NumFrameMin = nVppSurfNum;
MSDK_MEMCPY_VAR(VppRequest[0].Info, &(m_mfxVppParams.mfx.FrameInfo), sizeof(mfxFrameInfo));
VppRequest[0].Type |= MFX_MEMTYPE_EXPORT_FRAME;
#endif
sts = m_pMFXAllocator->Alloc(m_pMFXAllocator->pthis, &(VppRequest[0]), &m_VppResponse);
// prepare mfxFrameSurface1 array for encoder
m_pEncSurfaces = new mfxFrameSurface1 [m_EncResponse.NumFrameActual];
MSDK_CHECK_POINTER(m_pEncSurfaces, MFX_ERR_MEMORY_ALLOC);
for (int i = 0; i < m_EncResponse.NumFrameActual; i++)
memset(&(m_pEncSurfaces), 0, sizeof(mfxFrameSurface1));
MSDK_MEMCPY_VAR(m_pEncSurfaces.Info, &(m_mfxEncParams.mfx.FrameInfo), sizeof(mfxFrameInfo));
if (m_bExternalAlloc)
m_pEncSurfaces.Data.MemId = m_EncResponse.mids;
else
// get YUV pointers
sts = m_pMFXAllocator->Lock(m_pMFXAllocator->pthis, m_EncResponse.mids, &(m_pEncSurfaces.Data));
// prepare mfxFrameSurface1 array for vpp if vpp is enabled
if (m_pmfxVPP)
m_pVppSurfaces = new mfxFrameSurface1 [m_VppResponse.NumFrameActual];
MSDK_CHECK_POINTER(m_pVppSurfaces, MFX_ERR_MEMORY_ALLOC);
for (int i = 0; i < m_VppResponse.NumFrameActual; i++)
MSDK_ZERO_MEMORY(m_pVppSurfaces);
MSDK_MEMCPY_VAR(m_pVppSurfaces.Info, &(m_mfxVppParams.mfx.FrameInfo), sizeof(mfxFrameInfo));
m_pVppSurfaces.Data.MemId = m_VppResponse.mids;
else
sts = m_pMFXAllocator->Lock(m_pMFXAllocator->pthis, m_VppResponse.mids, &(m_pVppSurfaces.Data));
mfxStatus CEncodingPipeline::CreateAllocator()
sts = CreateHWDevice();
mfxHDL hdl = NULL;
mfxHandleType hdl_t =
D3D11_MEMORY == m_memType ? MFX_HANDLE_D3D11_DEVICE :
MFX_HANDLE_D3D9_DEVICE_MANAGER;
sts = m_hwdev->GetHandle(hdl_t, &hdl);
// handle is needed for HW library only
mfxIMPL impl = 0;
m_mfxSession.QueryIMPL(&impl);
if (impl != MFX_IMPL_SOFTWARE)
sts = m_mfxSession.SetHandle(hdl_t, hdl);
// create D3D allocator
m_pMFXAllocator = new D3D11FrameAllocator;
MSDK_CHECK_POINTER(m_pMFXAllocator, MFX_ERR_MEMORY_ALLOC);
D3D11AllocatorParams *pd3dAllocParams = new D3D11AllocatorParams;
MSDK_CHECK_POINTER(pd3dAllocParams, MFX_ERR_MEMORY_ALLOC);
pd3dAllocParams->pDevice = reinterpret_cast<ID3D11Device *>(hdl);
m_pmfxAllocatorParams = pd3dAllocParams;
else
m_pMFXAllocator = new D3DFrameAllocator;
D3DAllocatorParams *pd3dAllocParams = new D3DAllocatorParams;
pd3dAllocParams->pManager = reinterpret_cast<IDirect3DDeviceManager9 *>(hdl);
/* In case of video memory we must provide MediaSDK with external allocator
thus we demonstrate "external allocator" usage model.
Call SetAllocator to pass allocator to Media SDK */
sts = m_mfxSession.SetFrameAllocator(m_pMFXAllocator);
m_bExternalAlloc = true;
#endif
/* It's possible to skip failed result here and switch to SW implementation,
but we don't process this way */
mfxHDL hdl = NULL;
sts = m_hwdev->GetHandle(MFX_HANDLE_VA_DISPLAY, &hdl);
// provide device manager to MediaSDK
sts = m_mfxSession.SetHandle(MFX_HANDLE_VA_DISPLAY, hdl);
// create VAAPI allocator
m_pMFXAllocator = new vaapiFrameAllocator;
vaapiAllocatorParams *p_vaapiAllocParams = new vaapiAllocatorParams;
MSDK_CHECK_POINTER(p_vaapiAllocParams, MFX_ERR_MEMORY_ALLOC);
p_vaapiAllocParams->m_dpy = (VADisplay)hdl;
m_pmfxAllocatorParams = p_vaapiAllocParams;
Call SetAllocator to pass allocator to mediasdk */
#endif
else
//in case of system memory allocator we also have to pass MFX_HANDLE_VA_DISPLAY to HW library
mfxIMPL impl;
if(MFX_IMPL_HARDWARE == MFX_IMPL_BASETYPE(impl))
mfxHDL hdl = NULL;
#endif
// create system memory allocator
m_pMFXAllocator = new SysMemFrameAllocator;
/* In case of system memory we demonstrate "no external allocator" usage model.
