- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I think, as of now, there have been reports of issues with the 13900k and the 14900k processors when running DirectX 12 games. Many users have encountered crashes while playing games or running some programs under DX12.
Here are a few steps to try to fix the issue:
Update Windows: Press Windows + I to open System Settings, then navigate to Update & Security. Check for any available updates and install them. After installation, reboot your machine. Usually, this will activate DirectX 12 for most games2.
Check Graphics Drivers: Ensure that your graphics card drivers are up to date. You can download and install the recommended version from the support page of your PC manufacturer3.
Memory Considerations: Some users have reported success by adjusting their RAM. For instance, replacing RAM running at 6000 MHz with a different set running at 5600 MHz resolved the issue for one user. Additionally, downgrading the GPU driver may also help
But these solutions might not work universally, but they are worth trying.
Cheers,
H_Mlysgeek
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi, Jg615f.
Thank you for posting in our Community.
We will do further research on this matter and post the response on this thread once available.
Von M.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi, Jg615f.
I appreciate your patience. Kindly be informed that I will be sending you an email shortly as it includes some confidential information regarding this matter.
Von M.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi, Jg615f.
Just a heads up, we've sent you an email with all the details about your concern.
Thank you.
Von M.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi, Jg615f.
I hope you are doing fine.
Kindly let us know if you still need assistance.
Von M.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi, Jg615f.
Thank you for your response. Kindly be informed that I will be sending you an email shortly as it includes some confidential information regarding this matter.
Von M.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
In the meantime, if you continue to experience problems with your system, particularly with your processor, and you have a Gigabyte motherboard, please see the following troubleshooting guidelines below:
- Solution A):
- In BIOS, select "ADVANCED MODE", in the Tweaker tab, locate the CPU Vcore and select the "Normal" option, select "Dynamic Vcore(DVID)" option, change it from "Auto" to "+0.005V" Increase the DVID by +0.005 and reboot OS, until the game crash disappears and the system is running stable.
- Solution B):
- In BIOS, select "Tweaker", select "Advanced Voltage Settings", select "CPU/VRAM Settings", adjust "CPU Vcore Loadline Calibration", recommend starting from "Low" to "Medium" until the system is stable.
We look forward to your response regarding this matter. To allow you ample time to respond/provide the information above, is it okay if we follow up with you on Thursday, March 28, 2024? If we have not heard from you, we will check back with you on the date mentioned above to make sure that we can efficiently address your concern.
Have a delightful day ahead!
Me:
Are these options considered undervolting? Or what is the best terminology for the process I'm being asked to perform?
Mod:
Me:
- Solution A):
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi, Jg615f.
Kindly be informed that I will be sending you an email shortly as it contains confidential information related to this matter.
Von M.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi, Jg615f.
I trust you're doing well.
We have not heard back from you, we will close this inquiry now. We've sent you an email regarding this matter.
If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I'm facing the same issue as described with my 14900kf and an Asus ProArt Z790 Creator Motherboard.
Despite several BIOS updates provided by ASUS, the issue still remains and the only solution is downclocking the P-Cores with the Intel Extreme Tuning App.
Could you please provide some insights and a possible solution? @VonM_Intel
Thank you.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thanks a ton!
I'll look into it, though it's absolutely unacceptable to be digging that deep in the advances settings of the bios in order to have the CPU run normally. Huge let-down Intel... If you don't sort it out soon, I will have all the reasons not to touch your gear for the nearest foreseeable future.
Have a spry day!
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
