14900k
Kuba1982
Principiante
1.008 Vistas
Recently I had some random crashes in Fortnite. I installed all of the latest BIOS updates and made necessary changes but it is still similar.
Could you chech what is the problem?
In the attachment you can find tests results from Intel procesor diagnostic tools and system support utility.
My processor: Intel 14900k
Etiquetas (1)
0 kudos
1 Responder
pressed_for_time
Colaborador Valioso II
990 Vistas
The diagnostic tests seem to indicate there is no issue with your 14900K. I note that Windows 11 Cumulative Preview Update KB5043145 dated 9/27/2024 is installed. There have been reports of issues with this update by some users. Other than that there seem to be numerous references on the Internet to crashes in Fortnite, including in some cases check lists of items to work through. This includes using DX11 rendering instead of DX12. Are crash logs being created in FortniteGame/Saved/Logs and if so do they contain anything about the cause of the crashes. They may contain error codes or messages that could be reported to Epic Games.
Responder