We don't call SetAllocator, Media SDK uses internal allocator.
We use system memory allocator simply as a memory manager for application*/
// initialize memory allocator
sts = m_pMFXAllocator->Init(m_pmfxAllocatorParams);
void CEncodingPipeline::DeleteFrames()
// delete surfaces array
MSDK_SAFE_DELETE_ARRAY(m_pEncSurfaces);
MSDK_SAFE_DELETE_ARRAY(m_pVppSurfaces);
// delete frames
if (m_pMFXAllocator)
m_pMFXAllocator->Free(m_pMFXAllocator->pthis, &m_EncResponse);
m_pMFXAllocator->Free(m_pMFXAllocator->pthis, &m_VppResponse);
void CEncodingPipeline::DeleteHWDevice()
MSDK_SAFE_DELETE(m_hwdev);
void CEncodingPipeline::DeleteAllocator()
// delete allocator
MSDK_SAFE_DELETE(m_pMFXAllocator);
MSDK_SAFE_DELETE(m_pmfxAllocatorParams);
DeleteHWDevice();
CEncodingPipeline::CEncodingPipeline()
m_pmfxENC = NULL;
m_pmfxVPP = NULL;
m_pMFXAllocator = NULL;
m_pmfxAllocatorParams = NULL;
m_memType = SYSTEM_MEMORY;
m_bExternalAlloc = false;
m_pEncSurfaces = NULL;
m_pVppSurfaces = NULL;
m_MVCflags = MVC_DISABLED;
m_nNumView = 0;
m_FileWriters.first = m_FileWriters.second = NULL;
MSDK_ZERO_MEMORY(m_MVCSeqDesc);
m_MVCSeqDesc.Header.BufferId = MFX_EXTBUFF_MVC_SEQ_DESC;
m_MVCSeqDesc.Header.BufferSz = sizeof(m_MVCSeqDesc);
MSDK_ZERO_MEMORY(m_VppDoNotUse);
m_VppDoNotUse.Header.BufferId = MFX_EXTBUFF_VPP_DONOTUSE;
m_VppDoNotUse.Header.BufferSz = sizeof(m_VppDoNotUse);
MSDK_ZERO_MEMORY(m_CodingOption);
m_CodingOption.Header.BufferId = MFX_EXTBUFF_CODING_OPTION;
m_CodingOption.Header.BufferSz = sizeof(m_CodingOption);
MSDK_ZERO_MEMORY(m_CodingOption2);
m_CodingOption2.Header.BufferId = MFX_EXTBUFF_CODING_OPTION2;
m_CodingOption2.Header.BufferSz = sizeof(m_CodingOption2);
MSDK_ZERO_MEMORY(m_ExtHEVCParam);
m_ExtHEVCParam.Header.BufferId = MFX_EXTBUFF_HEVC_PARAM;
m_ExtHEVCParam.Header.BufferSz = sizeof(m_ExtHEVCParam);
m_hwdev = NULL;
#endif
MSDK_ZERO_MEMORY(m_mfxEncParams);
MSDK_ZERO_MEMORY(m_mfxVppParams);
MSDK_ZERO_MEMORY(m_EncResponse);
MSDK_ZERO_MEMORY(m_VppResponse);
isV4L2InputEnabled = false;
m_nFramesToProcess = 0;
CEncodingPipeline::~CEncodingPipeline()
Close();
void CEncodingPipeline::SetMultiView()
m_FileReader.SetMultiView();
mfxStatus CEncodingPipeline::InitFileWriter(CSmplBitstreamWriter **ppWriter, const msdk_char *filename)
MSDK_CHECK_ERROR(ppWriter, NULL, MFX_ERR_NULL_PTR);
MSDK_SAFE_DELETE(*ppWriter);
*ppWriter = new CSmplBitstreamWriter;
MSDK_CHECK_POINTER(*ppWriter, MFX_ERR_MEMORY_ALLOC);
mfxStatus sts = (*ppWriter)->Init(filename);
return sts;
mfxStatus CEncodingPipeline::InitFileWriters(sInputParams *pParams)
MSDK_CHECK_POINTER(pParams, MFX_ERR_NULL_PTR);
// prepare output file writers
// ViewOutput mode: output in single bitstream
if ( (MVC_VIEWOUTPUT & pParams->MVC_flags) && (pParams->dstFileBuff.size() <= 1))
sts = InitFileWriter(&m_FileWriters.first, pParams->dstFileBuff[0]);
m_FileWriters.second = m_FileWriters.first;
// ViewOutput mode: 2 bitstreams in separate files
else if ( (MVC_VIEWOUTPUT & pParams->MVC_flags) && (pParams->dstFileBuff.size() <= 2))
sts = InitFileWriter(&m_FileWriters.second, pParams->dstFileBuff[1]);
// ViewOutput mode: 3 bitstreams - 2 separate & 1 merged
else if ( (MVC_VIEWOUTPUT & pParams->MVC_flags) && (pParams->dstFileBuff.size() <= 3))
std::auto_ptr<CSmplBitstreamDuplicateWriter> first(new CSmplBitstreamDuplicateWriter);
