So ive recently noticed my idle temps with an NH D15 are around 60 and 70 degrees (as seen in the picture)
Ive updated to the newest bios with the micro code and have enabled the intel profile. Thermalpast seems to be good so what could be the problem?
Thanks in advance
Those idle temperatures point to the cooling solution being improperly installed/configured/controlled or, well, broken.
Change the CPU Loadline Calibration Control.
Select mode 1 first, then increase to a maximum of mode 9.
You have to find a mode in which the PC will be stable and at the same time the highest score in multicore movies and at the same time max 80C.
