16774 Diskussionen
13900k and 14900k, directx12, windows 11
Jg615f
Einsteiger
7.833Aufrufe
Does anyone know if the problems with the 13900k and the 14900k running direct X12 games and programs have been solved by either Microsoft in Windows 11 or by Intel? Aside from lowering your p cores and all the other tuning possibilities which are not actually fixes.
17 Antworten
H_Mlysgeek
Neuer Beitragender I
7.769Aufrufe
I think, as of now, there have been reports of issues with the 13900k and the 14900k processors when running DirectX 12 games. Many users have encountered crashes while playing games or running some programs under DX12.
Some have found workarounds, such as decreasing the pcore to 52x, but this solution doesn’t work for everyone.
Here are a few steps to try to fix the issue:
  1. Update Windows: Press Windows + I to open System Settings, then navigate to Update & Security. Check for any available updates and install them. After installation, reboot your machine. Usually, this will activate DirectX 12 for most games2.
  2. Check Graphics Drivers: Ensure that your graphics card drivers are up to date. You can download and install the recommended version from the support page of your PC manufacturer3.
  3. Memory Considerations: Some users have reported success by adjusting their RAM. For instance, replacing RAM running at 6000 MHz with a different set running at 5600 MHz resolved the issue for one user. Additionally, downgrading the GPU driver may also help
But these solutions might not work universally, but they are worth trying.
Cheers,
H_Mlysgeek
Jg615f
Einsteiger
7.761Aufrufe
I appreciate your attempt to help, but this issue is well documented and far beyond gpu drivers, windows os updates and I specifically asked if solutions were in the works from the companies mentioned. I also didn't ask for p cores to be reduced in the first post.
VonM_Intel
7.743Aufrufe
Hi, Jg615f.
Thank you for posting in our Community.
We will do further research on this matter and post the response on this thread once available.
Von M.
VonM_Intel
7.651Aufrufe
Hi, Jg615f.
I appreciate your patience. Kindly be informed that I will be sending you an email shortly as it includes some confidential information regarding this matter.
Von M.
Jg615f
Einsteiger
7.571Aufrufe
Is there any update from Intel, partners or affiliates on this matter? Or is this just the type of instability we can expect from our very expensive purchases of the latest consumer Intel CPUs?
VonM_Intel
7.520Aufrufe
Hi, Jg615f.
Just a heads up, we've sent you an email with all the details about your concern.
Thank you.
Von M.
VonM_Intel
7.479Aufrufe
Hi, Jg615f.
I hope you are doing fine.
Kindly let us know if you still need assistance.
Von M.
Jg615f
Einsteiger
7.449Aufrufe
Are these options considered undervolting? Or what is the best terminology for the process I'm being asked to perform?
VonM_Intel
7.359Aufrufe
Hi, Jg615f.
Thank you for your response. Kindly be informed that I will be sending you an email shortly as it includes some confidential information regarding this matter.
Von M.
Jg615f
Einsteiger
7.187Aufrufe
From Intel Moderator after asking about my system specs:
Thank you for your response. As we carefully looked into the issue, Intel has acknowledged the existence of issues affecting the 13th and 14th Gen unlocked desktop processors under specific workloads. We are actively collaborating with our partners to investigate the nature of these problems.
In the meantime, if you continue to experience problems with your system, particularly with your processor, and you have a Gigabyte motherboard, please see the following troubleshooting guidelines below:
  • Solution A):
    • In BIOS, select "ADVANCED MODE", in the Tweaker tab, locate the CPU Vcore and select the "Normal" option, select "Dynamic Vcore(DVID)" option, change it from "Auto" to "+0.005V" Increase the DVID by +0.005 and reboot OS, until the game crash disappears and the system is running stable.
  • Solution B):
    • In BIOS, select "Tweaker", select "Advanced Voltage Settings", select "CPU/VRAM Settings", adjust "CPU Vcore Loadline Calibration", recommend starting from "Low" to "Medium" until the system is stable.
After implemented A or B, run the XTU test again, and if the AVX2 test can pass. Run games and see if the issue happens again.
We look forward to your response regarding this matter. To allow you ample time to respond/provide the information above, is it okay if we follow up with you on Thursday, March 28, 2024? If we have not heard from you, we will check back with you on the date mentioned above to make sure that we can efficiently address your concern.
Have a delightful day ahead!
Von M.
Me:
Mod:
Thank you for your reply to our Intel Community Threads. In response to your query about whether the suggested options constitute undervolting: they do not. Instead, these are measures to increase the processor voltage. This solution is determined to be the most suitable for your processor following our thorough analysis.
We look forward to your response regarding this matter. To allow you ample time to respond/provide the information above, is it okay if we follow up with you on Thursday, April 4, 2024? If we have not heard from you, we will check back with you on the date mentioned above to make sure that we can efficiently address your concern.
Me:
  • Solution A):
in this option, I should increase the voltage by the specified amount until it passes an xtu test and plays games that are directx12? Is there a specific criteria for the xtu test?
Is this option potentially dangerous for the cpu? Is raising the voltage going to cause thermal throttle issues?
VonM_Intel
7.152Aufrufe
Hi, Jg615f.
Kindly be informed that I will be sending you an email shortly as it contains confidential information related to this matter.
Von M.
VonM_Intel
6.515Aufrufe
Hi, Jg615f.
I trust you're doing well.
We have not heard back from you, we will close this inquiry now. We've sent you an email regarding this matter.
If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
iobotic
Einsteiger
5.676Aufrufe
I'm facing the same issue as described with my 14900kf and an Asus ProArt Z790 Creator Motherboard.
Despite several BIOS updates provided by ASUS, the issue still remains and the only solution is downclocking the P-Cores with the Intel Extreme Tuning App.
Could you please provide some insights and a possible solution? @VonM_Intel
Thank you.
Jg615f
Einsteiger
5.661Aufrufe
In the bios Asus has an Intel baseline that was released recently, but this is still not correct. You have to manually change the wattage and amps in the bios. There are 2 profiles that Intel released. Performance has Pl1-125, pl2- 253 and 307a also there will be a duration for the power setting that should be set to 56 seconds. The second profile is called extreme with pl1-253 pl2-253 and amps set to 400a. The duration is still 56 seconds. Hope this helps lmk what you find out.
Jg615f
Einsteiger
5.659Aufrufe
I know you probably want to hear from mods on this but the entire group of customer service reps was completely unhelpful and really had no idea how to help me.
iobotic
Einsteiger
5.578Aufrufe
Thanks a ton!
I'll look into it, though it's absolutely unacceptable to be digging that deep in the advances settings of the bios in order to have the CPU run normally. Huge let-down Intel... If you don't sort it out soon, I will have all the reasons not to touch your gear for the nearest foreseeable future.
Have a spry day!
Antworten