// init first duplicate writer
MSDK_CHECK_POINTER(first.get(), MFX_ERR_MEMORY_ALLOC);
sts = first->Init(pParams->dstFileBuff[0]);
sts = first->InitDuplicate(pParams->dstFileBuff[2]);
// init second duplicate writer
std::auto_ptr<CSmplBitstreamDuplicateWriter> second(new CSmplBitstreamDuplicateWriter);
MSDK_CHECK_POINTER(second.get(), MFX_ERR_MEMORY_ALLOC);
sts = second->Init(pParams->dstFileBuff[1]);
sts = second->JoinDuplicate(first.get());
m_FileWriters.first = first.release();
m_FileWriters.second = second.release();
// not ViewOutput mode
else
return sts;
mfxStatus CEncodingPipeline::Init(sInputParams *pParams)
#if defined ENABLE_V4L2_SUPPORT
isV4L2InputEnabled = pParams->isV4L2InputEnabled;
#endif
if (!isV4L2InputEnabled)
// prepare input file reader
sts = m_FileReader.Init(pParams->strSrcFile,
pParams->ColorFormat,
pParams->numViews,
pParams->srcFileBuff);
m_MVCflags = pParams->MVC_flags;
sts = InitFileWriters(pParams);
mfxInitParam initPar;
mfxVersion version; // real API version with which library is initialized
MSDK_ZERO_MEMORY(initPar);
// we set version to 1.0 and later we will query actual version of the library which will got leaded
initPar.Version.Major = 1;
initPar.Version.Minor = 0;
initPar.GPUCopy = pParams->gpuCopy;
// Init session
if (pParams->bUseHWLib) {
// try searching on all display adapters
initPar.Implementation = MFX_IMPL_HARDWARE_ANY;
// if d3d11 surfaces are used ask the library to run acceleration through D3D11
// feature may be unsupported due to OS or MSDK API version
if (D3D11_MEMORY == pParams->memType)
initPar.Implementation |= MFX_IMPL_VIA_D3D11;
sts = m_mfxSession.InitEx(initPar);
// MSDK API version may not support multiple adapters - then try initialize on the default
if (MFX_ERR_NONE != sts) {
initPar.Implementation = (initPar.Implementation & !MFX_IMPL_HARDWARE_ANY) | MFX_IMPL_HARDWARE;
} else {
initPar.Implementation = MFX_IMPL_SOFTWARE;
sts = MFXQueryVersion(m_mfxSession , &version); // get real API version of the loaded library
if ((pParams->MVC_flags & MVC_ENABLED) != 0 && !CheckVersion(&version, MSDK_FEATURE_MVC)) {
msdk_printf(MSDK_STRING("error: MVC is not supported in the %d.%d API version\n"),
version.Major, version.Minor);
return MFX_ERR_UNSUPPORTED;
if ((pParams->MVC_flags & MVC_VIEWOUTPUT) != 0 && !CheckVersion(&version, MSDK_FEATURE_MVC_VIEWOUTPUT)) {
msdk_printf(MSDK_STRING("error: MVC Viewoutput is not supported in the %d.%d API version\n"),
if ((pParams->CodecId == MFX_CODEC_JPEG) && !CheckVersion(&version, MSDK_FEATURE_JPEG_ENCODE)) {
msdk_printf(MSDK_STRING("error: Jpeg is not supported in the %d.%d API version\n"),
if ((pParams->nRateControlMethod == MFX_RATECONTROL_LA) && !CheckVersion(&version, MSDK_FEATURE_LOOK_AHEAD)) {
msdk_printf(MSDK_STRING("error: Look ahead is not supported in the %d.%d API version\n"),
if (CheckVersion(&version, MSDK_FEATURE_PLUGIN_API)) {
/* Here we actually define the following codec initialization scheme:
* 1. If plugin path or guid is specified: we load user-defined plugin (example: HEVC encoder plugin)
* 2. If plugin path not specified:
* 2.a) we check if codec is distributed as a mediasdk plugin and load it if yes
* 2.b) if codec is not in the list of mediasdk plugins, we assume, that it is supported inside mediasdk library
