16840 Discussions
CPU sockets support
I have a laptop which runs an i5 520U CPU which supports a BGA1288 socket, and I would like to swap the CPU to a more powerfull one. most other CPUs that i have looked at support BGA1288 and a PGA988 sockets, I was therefore wondering whether I need to buy a CPU that is specifically designed for a socket, i.e. there are two versions of the same CPU one for each socket, or one CPU that is compatible with both of the sockets.
JChen204
if you use the BGA1288 CPU,you cann't to change the cpu,becasue the CPU is solding in the board.
