16771 討論
BSOD Bluescreen REFERENCE_BY_POINTER IntcBTAu.sys in Intel Smart Sound after resume
svrghaxa
新手
6,295 檢視
I had several BSODs only again with Intel Drivers - this BSOD REFERENCE_BY_POINTER IntcBTAu.sys
Uptime only six days, while my apple macbook has now an uptime of more than 30 days.
Both having multiple sleep/hibernation/docking/undocking cycles.
But Intel machines just crashing earlier, and losing again all my work.
Using only recent Windows updates and recent Dell Provided Drivers using Dell Update.
(Not using directly recent Intel drivers which also produce BSOD after  about one week).
See attached files.
0 積分
5 回應
Andres_Intel
員工
6,270 檢視
Hello svrghaxa,
Thank you for posting on the Intel communities. I am sorry to hear that you are having Blue Screen of Death issues, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
svrghaxa
新手
6,254 檢視
  • When does the issue happen? For example when running specific apps, randomly, etc.
    It happens when waking up from Sleep.
  • Provide a list of the drivers versions you have issues with.
    - Driver name: Intel Smart Sound Technology for Bluetooth
    - C:\Windows\System32\DriverStore\FileRepository\intcbtau.inf_amd64_fd6b2af28036afac\IntcBTAu.sys
    - Driver version and file version: 10.29.0.8467
  • Intel SSU Log: See attached file
  • Something else: I had also BSOD Driver Power state failure with "Intel Smart Sound Technology BUS " after one week and when trying to going to sleep.
    This I was able to fix by unchecking "Allow Computer to turn off this device .."
  • I tried also more recent Intel drivers using the Intel Driver Assistant, but then I quickly uninstalled it and used again the more Stable Dell drivers. With NonDell provided drivers I get then BSODs  after three days of multiple docking/undocking/sleeping/hibernation/resuming cycles.
  • Ran already for 48h memtest86, then mprime95 with maximum heat, no crashes or BSODs, and Dell cannot find any hardware issue.
  • It seems that resuming from ModernStandby and Intel are not 100% reliable.
Andres_Intel
員工
6,238 檢視
Hello svrghaxa,
Thank you for your response, and all the information provided.
If the BSOD issue still persists, for drivers and support for Intel® Smart Sound Technology on your laptop, we recommend that you refer back to your laptop manufacturer as they can provide you with the required support.
Now we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
hoegge
初學者
5,953 檢視
I have the same problem BSOD on a Lenovo P14s:
SYMBOL_NAME: IntcBTAu+38dfb
MODULE_NAME: IntcBTAu
IMAGE_NAME: IntcBTAu.sys
IMAGE_VERSION: 10.29.0.9153
STACK_COMMAND: .cxr 0xffff8f0a344aee40 ; kb
BUCKET_ID_FUNC_OFFSET: 38dfb
FAILURE_BUCKET_ID: 0x7E_IntcBTAu!unknown_function
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {5f498db8-a317-17dd-db67-307d672b4e3f}
Followup: MachineOwner
8: kd> lmvm IntcBTAu
Browse full module list
start end module name
fffff801`2b810000 fffff801`2b8ea000 IntcBTAu (no symbols)
Loaded symbol image file: IntcBTAu.sys
Image path: \SystemRoot\System32\DriverStore\FileRepository\intcbtau.inf_amd64_543b5a199b5f980c\IntcBTAu.sys
Image name: IntcBTAu.sys
Browse all global symbols functions data
Timestamp: Thu May 25 15:58:23 2023 (646F697F)
CheckSum: 000E6530
ImageSize: 000DA000
File version: 10.29.0.9153
Product version: 10.29.0.9153
File flags: 8 (Mask 3F) Private
File OS: 40004 NT Win32
File type: 3.9 Driver
File date: 00000000.00000000
Translations: 0409.04b0
Information from resource tables:
CompanyName: Intel(R) Corporation
ProductName: Intel(R) Smart Sound Technology for Bluetooth(R) Audio
InternalName: IntcBTAu.sys
OriginalFilename: IntcBTAu.sys
ProductVersion: 10.29.00.9153
FileVersion: 10.29.00.9153
FileDescription: Intel(R) Smart Sound Technology for Bluetooth(R) Audio
LegalCopyright: Intel(R) Corporation. All rights reserved.
svrghaxa
新手
6,207 檢視
Really frustrating just being ping-ponged and not even looking at or understanding the crashdump!
Can you at least verify / check whether Intel Products are suitable for long uptimes (more than six days)
and multiple suspend and resume cycles?
Dell has already verified after replacements, that there is no hardware fault.
If not, then I would like to close / delete this thread and will just do daily restart with Intel notebooks
and for critical long uptime  stuff I use then my MacBook.
As recommended by Dell I installed their older drivers , and also their recommended drivers.
They told me, to ask Intel, might be Intel can understand the stacktrace of the dump.
I really hoped, that at last resort Intel can check my crashdump - there must be a driver bug because there is no hardware fault!
回覆