if (pParams->pluginParams.type == MFX_PLUGINLOAD_TYPE_FILE && msdk_strnlen(pParams->pluginParams.strPluginPath,sizeof(pParams->pluginParams.strPluginPath)))
m_pUserModule.reset(new MFXVideoUSER(m_mfxSession));
m_pPlugin.reset(LoadPlugin(MFX_PLUGINTYPE_VIDEO_ENCODE, m_mfxSession, pParams->pluginParams.pluginGuid, 1, pParams->pluginParams.strPluginPath, (mfxU32)msdk_strnlen(pParams->pluginParams.strPluginPath,sizeof(pParams->pluginParams.strPluginPath))));
if (m_pPlugin.get() == NULL) sts = MFX_ERR_UNSUPPORTED;
else
if (AreGuidsEqual(pParams->pluginParams.pluginGuid, MSDK_PLUGINGUID_NULL))
mfxIMPL impl = pParams->bUseHWLib ? MFX_IMPL_HARDWARE : MFX_IMPL_SOFTWARE;
pParams->pluginParams.pluginGuid = msdkGetPluginUID(impl, MSDK_VENCODE, pParams->CodecId);
if (!AreGuidsEqual(pParams->pluginParams.pluginGuid, MSDK_PLUGINGUID_NULL))
m_pPlugin.reset(LoadPlugin(MFX_PLUGINTYPE_VIDEO_ENCODE, m_mfxSession, pParams->pluginParams.pluginGuid, 1));
if(sts==MFX_ERR_UNSUPPORTED)
msdk_printf(MSDK_STRING("Default plugin cannot be loaded (possibly you have to define plugin explicitly)\n"));
// set memory type
m_memType = pParams->memType;
// create and init frame allocator
sts = CreateAllocator();
sts = InitMfxEncParams(pParams);
sts = InitMfxVppParams(pParams);
// MVC specific options
sts = AllocAndInitMVCSeqDesc();
// create encoder
m_pmfxENC = new MFXVideoENCODE(m_mfxSession);
MSDK_CHECK_POINTER(m_pmfxENC, MFX_ERR_MEMORY_ALLOC);
// create preprocessor if resizing was requested from command line
// or if different FourCC is set in InitMfxVppParams
if (pParams->nWidth != pParams->nDstWidth ||
pParams->nHeight != pParams->nDstHeight ||
m_mfxVppParams.vpp.In.FourCC != m_mfxVppParams.vpp.Out.FourCC)
m_pmfxVPP = new MFXVideoVPP(m_mfxSession);
MSDK_CHECK_POINTER(m_pmfxVPP, MFX_ERR_MEMORY_ALLOC);
sts = ResetMFXComponents(pParams);
InitV4L2Pipeline(pParams);
m_nFramesToProcess = pParams->nNumFrames;
void CEncodingPipeline::InitV4L2Pipeline(sInputParams *pParams)
int i;
v4l2Pipeline.Init(pParams->DeviceName,
pParams->nWidth, pParams->nHeight,
m_VppResponse.NumFrameActual,
pParams->v4l2Format,
pParams->MipiMode,
pParams->MipiPort);
v4l2Pipeline.V4L2Alloc();
for(i=0; i<m_VppResponse.NumFrameActual; i++)
buffers.index = i;
struct vaapiMemId *vaapi = (struct vaapiMemId *)m_pVppSurfaces.Data.MemId;
buffers.fd = vaapi->m_buffer_info.handle;
v4l2Pipeline.V4L2QueueBuffer(&buffers);
#endif
mfxStatus CEncodingPipeline::CaptureStartV4L2Pipeline()
v4l2Pipeline.V4L2StartCapture();
v4l2Device *m_v4l2Display = &v4l2Pipeline;
if (pthread_create(&m_PollThread, NULL, PollingThread, (void *)m_v4l2Display))
msdk_printf(MSDK_STRING("Couldn't create v4l2 polling thread\n"));
return MFX_ERR_UNKNOWN;
#endif
void CEncodingPipeline::CaptureStopV4L2Pipeline()
pthread_join(m_PollThread, NULL);
v4l2Pipeline.V4L2StopCapture();
#endif
void CEncodingPipeline::Close()
if (m_FileWriters.first)
msdk_printf(MSDK_STRING("Frame number: %u\r\n"), m_FileWriters.first->m_nProcessedFramesNum);
#ifdef TIME_STATS
mfxF64 ProcDeltaTime = m_statOverall.GetDeltaTime() - m_statFile.GetDeltaTime() - m_TaskPool.GetFileStatistics().GetDeltaTime();
msdk_printf(MSDK_STRING("Encoding fps: %.0f"), m_FileWriters.first->m_nProcessedFramesNum / ProcDeltaTime);
#endif
MSDK_SAFE_DELETE(m_pmfxENC);
MSDK_SAFE_DELETE(m_pmfxVPP);
