16803 Diskussionen
100% CPU usage while playing games -- Intel(R) Core(TM) i5-9400F CPU 2.90 GHz --
Radek7
Einsteiger
15.295Aufrufe
Hello i'm experiencing 100% cpu usage while playing games and i'm little worried that this might hurt my cpu in the future. So that is why i'm writing you this.
I also sent you few screenshots and txt document which i get from your official applications.
I hope this is enough to find an issue, if you need anything more, let me know.
Thanks for your time,
Radek
15 Antworten
RamyerM_Intel
15.191Aufrufe
Hello Radek7,
Thank you for posting in the communities. Before we proceed with some troubleshooting, may I please know what games are causing this issue? This will help us identify if there is a known issue with the games you are playing. Are there also other software open while playing these games? I will be waiting for your reply.
Ramyer M.
Radek7
Einsteiger
15.168Aufrufe
Hello, mostly when playing rust, but this also happens on other games like league of legends, wow.
Especially when i use some other app while playing game, for example google chrome.
Softwares in background are lightshot, bloody7 mouse app, and riot vanguard.
I might think that riot vanguard does that.
RamyerM_Intel
14.970Aufrufe
Hello Radek7,
Thank you for letting us know of the games. I highly recommend to not open other software/ game while you are playing the games as this will surely result to a high CPU usage.  I also have here some recommendations for your system. Upon checking the logs I can see that you may update the BIOS of your system to ensure optimal settings is met. However, since there is a considerable gap between the current and the newest one, I highly recommend updating two BIOS version at a time. Here is an example: 2002 to 2501, 2501 to 2901, 2901 to 3101. You may use this link to download the files:  ROG STRIX B360-G GAMING
Additionally, please update the NVIDIA graphics driver to version: 552.22
Once you do, please follow this additional steps:
  • Confirm that no other heavy workload programs are running in the background while playing.
    1. Open the Task Manager (Ctrl+Shift+Esc).
    2. Click the CPU and Memory tabs to check whether anything is using up large chunks of your CPU or RAM (for instance, a web browser with many tabs open).
  • Keep the operating system up to date.
  • Check with the game developer for the latest patches and updates.
  • For online Games
    • Check the game developer website for suggested network speed in playing the game. Then check if your network will meet the required speed to play in optimum gameplay.
You may also visit this link for more information: How do I Correct a Drop on FPS (Frames Per Second) and High CPU Usage While Gaming on an Intel Processor?
Let me know if you are able to see improvement after doing so. I will be waiting for your reply.
Ramyer M.
Radek7
Einsteiger
14.831Aufrufe
Hello, so i updated my bios with the file, you sent me, also updates nvidia drivers and NOW,  suddenly my GPU started to struggle.
Normal temperature of my GPU is around 50°C, when i launched rust and the game loaded into main menu, GPU went from 50°C to 75°C and fans inside my computer started to be really loud.
I'm totally lost, don't know what to do now.
Also thx for your replies and your time.
RamyerM_Intel
14.759Aufrufe
Hello Radek7,
I'm sorry to hear that the troubleshooting did not solve the high cpu usage. For now, kindly please make sure that you are loading the default settings in your BIOS. I will also coordinate this with our team for further investigation and get back to this thread as soon as possible.
Ramyer M.
Radek7
Einsteiger
14.675Aufrufe
Also i wanted to mention that i also cleaned dust from my computer, so that cannot be weather problem that gpu is hitting more temperature.
Doesn't make sense to me, cause like week or two ago when pc was full of dust, had old version of bios and also i was missing 1 gpu driver update, it wouldn't ramp up to temperatures when it has to use fans with that much RPM.
If you need anything, let me know, it's really strange and i feel lost
Radek
RamyerM_Intel
14.591Aufrufe
Hello Radek7,
Thank you for mentioning that you have cleaned the system as well. For now, I will continue on coordinating this with my team and get back on this thread as soon as possible. Thank you for your patience and cooperation
Ramyer M.
Radek7
Einsteiger
14.469Aufrufe
Hi, today i just noticed some really strange behaviour of my GPU.
I was playing World of Warcraft classic and randomly while playing my fans started to be really loud as i mentioned in previous posts, BUT when i looked task manager, and continued watching it while playing, it was permanently around 2% of GPU usage, i don't think that is the gpu problem now but mby some fan overclock? i don't really know.
But this started when i updated the bios, never did that before, fans were always quiet.
RamyerM_Intel
14.133Aufrufe
Hello Radek7,
Thank you for patiently waiting. Upon coordinating with our team, we can say that there is nothing wrong with the processor. To fully understand the source for the high CPU utilization, we need to investigate the process that is using the processor.
To check the running processes within your system, please do the following:
  1. Download the Process Explorer tool
  2. Run Process Explorer as an administrator.
  3. Right-click the process, select Properties, and then select the Threads tab.
  4. Select the thread that consumes high CPU, and then select Stack to view the functions that are being run.
If you wish to get the better stack information result, configure symbols in the Process Explorer. To do this, follow these steps:
  1. Install Debugging Tools for Windows.
  3. Select the Options menu, and then select Configure Symbols.
  4. Change the Dbghelp.dll path to C:\Program Files (x86)\Windows Kits\10\Debuggers\x64\dbghelp.dll, and then select OK.
Ramyer M.
RamyerM_Intel
14.009Aufrufe
Hello Radek7,
I am just checking in if you were able to gather thee details we requested in my previous post? Feel free to share this with us so we can determine the root cause of high cpu utilization.
Ramyer M.
Radek7
Einsteiger
13.952Aufrufe
Hello
I did every step up to step 4. but there are 4 threads, 1 with low usage and 3 with the same usage, so i'm not sure which one should i stack, BUT i tried to stack all three but it says "Unable to access thread".
For this, i did a screenshot how it looks like.
For future questions, yes i ran that as an administrator.
I also tried to use that debugg thing you mentioned, but i'm not quite sure what to download through that link.
Could you please make me even install path to debugg kit?
Sorry that i cannot even do these easy things but i'm just amateur
Thanks for your time.
RamyerM_Intel
13.738Aufrufe
Hello Radek7,
Thank you for letting us know about this details and we will check the screenshot you have sent.
As for the debugging tool link, feel free to install it at this link: Install the Windows debugger and follow the following steps:
  1. Run Process Explorer as an administrator.
  2. Select the Options menu, and then select Configure Symbols.
  3. Change the Dbghelp.dll path to C:\Program Files (x86)\Windows Kits\10\Debuggers\x64\dbghelp.dll, and then select OK.
Ramyer M.
NormanS_Intel
13.610Aufrufe
Hello Radek7,
I wanted to check if you had the chance to review the information we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Norman S.
RamyerM_Intel
13.508Aufrufe
Hello Radek7,
I hope you are doing well. As we have not heard a response in the past few days, we will proceed in closing this thread. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
We wholeheartedly wish you every success in all your future ventures and may your path be lined with triumphs and fulfillment
Ramyer M.
Radek7
Einsteiger
13.344Aufrufe
Sorry, i forgot to reply you.
The problem somehow dissapeared and everything works fine.
Thanks for your help and TIME.
Radek
Antworten
