16771 Discussions
Can't Update Drivers
I recently upgraded from Windows 7(64 bit) to Windows 10 (64bit) and discovered I needed to update the drivers for my Intel(r) Core(TM) i7-3820 CPU @ 3.60 GHZ. I've tried using Intel Driver Update Utility and continue to get an error. Below is a copy of the log:
Chipset_20160414210940 Log:
[1FA4:1700][2016-04-14T21:09:39]i001: Burn v3.7.1224.0, Windows v6.2 (Build 9200: Service Pack 0), path: C:\Users\Teagen\Downloads\Intel Components\SetupChipset.exe, cmdline: '-burn.unelevated BurnPipe.{43BC9F49-CC7B-4265-B0B7-5FCA408276BA} {5E070E05-59AD-4A8A-ACFD-FA1996590A1B} 7648'
[1FA4:1700][2016-04-14T21:09:39]i000: Initializing string variable 'IIF_ProductVersion' to value '10.1.1.14'
[1FA4:1700][2016-04-14T21:09:39]i000: Initializing string variable 'IIF_InstallerVersion' to value '3.1.6'
[1FA4:1700][2016-04-14T21:09:39]i000: Initializing string variable 'IIF_ExtractionMapping_SetupChipsetx86.msi' to value ';NullDrivers.cab;NOT VersionNT64'
[1FA4:1700][2016-04-14T21:09:39]i000: Initializing string variable 'IIF_ExtractionMapping_SetupChipsetx64.msi' to value ';NullDrivers.cab;VersionNT64'
[1FA4:1700][2016-04-14T21:09:40]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Teagen\AppData\Local\Temp\Intel\Logs\Chipset_20160414210940.log'
[1FA4:1700][2016-04-14T21:09:40]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Teagen\Downloads\Intel Components\SetupChipset.exe'
[1FA4:1700][2016-04-14T21:09:40]i052: Condition 'VersionNT >= v6.1 OR (VersionNT = v6.0 AND NTProductType = 3)' evaluates to true.
[1FA4:1700][2016-04-14T21:09:40]i000: Setting string variable 'WixBundleName' to value 'Intel(R) Chipset Device Software'
[1FA4:1700][2016-04-14T21:09:40]i000: Loading managed bootstrapper application.
[1FA4:1700][2016-04-14T21:09:40]i000: Creating BA thread to run asynchronously.
[1FA4:1614][2016-04-14T21:09:40]i000: ** MBA ** Command line:
[1FA4:1614][2016-04-14T21:09:40]i000: Setting string variable 'WixBundleName' to value 'Intel(R) Chipset Device Software'
[1FA4:1614][2016-04-14T21:09:40]i000: ** MBA ** Calling Engine.Detect()
[1FA4:1700][2016-04-14T21:09:40]i100: Detect begin, 3 packages
[1FA4:1700][2016-04-14T21:09:40]i000: Setting string variable 'DotNet35' to value '1'
[1FA4:1700][2016-04-14T21:09:40]i000: Setting string variable 'DotNet40Client' to value '1'
[1FA4:1700][2016-04-14T21:09:40]i000: Setting string variable 'DotNet40Full' to value '1'
[1FA4:1700][2016-04-14T21:09:40]i000: Setting string variable 'DotNet45' to value '394254'
[1FA4:1700][2016-04-14T21:09:40]i052: Condition 'DotNet35 OR DotNet40Client OR DotNet40Full OR (DotNet45 >= 378389)' evaluates to true.
[1FA4:1700][2016-04-14T21:09:40]i101: Detected package: DotNet45, state: Present, cached: None
[1FA4:1700][2016-04-14T21:09:40]i101: Detected package: SetupChipsetx86.msi, state: Absent, cached: None
[1FA4:1700][2016-04-14T21:09:40]i104: Detected package: SetupChipsetx86.msi, feature: NullDriverFeature, state: Absent
[1FA4:1700][2016-04-14T21:09:40]i104: Detected package: SetupChipsetx86.msi, feature: PackageVersionFeature, state: Absent
[1FA4:1700][2016-04-14T21:09:40]i104: Detected package: SetupChipsetx86.msi, feature: LicenseAgreementFeature, state: Absent
[1FA4:1700][2016-04-14T21:09:40]i101: Detected package: SetupChipsetx64.msi, state: Absent, cached: None
[1FA4:1700][2016-04-14T21:09:40]i104: Detected package: SetupChipsetx64.msi, feature: NullDriverFeature, state: Absent
[1FA4:1700][2016-04-14T21:09:40]i104: Detected package: SetupChipsetx64.msi, feature: PackageVersionFeature, state: Absent
[1FA4:1700][2016-04-14T21:09:40]i104: Detected package: SetupChipsetx64.msi, feature: LicenseAgreementFeature, state: Absent
[1FA4:1700][2016-04-14T21:09:40]i199: Detect complete, result: 0x0
[1FA4:1700][2016-04-14T21:09:44]i200: Plan begin, 3 packages, action: Install
[1FA4:1700][2016-04-14T21:09:44]w321: Skipping dependency registration on package with no dependency providers: DotNet45
[1FA4:1700][2016-04-14T21:09:44]i052: Condition 'NOT VersionNT64' evaluates to false.