FreeMVCSeqDesc();
FreeVppDoNotUse();
DeleteFrames();
m_pPlugin.reset();
m_TaskPool.Close();
m_mfxSession.Close();
m_FileReader.Close();
FreeFileWriters();
// allocator if used as external for MediaSDK must be deleted after SDK components
DeleteAllocator();
void CEncodingPipeline::FreeFileWriters()
if (m_FileWriters.second == m_FileWriters.first)
m_FileWriters.second = NULL; // second do not own the writer - just forget pointer
m_FileWriters.first->Close();
MSDK_SAFE_DELETE(m_FileWriters.first);
if (m_FileWriters.second)
m_FileWriters.second->Close();
MSDK_SAFE_DELETE(m_FileWriters.second);
mfxStatus CEncodingPipeline::ResetMFXComponents(sInputParams* pParams)
MSDK_CHECK_POINTER(m_pmfxENC, MFX_ERR_NOT_INITIALIZED);
sts = m_pmfxENC->Close();
MSDK_IGNORE_MFX_STS(sts, MFX_ERR_NOT_INITIALIZED);
if (m_pmfxVPP)
sts = m_pmfxVPP->Close();
// free allocated frames
DeleteFrames();
m_TaskPool.Close();
sts = AllocFrames();
sts = m_pmfxENC->Init(&m_mfxEncParams);
if (MFX_WRN_PARTIAL_ACCELERATION == sts)
msdk_printf(MSDK_STRING("WARNING: partial acceleration\n"));
MSDK_IGNORE_MFX_STS(sts, MFX_WRN_PARTIAL_ACCELERATION);
if (m_pmfxVPP)
sts = m_pmfxVPP->Init(&m_mfxVppParams);
mfxU32 nEncodedDataBufferSize = m_mfxEncParams.mfx.FrameInfo.Width * m_mfxEncParams.mfx.FrameInfo.Height * 4;
sts = m_TaskPool.Init(&m_mfxSession, m_FileWriters.first, m_mfxEncParams.AsyncDepth, nEncodedDataBufferSize, m_FileWriters.second);
mfxStatus CEncodingPipeline::AllocateSufficientBuffer(mfxBitstream* pBS)
MSDK_CHECK_POINTER(pBS, MFX_ERR_NULL_PTR);
mfxVideoParam par;
MSDK_ZERO_MEMORY(par);
// find out the required buffer size
mfxStatus sts = GetFirstEncoder()->GetVideoParam(&par);
// reallocate bigger buffer for output
sts = ExtendMfxBitstream(pBS, par.mfx.BufferSizeInKB * 1000);
MSDK_CHECK_RESULT_SAFE(sts, MFX_ERR_NONE, sts, WipeMfxBitstream(pBS));
mfxStatus CEncodingPipeline::GetFreeTask(sTask **ppTask)
sts = m_TaskPool.GetFreeTask(ppTask);
if (MFX_ERR_NOT_FOUND == sts)
sts = m_TaskPool.SynchronizeFirstTask();
// try again
return sts;
int64_t timstmp = 1;
mfxStatus CEncodingPipeline::Run()
mfxFrameSurface1* pSurf = NULL; // dispatching pointer
sTask *pCurrentTask = NULL; // a pointer to the current task
mfxU16 nEncSurfIdx = 0; // index of free surface for encoder input (vpp output)
mfxU16 nVppSurfIdx = 0; // index of free surface for vpp input
mfxSyncPoint VppSyncPoint = NULL; // a sync point associated with an asynchronous vpp call
bool bVppMultipleOutput = false; // this flag is true if VPP produces more frames at output
// than consumes at input. E.g. framerate conversion 30 fps -> 60 fps
// Since in sample we support just 2 views
// we will change this value between 0 and 1 in case of MVC
mfxU16 currViewNum = 0;
mfxU32 nFramesProcessed = 0;
sts = MFX_ERR_NONE;
msdk_printf(MSDK_STRING("Press Ctrl+C to terminate this application\n"));
#endif
// main loop, preprocessing and encoding
while (MFX_ERR_NONE <= sts || MFX_ERR_MORE_DATA == sts)
if ((m_nFramesToProcess != 0) && (nFramesProcessed == m_nFramesToProcess))
break;
if (v4l2Pipeline.GetV4L2TerminationSignal() && isV4L2InputEnabled)
break;
#endif
// get a pointer to a free task (bit stream and sync point for encoder)
sts = GetFreeTask(&pCurrentTask);
MSDK_BREAK_ON_ERROR(sts);
// find free surface for encoder input
