- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
These flags appear on hwinfo64
A CMOS reset and BIOS update didn't fix them (MSI Z170I Gaming Pro AC Motherboard)
The CPU voltage was set to 1.23V, now it's at Auto, the issue is persistent
Intel Extreme Tuning Utility reports the 1-Core Turbo at 42x, yet 2,3,4 Cores are at 40x
So it seems the CPU somehow disabled Turbo for multiple cores
Can someone explain why this happened and whether this flags are every going to be disabled?
Message was edited by: Kaan Soral
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi KaanS,
The processor is working under its specifications. Turbo Boost increases the Core speed; however, only 1 Core will reach the maximum, in this case 4.2Mhz the rest will run slower.
The picture below shows expect Core speed on 6th gen processors
Further information about Intel® Turbo Boost Technology at
http://www.intel.com/support/processors/corei7/sb/CS-032279.htm Intel® Core&# 153; i7 Desktop Processor — Intel® Turbo Boost Technology Frequency Table
MiKe C
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
On my processor, I observe each core reaching 42x, but it really doesn't matter for the sake of this argument
This specific processor doesn't reach 42x ever, the performance blocking flags I mentioned gets set, it stays at 40x, my brother also reported glitches during usage, disabling Turbo fixed the issue, the flags no longer get set
Folks who know more pointed out that it's most porbably a BIOS/voltage issue that might get solved: http://www.overclockers.com/forums/showthread.php/766755-6700K-IA-Max-Turbo-Limit-IA-Turbo-Attenuation-(MCT)-flags-on-hwinfo64?p=7879386# post7879386 Overclockers Forums
I'm just wondering whether it's a faulty CPU
