16761 Discussions
14900K - Why do all of my browsers keep crashing?
Nefer26
Hello.
I had a crashing problem in the games, I changed it to default settings and the situation improved a little. I am currently getting constant crashes on all my browsers. I did a ram test, no problem.I've formatted. I've done all the updates. My system is new. I think there is a problem with the processor. Will the next update solve this issue?
My current system is as follows;
14900 K (dated 18.10.2023)
Rog Z790 Dark Hero Motherboard
Rog RTX 4090 OC
GSKILL 64GB (2x32GB) Trident Z5 RGB 6400MHz CL32
ASUS ROG RYUJIN III 360 ARGB
RandyT_Intel
Hello Nefer26,
If you have already applied the Intel default settings to your BIOS and are still experiencing game crashes, I can offer you alternative options for this case.
Please check your email. I have sent you a personal message on how to address this issue.
Randy T.
Nefer26
I added the Intel System Support Utility scan problems. My problem persists. Crashes continue on all my browsers. I updated the BIOS settings. I turned off and on XMP. I couldn't find any solution in any way. I updated the BIOS settings. I'm trying to use it in Intel mode, but I'm still not satisfied. Can someone please help? I'm very desperate.
Senkuchan
Valued Contributor II
You tried using the intel default settings is that correct? If the issue is the same, i suggest requesting a replacement
Nefer26
Yes, Intel default is at recommended settings.
RandyT_Intel
Hello Nefer26,
Randy T.
Nefer26
Hello. I am waiting for your mail. I haven' t received any mail yet. My problem continues. I am using Intel default settings.
Nefer26