nEncSurfIdx = GetFreeSurface(m_pEncSurfaces, m_EncResponse.NumFrameActual);
MSDK_CHECK_ERROR(nEncSurfIdx, MSDK_INVALID_SURF_IDX, MFX_ERR_MEMORY_ALLOC);
// point pSurf to encoder surface
pSurf = &m_pEncSurfaces[nEncSurfIdx];
if (!bVppMultipleOutput)
// if vpp is enabled find free surface for vpp input and point pSurf to vpp surface
if (m_pmfxVPP)
nVppSurfIdx = v4l2Pipeline.GetOffQ();
#else
nVppSurfIdx = GetFreeSurface(m_pVppSurfaces, m_VppResponse.NumFrameActual);
MSDK_CHECK_ERROR(nVppSurfIdx, MSDK_INVALID_SURF_IDX, MFX_ERR_MEMORY_ALLOC);
#endif
pSurf = &m_pVppSurfaces[nVppSurfIdx];
// load frame from file to surface data
// if we share allocator with Media SDK we need to call Lock to access surface data and...
// get YUV pointers
sts = m_pMFXAllocator->Lock(m_pMFXAllocator->pthis, pSurf->Data.MemId, &(pSurf->Data));
pSurf->Info.FrameId.ViewId = currViewNum;
sts = m_FileReader.LoadNextFrame(pSurf);
pSurf->Data.TimeStamp =timstmp++ * 90000; // for test
printf("in: tm %d\n",pSurf->Data.TimeStamp);
if (MVC_ENABLED & m_MVCflags) currViewNum ^= 1; // Flip between 0 and 1 for ViewId
// ... after we're done call Unlock
sts = m_pMFXAllocator->Unlock(m_pMFXAllocator->pthis, pSurf->Data.MemId, &(pSurf->Data));
// perform preprocessing if required
if (m_pmfxVPP)
bVppMultipleOutput = false; // reset the flag before a call to VPP
for (;;)
sts = m_pmfxVPP->RunFrameVPPAsync(&m_pVppSurfaces[nVppSurfIdx], &m_pEncSurfaces[nEncSurfIdx],
NULL, &VppSyncPoint);
if (MFX_ERR_NONE < sts && !VppSyncPoint) // repeat the call if warning and no output
if (MFX_WRN_DEVICE_BUSY == sts)
MSDK_SLEEP(1); // wait if device is busy
else if (MFX_ERR_NONE < sts && VppSyncPoint)
sts = MFX_ERR_NONE; // ignore warnings if output is available
break;
else
break; // not a warning
// process errors
if (MFX_ERR_MORE_DATA == sts)
continue;
else if (MFX_ERR_MORE_SURFACE == sts)
bVppMultipleOutput = true;
else
// save the id of preceding vpp task which will produce input data for the encode task
if (VppSyncPoint)
pCurrentTask->DependentVppTasks.push_back(VppSyncPoint);
for (;;)
// at this point surface for encoder contains either a frame from file or a frame processed by vpp
sts = m_pmfxENC->EncodeFrameAsync(NULL, &m_pEncSurfaces[nEncSurfIdx], &pCurrentTask->mfxBS, &pCurrentTask->EncSyncP);
if (MFX_ERR_NONE < sts && !pCurrentTask->EncSyncP) // repeat the call if warning and no output
else if (MFX_ERR_NONE < sts && pCurrentTask->EncSyncP)
break;
else if (MFX_ERR_NOT_ENOUGH_BUFFER == sts)
sts = AllocateSufficientBuffer(&pCurrentTask->mfxBS);
else
// get next surface and new task for 2nd bitstream in ViewOutput mode
MSDK_IGNORE_MFX_STS(sts, MFX_ERR_MORE_BITSTREAM);
break;
nFramesProcessed++;
// means that the input file has ended, need to go to buffering loops
MSDK_IGNORE_MFX_STS(sts, MFX_ERR_MORE_DATA);
// exit in case of other errors
if (m_pmfxVPP)
// loop to get buffered frames from vpp
while (MFX_ERR_NONE <= sts || MFX_ERR_MORE_DATA == sts || MFX_ERR_MORE_SURFACE == sts)
// MFX_ERR_MORE_SURFACE can be returned only by RunFrameVPPAsync
// MFX_ERR_MORE_DATA is accepted only from EncodeFrameAsync
// find free surface for encoder input (vpp output)
for (;;)
sts = m_pmfxVPP->RunFrameVPPAsync(NULL, &m_pEncSurfaces[nEncSurfIdx], NULL, &VppSyncPoint);
break;
else
continue;
else
