17162 Discussions
Can't install XTU, and intel driver
asd123
I'm using i7-14700k
some games not working properly, and someone said install XTU
i tried install latest XTU from this site
and i got this message
so now i had to install intel driver?
i download latest intel driver installer.exe from this site.
when i run it, i got these error log
[671C:79E0][2024-10-07T11:45:50]i001: Burn v3.14.1.8722, Windows v10.0 (Build 22631: Service Pack 0), path: D:\TMP\{AEE25A9A-9306-4B9F-B3B8-371C9644EBCB}\.cr\XTUSetup_7.14.2.14.exe
[671C:79E0][2024-10-07T11:45:50]i000: Initializing string variable 'RemoveAllDataCheckboxValue' to value '[RemoveAllDataCheckbox]'
[671C:79E0][2024-10-07T11:45:50]i000: Initializing version variable 'BundleVersionNumber' to value '7.14.2.14'
[671C:79E0][2024-10-07T11:45:50]i009: Command Line: '-burn.clean.room=D:\Download\XTUSetup_7.14.2.14.exe -burn.filehandle.attached=524 -burn.filehandle.self=520'
[671C:79E0][2024-10-07T11:45:50]i000: Setting string variable 'WixBundleOriginalSource' to value 'D:\Download\XTUSetup_7.14.2.14.exe'
[671C:79E0][2024-10-07T11:45:50]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'D:\Download\'
[671C:79E0][2024-10-07T11:45:50]i000: Setting string variable 'WixBundleLog' to value 'D:\TMP\Intel(R)_Extreme_Tuning_Utility_20241007114550.log'
[671C:79E0][2024-10-07T11:45:50]i052: Condition 'VersionNT >= v6.1' evaluates to true.
[671C:79E0][2024-10-07T11:45:50]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel Corporation'
[671C:64D4][2024-10-07T11:45:50]i000: Setting version variable 'WixBundleFileVersion' to value '7.14.2.14'
[671C:79E0][2024-10-07T11:45:51]i100: Detect begin, 2 packages
[671C:79E0][2024-10-07T11:45:51]i000: Setting version variable 'MsiAlreadyInstalledVersion' to value '7.14.2.14'
[671C:79E0][2024-10-07T11:45:51]i000: Setting string variable 'NETFRAMEWORK45' to value '533320'
[671C:79E0][2024-10-07T11:45:51]i000: Setting version variable 'WindowsDllVersion' to value '10.0.22621.3810'
[671C:79E0][2024-10-07T11:45:51]i101: Detected package: vcredist_64.exe, state: Absent, cached: Complete
[671C:79E0][2024-10-07T11:45:51]i101: Detected package: Intel_XtuInstaller.msi, state: Present, cached: Complete
[671C:79E0][2024-10-07T11:45:51]i052: Condition 'BundleVersionNumber > MsiAlreadyInstalledVersion OR BundleVersionNumber = "0.0.0.0" OR NOT WixBundleAction = 5' evaluates to false.
[671C:79E0][2024-10-07T11:45:51]e000: Another flavor of the XTU application of a same or higher version is already installed. Uninstall the following from Add/Remove Programs: Intel(R) Extreme Tuning Utility
[671C:79E0][2024-10-07T11:45:51]e000: Error 0x81f40001: Bundle condition evaluated to false: BundleVersionNumber > MsiAlreadyInstalledVersion OR BundleVersionNumber = "0.0.0.0" OR NOT WixBundleAction = 5
[671C:79E0][2024-10-07T11:45:51]i199: Detect complete, result: 0x0
[671C:79E0][2024-10-07T11:46:06]i500: Shutting down, exit code: 0x1
[671C:79E0][2024-10-07T11:46:06]i410: Variable: BundleVersionNumber = 7.14.2.14
[671C:79E0][2024-10-07T11:46:06]i410: Variable: MsiAlreadyInstalledVersion = 7.14.2.14
[671C:79E0][2024-10-07T11:46:06]i410: Variable: NETFRAMEWORK45 = 533320
[671C:79E0][2024-10-07T11:46:06]i410: Variable: RemoveAllDataCheckboxValue =
[671C:79E0][2024-10-07T11:46:06]i410: Variable: System64Folder = C:\WINDOWS\system32\
[671C:79E0][2024-10-07T11:46:06]i410: Variable: VersionNT = 10.0.0.0
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WindowsDllVersion = 10.0.22621.3810
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleAction = 5
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleElevated = 0
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleFileVersion = 7.14.2.14
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleInstalled = 1
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleLog = D:\TMP\Intel(R)_Extreme_Tuning_Utility_20241007114550.log
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleManufacturer = Intel Corporation
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleName = Intel(R) Extreme Tuning Utility
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleOriginalSource = D:\Download\XTUSetup_7.14.2.14.exe
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleOriginalSourceFolder = D:\Download\
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleProviderKey = {fdc445a5-0180-47a6-a653-ab97fa2d4723}
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleSourceProcessFolder = D:\Download\
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleSourceProcessPath = D:\Download\XTUSetup_7.14.2.14.exe
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleTag =
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleUILevel = 4
[671C:79E0][2024-10-07T11:46:06]i410: Variable: WixBundleVersion = 7.14.2.14
[671C:79E0][2024-10-07T11:46:06]i007: Exit code: 0x1, restarting: No
can i use your products normally? i already paid tho.
asd123
this lazy community doesn't have any help
intel fell off too much...
