16774 Discussions
Can’t reach turbo boost on i5-3470
Jgkladden
My Intel core i5-3470 won’t reach turbo boost 3,6Ghz. Base clock speed is 3,20Ghz. I have a problem with gaming since my cpu is bottlenecking my gpu. So I would really like to get that speed I want. Turbo boost is enabled in bios. I’ve even tried downloading some apps to reach turbo boost. But I only get it to 3,39ghz? Can you help me?
n_scott_pearson
I am not sure that you understand how this feature works. The achievable TB ratio varies (and drops) based upon the number of cores that are active. Other factors - temperature, power, etc. - can limit the amount of time that TB will remain active.
For more information, I suggest the following readings:
Hope this helps,
Jgkladden
I understand that, but my cpu is not running too hot. And it’s at 100% when playing games. It’s sitting at 3,39ghz the whole time I’m playing. All cores are active, is this why it won’t go higher? Will it reach 3,6ghz if I only run at for example 2 cores?
IsaacQ_Intel
Hello Jgkladden
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, I am glad to see that fellow community members have the knowledge and they jumped in and helped. You may also find the Discontinued Products website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued".
Isaac Q.
