question on simple transcode
MyMother
hi Intel,
OS: Ubuntu 12.04
       mediasdk-tutorials-0.0.3
       MediaServerStudioEssentials2015R6
Platform:  i5-4570S
Q1.  I found following and the question is below
        // Decode a frame asychronously (returns immediately)
        sts = mfxDEC.DecodeFrameAsync(&mfxBS, pSurfaces[nIndex], &pmfxOutSurface, &syncpD);
        ...   ==>  why  session.SyncOperation(syncpD, 60000) is unnecessary ???
        // Encode a frame asychronously (returns immediately)
        sts = mfxENC.EncodeFrameAsync(NULL, pmfxOutSurface, &mfxEncBS, &syncpE);
        sts = session.SyncOperation(syncpE, 60000);     // Synchronize. Wait until frame processing is ready
Jiandong_Z_Intel
Hi Medwin,
Are you refer simple_5_transcode in mediasdk-tutorials-0.0.3 for your code ?
You can found following in simple_5_transcode\src\simple_transcode.cpp.
        // Ignore warnings if output is available,
        // if no output and no action required just repeat the DecodeFrameAsync call
        if (MFX_ERR_NONE < sts && syncpD)
            sts = MFX_ERR_NONE;
The comments maybe answered your questions.
Zachary
MyMother
hi Zachary,
When I check simple_2_decode/simple_2_decode_vmem, there're always something below
        sts = mfxDEC.DecodeFrameAsync(&mfxBS, pmfxSurfaces[nIndex], &pmfxOutSurface, &syncp);
        if (MFX_ERR_NONE < sts && syncp)
            sts = MFX_ERR_NONE;
        if (MFX_ERR_NONE == sts)
            sts = session.SyncOperation(syncp, 60000);      // Synchronize. Wait until decoded frame is ready
         > How transcoding make sure there're frames ready for encode without above line ??
Jiandong_Z_Intel
Hi Medwin,
I have checked the simple_2_decode/simple_2_decode_vmem.
session.SyncOperation is used in page 13 in mediasdk-man.pdf, I think both of them are correct. you can use both them as you wish, I think  session.SyncOperation  is more better, because session.SyncOperation is used in mediasdk-man.pdf
About this question, I suggest you do some debug to watch "syncp" and "sts", to check when "syncp" is set and the values of "sts" can refer to mfxdefs.h
Zachary