// get a free task (bit stream and sync point for encoder)
if (VppSyncPoint)
for (;;)
break;
else
break;
// MFX_ERR_MORE_DATA is the correct status to exit buffering loop with
// indicates that there are no more buffered frames
// loop to get buffered frames from encoder
while (MFX_ERR_NONE <= sts)
for (;;)
sts = m_pmfxENC->EncodeFrameAsync(NULL, NULL, &pCurrentTask->mfxBS, &pCurrentTask->EncSyncP);
break;
else
// get new task for 2nd bitstream in ViewOutput mode
break;
// synchronize all tasks that are left in task pool
while (MFX_ERR_NONE == sts)
// MFX_ERR_NOT_FOUND is the correct status to exit the loop with
// EncodeFrameAsync and SyncOperation don't return this status
MSDK_IGNORE_MFX_STS(sts, MFX_ERR_NOT_FOUND);
// report any errors that occurred in asynchronous part
return sts;
void CEncodingPipeline::PrintInfo()
msdk_printf(MSDK_STRING("Encoding Sample Version %s\n"), MSDK_SAMPLE_VERSION);
msdk_printf(MSDK_STRING("\nInput file format\t%s\n"), ColorFormatToStr(m_FileReader.m_ColorFormat));
msdk_printf(MSDK_STRING("Output video\t\t%s\n"), CodecIdToStr(m_mfxEncParams.mfx.CodecId).c_str());
mfxFrameInfo SrcPicInfo = m_mfxVppParams.vpp.In;
mfxFrameInfo DstPicInfo = m_mfxEncParams.mfx.FrameInfo;
msdk_printf(MSDK_STRING("Source picture:\n"));
msdk_printf(MSDK_STRING("\tResolution\t%dx%d\n"), SrcPicInfo.Width, SrcPicInfo.Height);
msdk_printf(MSDK_STRING("\tCrop X,Y,W,H\t%d,%d,%d,%d\n"), SrcPicInfo.CropX, SrcPicInfo.CropY, SrcPicInfo.CropW, SrcPicInfo.CropH);
msdk_printf(MSDK_STRING("Destination picture:\n"));
msdk_printf(MSDK_STRING("\tResolution\t%dx%d\n"), DstPicInfo.Width, DstPicInfo.Height);
msdk_printf(MSDK_STRING("\tCrop X,Y,W,H\t%d,%d,%d,%d\n"), DstPicInfo.CropX, DstPicInfo.CropY, DstPicInfo.CropW, DstPicInfo.CropH);
msdk_printf(MSDK_STRING("Frame rate\t%.2f\n"), DstPicInfo.FrameRateExtN * 1.0 / DstPicInfo.FrameRateExtD);
if (m_mfxEncParams.mfx.RateControlMethod != MFX_RATECONTROL_CQP)
msdk_printf(MSDK_STRING("Bit rate(Kbps)\t%d\n"), m_mfxEncParams.mfx.TargetKbps);
else
msdk_printf(MSDK_STRING("QPI\t%d\nQPP\t%d\nQPB\t%d\n"), m_mfxEncParams.mfx.QPI, m_mfxEncParams.mfx.QPP, m_mfxEncParams.mfx.QPB);
msdk_printf(MSDK_STRING("Gop size\t%d\n"), m_mfxEncParams.mfx.GopPicSize);
msdk_printf(MSDK_STRING("Ref dist\t%d\n"), m_mfxEncParams.mfx.GopRefDist);
msdk_printf(MSDK_STRING("Ref number\t%d\n"), m_mfxEncParams.mfx.NumRefFrame);
msdk_printf(MSDK_STRING("Idr Interval\t%d\n"), m_mfxEncParams.mfx.IdrInterval);
msdk_printf(MSDK_STRING("Target usage\t%s\n"), TargetUsageToStr(m_mfxEncParams.mfx.TargetUsage));
const msdk_char* sMemType =
#if defined(_WIN32) || defined(_WIN64)
m_memType == D3D9_MEMORY ? MSDK_STRING("d3d")
#else
m_memType == D3D9_MEMORY ? MSDK_STRING("vaapi")
#endif
: (m_memType == D3D11_MEMORY ? MSDK_STRING("d3d11")
: MSDK_STRING("system"));
msdk_printf(MSDK_STRING("Memory type\t%s\n"), sMemType);
mfxIMPL impl;
GetFirstSession().QueryIMPL(&impl);
const msdk_char* sImpl = (MFX_IMPL_VIA_D3D11 == MFX_IMPL_VIA_MASK(impl)) ? MSDK_STRING("hw_d3d11")
: (MFX_IMPL_HARDWARE & impl) ? MSDK_STRING("hw")
: MSDK_STRING("sw");
msdk_printf(MSDK_STRING("Media SDK impl\t\t%s\n"), sImpl);
mfxVersion ver;
GetFirstSession().QueryVersion(&ver);
msdk_printf(MSDK_STRING("Media SDK version\t%d.%d\n"), ver.Major, ver.Minor);
msdk_printf(MSDK_STRING("\n"));
what is wrong with me?
