16771 ディスカッション
Any suggested Intel processor to use?
BLee41
ビギナー
4,107件の閲覧回数
Current computer: Plan to replace the ASRock Intel Celeron with a faster processor.
Items considered:
- Current motherboard plan, must be mini-ITX: https://www.newegg.com/Product/Product.aspx?Item=9SIAD7H5EW9619&cm_re=9SIAD7H5EW9619_i7_mini-ITX_SO_DIMM-_-9SIAD7H5EW9619-_-Product ASRock H81TM-ITX R2.0 LGA 1150 Intel H81 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard - Newegg.com
- Must be low temperature (at best, 35W), or if not, cooling items must fit inside this Commodore 64x.
- Must allow: https://www.amazon.com/gp/product/B0076W9Q4Q/ CMSX8GX3M1A1600C10 Vengeance 8GB (1x8GB) DDR3 1600 MHz (PC3 12800) Laptop Memory- 1.5V
i.e. https://ark.intel.com/products/75468 Intel® Core™ i5-4570TE Processor (4M Cache, up to 3.30 GHz) Product Specifications
0 件の賞賛
13 返答(返信)
AlHill
スーパーユーザー
2,900件の閲覧回数
asrock says you can use these processors:
https://www.asrock.com/mb/Intel/H81TM-ITX%20R2.0/# CPU ASRock > H81TM-ITX R2.0
Doc
BLee41
ビギナー
2,900件の閲覧回数
Oh thanks. Very useful. Hoping the one I picked doesn't have Windows 8 installed.
Now I have to find which ones are DDR3 1600 compatible (RAM in link) then narrow it.
If there's a better motherboard that's different, I'd like to know.
I don't aim for a reinstallation, just a swap.
AlHill
スーパーユーザー
2,900件の閲覧回数
If the motherboard supports the ram, and the motherboard bios supports those processors, you should have no trouble selecting a processor.
And, you may want to sort by "power" if heat is a concern.
And, make sure the bios meets the minimum level. You may want to update the bios with the old processor first.
Doc
BLee41
ビギナー
2,900件の閲覧回数
Does that have Windows 8 installed? I hope not because it might get in the way of my migration.
AlHill
スーパーユーザー
2,900件の閲覧回数
Does what have Windows 8 installed? asrock supports w7, w8x and w10 on this board.
https://www.asrock.com/mb/Intel/H81TM-ITX%20R2.0/# Download ASRock > H81TM-ITX R2.0
Doc
BLee41
ビギナー
2,900件の閲覧回数
Ah wait, nvm I forgot that this one doesn't have a OEM OS.
Would a fan work if I already have an existing fan on the case? Or should I get a heatsink?
従業員
2,900件の閲覧回数
Hi bhl88,
The board manufacturer determines if the system requires a dedicated heatsink and fan for the processor. The board requires additionally, holes on the board to attach the heatsink and fan.
Miguel C.
Intel Customer Support
従業員
2,900件の閲覧回数
Hi bhl88,
I am wondering if you been able to build your custom system.
Miguel C.
BLee41
ビギナー
2,900件の閲覧回数
It will take time. Shipping takes until August.
A 35 W should work in a constrained space.
従業員
2,900件の閲覧回数
Hi bhl88,
I would like to know if you continue needing assistance with this or if there is anything else.
Eduardo_B.
VARADHARAJAN
高評価コントリビューター II
2,900件の閲覧回数
INTEL CORE i3 PROCESSORS with LGA1150 socket with maximum TDP 35W
core i3 4130T
core i3 4150T
core i3 4160T
core i3 4170T
core i3 4330T
core i3 4350T
core i3 4360T
core i3 4370T
core i3 4330TE
core i3 4340TE
INTEL CORE i5 PROCESSORS with LGA1150 socket with maximum TDP 35W
core i5 4570T
core i5 4570TE
INTEL CORE i7 PROCESSORS with LGA1150 socket with maximum TDP 35W
core i7 4765T
core i7 4785T
make sure one of the above is definitely compatible with your desired
DO you want changed the motherboard also with same LGA1150 socket ?
AlHill
スーパーユーザー
2,900件の閲覧回数
Raju, again I warn you. You can only use a processor if it is supported by the BIOS. So, your list is worthless without this knowledge.
Doc
返信
