- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I've been getting WHEA errors that WinDbg is telling me are BOOT errors. Strangely enough, this only happens while the system is idling - I've never had this happen while using the system. Every error has been accompanied by the system being unresponsive - no bugchecks or anything weird, the screen is just completely frozen.
The issue started happening after I installed new RAM (DDR4, XMP profile 4000mhz 19-19-19-39, ran in Gear1 CR2).
The CPU is overclocked a little bit (so it hits 5 allcore, I can provide detailed info if needed) but that shouldn't matter on idle, correct (using the Balanced power profile on Windows 11)?
My motherboard is a MSI PRO Z690-A DDR4 and the RAM model is Patriot PVS416G400C9K.
Here's the WinDbg output for the latest crash dump:
Mini Kernel Dump does not contain unloaded driver list
For analysis of this file, run !analyze -v
nt!LkmdTelCreateReport+0x1de:
fffff804`47a344ea 0f1f440000 nop dword ptr [rax+rax]
6: kd> !analyze -v
* Bugcheck Analysis *
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
nt!_WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the nt!_WHEA_ERROR_RECORD structure to get more details.
Arguments:
Arg1: 0000000000000007, BOOT Error
Arg2: ffff81825c103020, Address of the nt!_WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1343
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 4637
Key : Analysis.Init.CPU.mSec
Value: 311
Key : Analysis.Init.Elapsed.mSec
Value: 20710
Key : Analysis.Memory.CommitPeak.Mb
Value: 127
FILE_IN_CAB: WHEA-20211219-2030.dmp
DUMP_FILE_ATTRIBUTES: 0x18
Kernel Generated Triage Dump
Live Generated Dump
BUGCHECK_CODE: 124
BUGCHECK_P1: 7
BUGCHECK_P2: ffff81825c103020
BUGCHECK_P3: 0
BUGCHECK_P4: 0
PROCESS_NAME: smss.exe
STACK_TEXT:
ffffa585`05a96e80 fffff804`47a06eff : ffff8182`5c103000 00000000`00000000 ffff8182`5c103020 00000055`d2a7fa00 : nt!LkmdTelCreateReport+0x1de
ffffa585`05a973c0 fffff804`47a06df6 : ffff8182`5c103000 00000000`00000000 00000000`00000000 ffff8182`5bfd2d00 : nt!WheapReportLiveDump+0x7b
ffffa585`05a97400 fffff804`4784c599 : 00000000`00000001 ffffa585`05a97aa0 00000000`00000000 00000000`000002f4 : nt!WheapReportDeferredLiveDumps+0x7a
ffffa585`05a97430 fffff804`47739932 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000001 : nt!WheaCrashDumpInitializationComplete+0x59
ffffa585`05a97460 fffff804`47427f75 : ffff8182`5c597080 00000000`00000000 00000000`0000022c 00000000`00000001 : nt!NtSetSystemInformation+0xa72
ffffa585`05a97a20 00007ffe`d69a69d4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
00000055`d2a7f9a8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffe`d69a69d4
MODULE_NAME: GenuineIntel
IMAGE_NAME: GenuineIntel.sys
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: LKD_0x124_7_GenuineIntel__UNKNOWN_IMAGE_GenuineIntel.sys
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {5ea80f6a-69bf-5d6f-8fd2-cd87deb91a03}
Followup: MachineOwner
6: kd> !errrec ffff81825c103020
Common Platform Error Record @ ffff81825c103020
Record Id : 01d7f506713867a9
Severity : Fatal (1)
Length : 28896
Creator : Microsoft
Notify Type : BOOT Error Record
Timestamp : 12/19/2021 18:30:05 (UTC)
Flags : 0x00000002 PreviousError
Section 0 : Firmware Error Record Reference
Descriptor @ ffff81825c1030a0
Section @ ffff81825c1032e0
Offset : 704
Length : 2592
Flags : 0x00000000
Severity : Fatal
Section 1 : Firmware Error Record Reference
Descriptor @ ffff81825c1030e8
Section @ ffff81825c103d00
Offset : 3296
Length : 544
Flags : 0x00000000
Severity : Fatal
Section 2 : Firmware Error Record Reference
Descriptor @ ffff81825c103130
Section @ ffff81825c103f20
Offset : 3840
Length : 72
Flags : 0x00000000
Severity : Fatal
At this point I'm beginning to think it's the PSU being faulty (Fractal Design Newton R3 800W) - I've been having complete system shutdowns in heavy CPU+GPU workloads with no bugchecks/whatnot.
Attached is the System Support Utility log.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello a999,
Thank you for posting on the Intel
- Have you tested a different RAM?
- Have you tested a different motherboard?
- Have you tested using only 1 DIMM of RAM?
Josue O.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I've tried different RAM and didn't have the issue - the current RAM shouldn't be defective, I've tested it using TestMem5 several times. Haven't tried a different motherboard/using 1 RAM stick.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello a999,
Thank you for the information provided, in this case, please try testing the RAM modules in another system and check if the issue persists.
Also, please try using only 1 DIMM of RAM and check if the issue persists.
Josue O.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
tested the DIMMs in another PC - no signs of such instability. Haven't tested with 1 DIMM, though.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello a999,
Thank you for the information provided, please also test using 1 DIMM and let us know if the issue persists.
Also, please share with us the model of the RAM that works fine with the system.
Josue O.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
The memory that worked fine was the Corsair Vengeance Pro 3600mhz CL18-22-22-42. Could the tighter timings/higher clocks of the new memory be the issue?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello a999,
Thank you for the information provided, in this case, it is important for you to know that the maximum DDR4 memory speed supported by the processor is 3200 MT/s, please try setting the RAM to that speed and test the system.
Regard,
Josue O.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello a999,
Regard,
Josue O.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello a999,
We have not heard back from you, so we will close this thread. In case the issue persists, our recommendation is to check compatibility between the RAM with the other components of the system since this could affect its proper functioning, for this, please contact the ram manufacturer and check with them for any compatibility issues.
Regard,
Josue O.
