16761 Discussions
Celeron G3930TE CPU(spec TDP 35W),use intel TAT tool CPU package power can only run bellow 35W
LHuan1
Description
1.our thermal design is good ,and there is no cpu or gpu throttling
2.there is no ctdp or pl1/pl2/plx limitation
3.other cpu is ok (skl-s/kbl-s i5/i7 ...)
1.flash bios
2.install os and driver ,intel TAT6.0
3.set TAT workload to 100% and run
4.from TAT tool we can see the "cpu compent"->"package power" < 35W (from intel ark webset we can see the TDP is 35W)
HW:h110
cpu:Celeron G3930TE CPU(spec TDP 35W)
RC version: 3.7.5
os:win10-64
AndrewG_Intel
Hello LHuan1,
I would like to clarify some details regarding your inquiry.
1- Are you experiencing performance or overheating issues with the Intel® Celeron® Processor G3930TE?
2- Are you having issues with the Intel® Thermal Analysis Tool (TAT 6)?
3- Is this regarding Configurable TDP (cTDP), power levels (PL2) and sustained load on the CPU (PL1)
4- Are you deploying or designing custom systems or thermal solutions?
Andrew G.
A Contingent Worker at Intel
LHuan1
A.from intel ark webset ,ther G3930TE TDP is 35w ,but with TAT6.0 100% loading,the package power is bellow 35W( at most 20w).
with the same bios/heat sink,other cpu is ok203970866416
A.we use the newest version TAT6 which download from intel webset
A.PL1 and PL2 all above 35W,and other cpu use the same PL1/pl2 setting has no issue
A.no, we design MB ,and we can found that our thermal solution is fine for this case,and there is no cpu or gpu throttling
AndrewG_Intel
Hello LHuan1,
Thank you for your response.
After checking the details provided, for inquiries regarding Intel® Thermal Analysis Tool (TAT 6), including how to install and use the products, defective parts, or warranties, please go to Design-In Tools Store, scroll down to section "Technical Support" and send an email to specified contact options:
  • Design development tools support
  • Schematic Review support
Design-In Tools Store link:
https://designintools.intel.com/Customer-Service-a/251.htm
We will proceed to close this inquiry and thank you for posting on the Intel® Community.
Andrew G.
