16806 Discussions
Can anyone tell me if this is right?
nwalt1
values obtained by core temp 1.0
is this safe? max values occuring with heavy use of the graphics card (GTX 550 Ti)
the graphics card i am having issues with, i basically forgot to clean the computer out and there was a heavy amount of dust in the graphics card fan causing it to overheat and crash. have since fixed this problem but noticed the temperature still isnt great, and the computer does tend to slow right down and struggle which it should do with the specs i have and the kind of games being run.
it doesnt help i have a crap case, that the PSU is at the bottom.. which i have since been told that this can cause over heating as the heat from the psu rises?
anyway ideas guys? do i replace the graphics card (which i really dont want to do because of the cost) or do i replace the case? or could it be the PSU?
Silvia_L_Intel1
Hi Natty123,
Your processor has a TCase value of 72.6°C; anything from the Tcase and below will be the expected temperature of the processor in normal use, anything that doesn't stress out the processor (watching movies, burning CDs, browsing the internet, creating documents, etc.)
When the processor is stressed out meaning that you are running heavy processor applications that take control of the CPU or uses it at 100% the temperature will go beyond the Tcase. It can perfectly reach 80 to 85 degrees and the processor will still be OK. The cooling fan is in charge to keep that temperature there.
If the processor temperature reaches 100 degrees or more it will send a signal to the motherboard to shut down to prevent mayor damages and most likely it will not be possible to turn the computer back in until it cools down.
Intel® has a tool that will test every single component inside the processor and then will generate a report. I recommend you running the tool named Intel® Processor Diagnostics Tool that can be downloaded at the f following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19792&lang=eng&OSVersion=Windows%207%20%2864-bit%29*&DownloadType=Utilities%2C%20Tools%20and%20Examples https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19792&lang=eng&OSVersion=Windows%207%20%2864-bit%29*&DownloadType=Utilities%2C%20Tools%20and%20Examples
Please reply with the results.
nwalt1
run the diagnostic. thank you for your reply, i did a Google search and couldn't find anything similar, i must have been using the wrong keywords!
results:
--- IPDT64 - rev 1.27.0.0 ---
--- Start Time: 06/20/2013 08:54:04---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 60 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i5-2500K 3.30GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 3.30
Detected CPU Frequency is --> 3.29235
CPU Frequency Test Passed!!!
--- FSB NOT Supported on this Processor ---
--- Running Base Clock test ---
Detected Base Clock --> 99
Base Clock test Pass ---
--- Running Floating Point test ---
Million Floating Points per Second, MFLOPS --> 403.2
Floating Point Test Pass ---
--- Running Prime Number Generation Test ---
Operation Per Second--> 5.31663e+006
Prime Number Generation Test Pass ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 4 x 32
- Detected L1 Inst Cache Size --> 4 x 32
- Detected L2 Cache Size --> 1024
- Detected L3 Cache Size --> 6144
Cache Size Test Passed!!!
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
MMX SSE Testing Passed !!
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
AVX AES PCLMULQDQ Testing Passed !!
--- Reading Memory Size ---
Detected Memory Size is --> 8.00GB
--- Integrated Memory Controller Stress Test ---
--- Integrated Memory Controller Stress Test Pass!!! ---
Integrated Memory Controller Test Pass!!!
Chipset : Intel(R) H67 Chipset
Chipset Stepping : B3
2 device connected to PCI Express Port 0
1 : NVIDIA GeForce GTX 550 Ti
2 : High Definition Audio Controller
No device connected to PCI Express Port 1
1 device connected to PCI Express Port 5
1 : PCI standard PCI-to-PCI bridge
1 device connected to PCI Express Port 6
1 : Realtek PCIe GBE Family Controller
1 device connected to PCI Express Port 7
1 : Renesas Electronics USB 3.0 Host Controller
No device connected to PCI Express Port 8
1 device connected to SATA Controller 1
1 : WDC WD3200JD-22KLB0 ATA Device
1 device connected to SATA Controller 2
1 : HL-DT-ST DVD-RAM GH15L ATA Device
2USB devices detected
1 : USB Composite Device
2 : USB Composite Device
1 device connected to Intel High Definition Audio Controller
1 : Realtek High Definition Audio
--- Platform Controller Hub Test Completed!!! ---
..Query 2..
--- Querying for Intel(R) Integrated Graphics Device (IGD) ---
..Did not detect Intel(R) Integrated Graphics Device (IGD).
..This could be that the test platform is using a discrete graphics card.
..To test IGD, verify that there is an onboard video connector,
..shutdown the test platform, remove the graphics card, and
..move video cable from graphics card to onboard video co...
Silvia_L_Intel1
Natty, since the CPU passed the test, what we can recommend you to use the system out of the chassis for a few days, just to discard the chassis is the one causing this temperatures.
If this is the problem, you may want to get a different cooling fan and heat sink and then check if the temperature decrease.
Regards.
nwalt1
have replaced the case and two days in this is the temp difference:
this is lower, is it low enough or should i replace the cpu fan and heat sink?
Silvia_L_Intel1
Are these temperatures readings after heavy usage?
ETuun
If you're using small stock HSF those core temperatures are quite normal for load.
Core temperatures are basically hot spot temperatures from hottest parts of CPU and always well above any generic CPU case/package temperatures.
