16770 ディスカッション
CPU i7 13700KF is it fixed?
Skodz
ビギナー
1,236件の閲覧回数
I tried launching path of titans yesterday and they told me there is a major critical issue with Intel 13 and 14th gen CPU eventually leading to total failure since a couple years... This is very concerning and I tried finding informations if it was fixed or not, I read an article that Intel tried to roll out BIOS updates, has it been fixed remotely by Intel or do I need to do something myself ? If so, could anyone by generous enough to provide me with instructions? I bought my pc fully assembled a couple years ago, I had zero issues with it so far but I dont want it to fail...
0 件の賞賛
1 解決策
AlHill
スーパーユーザー
779件の閲覧回数
We were talking about the BIOS, right?  That is the one you want.
I am concerned that you may not be able to do this, which is why I recomment that you contact MSI for assistance.  Else, you can really screw things up.
[AI is the same as snake-oil]
元の投稿で解決策を見る
13 返答(返信)
AlHill
スーパーユーザー
1,202件の閲覧回数
Get the bios update from your motherboard/system manufacturer.
n_scott_pearson
スーパーユーザー
1,145件の閲覧回数
Restating AL's post, regularly check for and always install any BIOS/firmware updates that the motherboard/system manufacturer makes available.
Skodz
ビギナー
1,119件の閲覧回数
I will look into the motherboard updates but  system manufacturer (Canada computer) didnt help at all when contacted. Updating the bios doesnt risk damaging other component?
AlHill
スーパーユーザー
1,113件の閲覧回数
@Skodz   We are wasting time here.
Download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Skodz
ビギナー
1,109件の閲覧回数
You guys know when Intel rolled out the update ?
Skodz
ビギナー
1,100件の閲覧回数
I must install something from here ?
https://ca.msi.com/Motherboard/PRO-Z790-P-WIFI/support#bios
It seems complicated to update bios -.-
AlHill
スーパーユーザー
1,096件の閲覧回数
If that is your board, then it is pretty self-explanatory.
The latest bios is:  AMI BIOS   7E06vAI20    25-08-18
from just 11 days ago.
If you need help with the bios, contact MSI.
AlHill
スーパーユーザー
1,098件の閲覧回数
ok,  msi made your board.  Open your system and look for a model number on the board.
Then go to MSI's website and find the bios for that board.
Skodz
ビギナー
786件の閲覧回数
what is the difference between bios, drivers, firmware and utility? Which one should I update?
Skodz
ビギナー
786件の閲覧回数
They have a video saying files must be on a usb key for the update, does it matter if there are other files on the key as well when I do it ?
AlHill
スーパーユーザー
778件の閲覧回数
Just contact MSI.
I can no longer respond to this thread.
AlHill
スーパーユーザー
780件の閲覧回数
Skodz
ビギナー
513件の閲覧回数
So I did contact MSI they were more helpful than Canada Computer, they think my cpu is probably fine.
返信
