Intel OneVPL version: 2023.0.0
Windows10
Visual Studio 2022
I'm developing app based on sample_decode.
My app receives AVC/HEVC stream, then split it into GOP units, and put them into CDecodingPipeline::RunDecoding().
Once I got MFX_ERR_MORE_DATA, put another GOP as so on.
HW decoder works fine, but SW decoder does not decode any frame and return MFX_ERR_MORE_DATA on 2nd call and results MFX_ERR_ABORTED on 3rd call.
How can I work around this error?
I modified sample_decode so that this situation can be reproduced.
- HW codec works fine
Warning - unable to create logfile C:\onevpldispatcher.log Log output will be sent to stdout function: MFXCreateConfig (enter) function: LoaderCtxVPL::AddConfigFilter (enter) function: LoaderCtxVPL::AddConfigFilter (return) function: MFXCreateConfig (return) function: MFXSetConfigFilterProperty (enter) function: MFXSetConfigFilterProperty (return) CONFIGURE LOADER: required implementation: hw function: MFXCreateConfig (enter) function: LoaderCtxVPL::AddConfigFilter (enter) function: LoaderCtxVPL::AddConfigFilter (return) function: MFXCreateConfig (return) function: MFXSetConfigFilterProperty (enter) function: MFXSetConfigFilterProperty (return) CONFIGURE LOADER: required implementation mfxAccelerationMode: MFX_ACCEL_MODE_VIA_D3D11 CONFIGURE LOADER: Use dispatcher's low-latency mode function: MFXCreateConfig (enter) function: LoaderCtxVPL::AddConfigFilter (enter) function: LoaderCtxVPL::AddConfigFilter (return) function: MFXCreateConfig (return) function: MFXSetConfigFilterProperty (enter) function: MFXSetConfigFilterProperty (return) function: MFXCreateConfig (enter) function: LoaderCtxVPL::AddConfigFilter (enter) function: LoaderCtxVPL::AddConfigFilter (return) function: MFXCreateConfig (return) function: MFXSetConfigFilterProperty (enter) function: MFXSetConfigFilterProperty (return) function: MFXCreateConfig (enter) function: LoaderCtxVPL::AddConfigFilter (enter) function: LoaderCtxVPL::AddConfigFilter (return) function: MFXCreateConfig (return) function: MFXSetConfigFilterProperty (enter) function: MFXSetConfigFilterProperty (return) function: MFXCreateSession (enter) message: low latency mode enabled function: LoaderCtxVPL::LoadLibsLowLatency (enter) function: LoaderCtxVPL::LoadLibsLowLatency (return) function: LoaderCtxVPL::QueryLibraryCaps (enter) function: LoaderCtxVPL::QueryLibraryCaps (return) function: LoaderCtxVPL::CreateSession (enter) function: LoaderCtxVPL::CreateSession (return) function: MFXCreateSession (return) Loaded Library configuration: Version: 1.0 ImplName: mfx-gen Adapter number : 0 Adapter type: integrated Loaded module path: C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_9671054d3bbcb1b5\libmfxhw64.dll pretending that aspect ratio is 1:1 Decoding Sample Version 8.4.27.0 Input video AVC Output format NV12 Input: Resolution 1280x960 Crop X,Y,W,H 0,0,1280,960 Output: Resolution 1280x960 Frame rate 1.00 Memory type system MediaSDK impl hw_d3d11 MediaSDK version 1.35 Decoding started Frame number: 150, fps: 131.517, fread_fps: 0.000, fwrite_fps: 233.132 [sk] call m_FileReader->Reset() Frame number: 300, fps: 153.265, fread_fps: 0.000, fwrite_fps: 214.777 [sk] call m_FileReader->Reset() Frame number: 450, fps: 183.200, fread_fps: 0.000, fwrite_fps: 245.750 [sk] call m_FileReader->Reset() Decoding finished function: LoaderCtxVPL::UnloadAllLibraries (enter) function: LoaderCtxVPL::UnloadAllLibraries (return) function: LoaderCtxVPL::FreeConfigFilters (enter) function: LoaderCtxVPL::FreeConfigFilters (return)
- SW codec fails with MFX_ERR_ABORTED
