16771 Discussions
14900k seems to be failing
jdamon
I'd appreciate any advice about my issue, thanks! I built a system with a 14900k + Z790 Apex (White) + 2x16 GB G.Skill ddr5 7800 + Corsair i1600 PSU + Corsair Link 420 AIO +2 Samsung 990Pros. The CPU is not a great bin with V/F 8 of 1.413v and everything higher @ 1.493v. But I have been running with the stock config + XMP and OCTVB +1 for a couple months with no problems and good temps (kept the Intel Power limits of 253 in place). But last week I started to get BSoDs, system restarts, and frequent programs crashes. Using Event Viewer and the program Who Crashes (just a dump file reader) I can see that all of the errors are cpu related and when I ran Cinebench r23 a few times the scores where half of what they were just last month. I am on Windows 11 and I normally use Process Lasso and Park Control, although I turned them off for the last few days to see if an incorrect setting had been the cause of my problems. Sadly that wasn't the answer. Again this chip pulls a lot of vcore by default, and refuses to run with any undervolting but lately it has been acting as though I have some unstable overclock despite it running basically stock. And it seems to be getting worse. Any help would be great, thanks!
RamyerM_Intel
Hello jdamon,
It is best if we can gather more information so we can identify what caused the BSODs, system restarts, and frequent programs crashes in your system.
Kindly please share the following details:
  1. When did the issue started? Was it sudden or gradual?
  2. Are there any error messages showing up in your system?
  3. Was the system working before?
  4. Have you made any changes before the issue occurred? If you do, kindly please indicate if it is a software or a hardware change.
  5. Have you tried any troubleshooting steps?
  6. It would really help us if we can get more information about your system. Please download and run our Intel® System Support Utility located at this link: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html.
  7. After running it, you will be given an option to save the logs to a text file, please do so and attach the file on your reply.
Ramyer M.
RamyerM_Intel
Hello jdamon,
How are you doing? Please send us the above information so we can further fix what is causing this frequent crashes. Please feel free to reply to the post here.
Ramyer M.
RamyerM_Intel
Hello jdamon,
We're going to close this thread as we haven't heard back from you regarding the BSODs you are experiencing in the last few days. This thread will no longer be monitored, so if you require any extra information, please post a new question.
Ramyer M.
