Intel i7 eight processor thread four thread does not get rid of the blue screen, somehow?
I bought the bulk of CPU i7, the first day is not good, suspected motherboard problem, for a long time. The results of CPU itself have problems
1 解答
链接已复制
21 回复数
Please elaborate this issue because using google translator was not clear enough to understand how you tried to solve it.
I would like to have additional information about your system configuration. Please run the following utility and attach the results.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility
In order to attach files, make sure you select the "Advanced Editor" option in the top right of your reply window. You will then be presented with an attach file dialogue at the bottom of the reply.
Allan.
Yes, Intel can help replacing the processor if you are still under warranty.
You can request warranty service by contacting your local support at http://www.intel.com/content/www/us/en/support/contact-support.html Intel® Processors
Or, you can check your private messages and reply the same way.
Hope this information is helpful.
Please do let me know if you need further assistance with your Intel product, I will be glad to assist you.
Allan.