Warning - unable to create logfile C:\onevpldispatcher.log Log output will be sent to stdout function: MFXCreateConfig (enter) function: LoaderCtxVPL::AddConfigFilter (enter) function: LoaderCtxVPL::AddConfigFilter (return) function: MFXCreateConfig (return) function: MFXSetConfigFilterProperty (enter) function: MFXSetConfigFilterProperty (return) CONFIGURE LOADER: required implementation: sw function: MFXCreateConfig (enter) function: LoaderCtxVPL::AddConfigFilter (enter) function: LoaderCtxVPL::AddConfigFilter (return) function: MFXCreateConfig (return) function: MFXSetConfigFilterProperty (enter) function: MFXSetConfigFilterProperty (return) CONFIGURE LOADER: required implementation mfxAccelerationMode: MFX_ACCEL_MODE_NA function: MFXEnumImplementations (enter) function: LoaderCtxVPL::BuildListOfCandidateLibs (enter) function: LoaderCtxVPL::BuildListOfCandidateLibs (return) function: LoaderCtxVPL::CheckValidLibraries (enter) function: LoaderCtxVPL::CheckValidLibraries (return) function: LoaderCtxVPL::QueryLibraryCaps (enter) function: LoaderCtxVPL::PrioritizeImplList (enter) function: LoaderCtxVPL::PrioritizeImplList (return) function: LoaderCtxVPL::QueryLibraryCaps (return) function: LoaderCtxVPL::UpdateValidImplList (enter) function: LoaderCtxVPL::PrioritizeImplList (enter) function: LoaderCtxVPL::PrioritizeImplList (return) function: LoaderCtxVPL::UpdateValidImplList (return) function: LoaderCtxVPL::QueryImpl (enter) function: LoaderCtxVPL::QueryImpl (return) function: MFXEnumImplementations (return) function: MFXEnumImplementations (enter) function: LoaderCtxVPL::QueryImpl (enter) function: LoaderCtxVPL::QueryImpl (return) function: MFXEnumImplementations (return) function: MFXCreateSession (enter) message: low latency mode disabled function: LoaderCtxVPL::CreateSession (enter) function: LoaderCtxVPL::CreateSession (return) function: MFXCreateSession (return) Loaded Library configuration: Version: 2.7 ImplName: oneAPI VPL CPU Implementation Adapter number : -1 Loaded module path: C:\Program Files (x86)\Intel\oneAPI\vpl\latest\bin\libvplswref64.dll Loaded module path: C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_9671054d3bbcb1b5\libmfxhw64.dll Decoding Sample Version 8.4.27.0 Input video AVC Output format IYUV Input: Resolution 1280x960 Crop X,Y,W,H 0,0,1280,960 Output: Resolution 1280x960 Frame rate 1.00 Memory type system MediaSDK impl sw MediaSDK version 2.7 Decoding started Frame number: 150, fps: 47.876, fread_fps: 0.000, fwrite_fps: 338.849 [sk] call m_FileReader->Reset() Frame number: 150, fps: 47.867, fread_fps: 0.000, fwrite_fps: 338.849 [sk] call m_FileReader->Reset() [ERROR], sts=MFX_ERR_ABORTED(-12), CDecodingPipeline::RunDecoding, DecodeFrameAsync returned error status at pipeline_decode.cpp:1980 Frame number: 150, fps: 47.859, fread_fps: 0.000, fwrite_fps: 338.849 [ERROR], sts=MFX_ERR_ABORTED(-12), CDecodingPipeline::RunDecoding, Unexpected error!! at pipeline_decode.cpp:2100 [ERROR], sts=MFX_ERR_ABORTED(-12), main, Pipeline.RunDecoding failed at sample_decode.cpp:901 function: MFXDispReleaseImplDescription (enter) function: LoaderCtxVPL::ReleaseImpl (enter) function: LoaderCtxVPL::ReleaseImpl (return) function: MFXDispReleaseImplDescription (return) function: LoaderCtxVPL::UnloadAllLibraries (enter) function: LoaderCtxVPL::UnloadAllLibraries (return) function: LoaderCtxVPL::FreeConfigFilters (enter) function: LoaderCtxVPL::FreeConfigFilters (return)
thank you
Since this is a duplicate thread of (https://community.intel.com/t5/Media-Intel-oneAPI-Video/oneVPL-sw-impl-fails-with-MFX-ERR-ABORTED-on-DecodeFrameAsync/m-p/1466945#M14540), we will no longer monitor this thread. We will continue addressing this issue in the other thread.
Alekhya
連結已複製
Alekhya