[1FA4:1700][2016-04-14T21:09:44]i204: Plan 3 msi features for package: SetupChipsetx86.msi
[1FA4:1700][2016-04-14T21:09:44]i203: Planned feature: NullDriverFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[1FA4:1700][2016-04-14T21:09:44]i203: Planned feature: PackageVersionFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[1FA4:1700][2016-04-14T21:09:44]i203: Planned feature: LicenseAgreementFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[1FA4:1700][2016-04-14T21:09:44]i052: Condition 'VersionNT64' evaluates to true.
[1FA4:1700][2016-04-14T21:09:44]i204: Plan 3 msi features for package: SetupChipsetx64.msi
[1FA4:1700][2016-04-14T21:09:44]i000: Setting string variable 'WixBundleRollbackLog_SetupChipsetx64.msi' to value 'C:\Users\Teagen\AppData\Local\Temp\Intel\Logs\Chipset_20160414210940_0_SetupChipsetx64.msi_rollback.log'
[1FA4:1700][2016-04-14T21:09:44]i000: Setting string variable 'WixBundleLog_SetupChipsetx64.msi' to value 'C:\Users\Teagen\AppData\Local\Temp\Intel\Logs\Chipset_20160414210940_0_SetupChipsetx64.msi.log'
[1FA4:1700][2016-04-14T21:09:44]i201: Planned package: DotNet45, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1FA4:1700][2016-04-14T21:09:44]i201: Planned package: SetupChipsetx86.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1FA4:1700][2016-04-14T21:09:44]i201: Planned package: SetupChipsetx64.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[1FA4:1700][2016-04-14T21:09:44]i299: Plan complete, result: 0x0
[1FA4:1614][2016-04-14T21:09:44]i000: Setting string variable 'IIF_MSI_SWITCHES' to value ''
[1FA4:1614][2016-04-14T21:09:44]i000: ** MBA ** Getting window handle.
[1FA4:1614][2016-04-14T21:09:44]i000: ** MBA ** Calling Engine.Apply(). Window handle: 131792
[1FA4:1700][2016-04-14T21:09:44]i300: Apply begin
[1DE0:12BC][2016-04-14T21:09:44]i000: Caching bundle from: 'C:\Users\Teagen\AppData\Local\Temp\{619e726e-d2b4-4e28-9568-c964fd81ee6c}\.be\SetupChipset.exe' to: 'C:\ProgramData\Package Cache\{619e726e-d2b4-4e28-9568-c964fd81ee6c}\SetupChipset.exe'
[1DE0:12BC][2016-04-14T21:09:44]i320: Registering bundle dependency provider: {619e726e-d2b4-4e28-9568-c964fd81ee6c}, version: 10.1.1.14
[1DE0:1720][2016-04-14T21:09:44]i305: Verified acquired payload: SetupChipsetx64.msi at path: C:\ProgramData\Package Cache\.unverified\SetupChipsetx64.msi, moving to: C:\ProgramData\Package Cache\{FEBB7B48-CC1C-4A50-A497-FA21413F6BE9}v10.1.1.14\SetupChipsetx64.msi.
[1DE0:1720][2016-04-14T21:09:44]i305: Verified acquired payload: cab4FADBDD6DC6637E75E196F741A3F14D1 at path: C:\ProgramData\Package Cache\.unverified\cab4FADBDD6DC6637E75E196F741A3F14D1, moving to: C:\ProgramData\Package Cache\{FEBB7B48-CC1C-4A50-A497-FA21413F6BE9}v10.1.1.14\media1.cab.
[1DE0:12BC][2016-04-14T21:09:4...
Hello, Teagen:
Thank you for contacting the Intel Communities.
In this case, I recommend you to install the drivers manually.
Here you can find the drivers for graphics:
https://downloadcenter.intel.com/download/25698/Intel-Graphics-Driver-for-Windows-7-and-8-1-and-Windows-10-15-33-?product=81499 https://downloadcenter.intel.com/download/25698/Intel-Graphics-Driver-for-Windows-7-and-8-1-and-Windows-10-15-33-?product=81499
Please make sure you download and install the drivers for your OS type (64/32-bit).
Drivers for chipset would be provided by the manufacturer of your board, if not available, then Windows 10* updates would be the way to go, meaning that installing all Windows updates should give you the drivers to make the system work properly.
Additionally, I would like to recommend you to check this article related to this scenario: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html
If any additional questions or inquiries are present, feel free to contact us back.
Esteban C
Hello, Teagen:
Esteban C