how can i solve it?
console output content is:
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Encoding Sample Version 0.0.000.0000
Input file format YUV420
Output video AVC
Source picture:
Resolution 1920x1088
Crop X,Y,W,H 0,0,1920,1080
Frame rate 30.00
Bit rate(Kbps) 3757
Gop size 0
Ref dist 0
Ref number 1
Idr Interval 0
Target usage balanced
Memory type system
Media SDK impl hw
Media SDK version 1.19
Processing started
in: tm 90000
in: tm 180000
in: tm 270000
in: tm 360000
in: tm 450000
in: tm 540000
in: tm 630000
out pts: 90000 87000
in: tm 720000 1
out pts: 360000 351000
in: tm 810000
out pts: 180000 180000
in: tm 900000
out pts: 270000 270000
in: tm 990000
out pts: 630000 621000
in: tm 1080000
out pts: 450000 450000
in: tm 1170000
out pts: 540000 540000
in: tm 1260000
out pts: 900000 891000
in: tm 1350000
out pts: 720000 720000
in: tm 1440000
out pts: 810000 810000
in: tm 1530000
out pts: 1170000 1161000
in: tm 1620000
out pts: 990000 990000
in: tm 1710000
out pts: 1080000 1080000
in: tm 1800000
out pts: 1440000 1431000
in: tm 1890000
out pts: 1260000 1260000
in: tm 1980000
out pts: 1350000 1350000
in: tm 2070000
out pts: 1710000 1701000
in: tm 2160000
out pts: 1530000 1530000
in: tm 2250000
out pts: 1620000 1620000
in: tm 2340000
out pts: 1980000 1971000
in: tm 2430000
out pts: 1800000 1800000
in: tm 2520000
out pts: 1890000 1890000
in: tm 2610000
out pts: 2250000 2241000
in: tm 2700000
out pts: 2070000 2070000
in: tm 2790000
out pts: 2160000 2160000
in: tm 2880000
out pts: 2520000 2511000
in: tm 2970000
out pts: 2340000 2340000
in: tm 3060000
out pts: 2430000 2430000
in: tm 3150000
out pts: 2790000 2781000
in: tm 3240000
out pts: 2610000 2610000
in: tm 3330000
out pts: 2700000 2700000
in: tm 3420000
out pts: 3060000 3051000
in: tm 3510000
out pts: 2880000 2880000
in: tm 3600000
out pts: 2970000 2970000
in: tm 3690000
out pts: 3330000 3321000
in: tm 3780000
out pts: 3150000 3150000
in: tm 3870000
out pts: 3240000 3240000
in: tm 3960000
out pts: 3600000 3591000
in: tm 4050000
out pts: 3420000 3420000
in: tm 4140000
out pts: 3510000 3510000
in: tm 4230000
out pts: 3870000 3861000
in: tm 4320000
out pts: 3690000 3690000
in: tm 4410000
out pts: 3780000 3780000
in: tm 4500000
out pts: 4140000 4131000
in: tm 4590000
out pts: 3960000 3960000
in: tm 4680000
out pts: 4050000 4050000
in: tm 4770000
out pts: 4410000 4401000
in: tm 4860000
out pts: 4230000 4230000
in: tm 4950000
out pts: 4320000 4320000
in: tm 5040000
out pts: 4680000 4671000
in: tm 5130000
out pts: 4500000 4500000
in: tm 5220000
out pts: 4590000 4590000
in: tm 5310000
out pts: 4950000 4941000
in: tm 5400000
Can you read the following post to see if it solved your question:
https://software.intel.com/en-us/forums/intel-media-sdk/topic/311726
Mark
Mark
it's useless for me. my question is output's TimeStamp and DecodeTimeStamp are both non-monotonic
whatever encode order or display order, must hava one monotonic.
sorry for my English, its not my mother language.
Yes, I think this should be fine as long as the output can be played in the correct order.
The Media SDK is an asynchronized framework, each frame will be running in parallel when processing, so they are not guarantee to finish in the order as they read from the file.
Mark
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
