16770 Discusiones
After restarting the PC, ETU's overclocking setting became invalid.
Qiye
Principiante
1.402 Vistas
After modifying the bios, ETU will restore the default settings. Sometimes, this can also happen after restarting the computer or starting from sleep mode. ETU has been set to start automatically upon startup. Is there any setting that can keep the overclocking setting constant?
0 kudos
5 Respuestas
Mike_Intel
Moderador
1.347 Vistas
Hello Qiye,
Let me gather more details about the issue for me to better understand it.
  1. What is ETU?
  2. Is it working before?
  3. What is the model of your processor and motherboard?
  4. Can you share some screenshots?
Michael L.
KrissyG
Nuevo Colaborador II
1.331 Vistas
XTU top right corner -> settings-> Advanced options
I guess if you uncheck it, XTU will no longer enforce its own settings.
That being said, why are you not using XTU to overclock, it has almost same capabilities as BIOS?
Mike_Intel
Moderador
1.313 Vistas
Hello Qiye,
Thank you for the update.
Overclocking inside the BIOS and using an app like XTU is just the same.
The "Restore Tuning after Reboot" is used if you are doing trial and error on the settings that you are changing.
However, I am not familiar with the ETU that you are using.
Michael L.
Mike_Intel
Moderador
1.218 Vistas
Hello Qiye,
Michael L.
Mike_Intel
Moderador
1.120 Vistas
Hello Qiye,
I am sending another follow up on the information that I requested.
Michael L.
Responder
