16790 Diskussionen
Changing Graphic card
nipung10157
Einsteiger
1.714Aufrufe
I have this Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz 2.10 GHz processor i want to upgrade it as it is too slow and no game works at it can i d othat pls check
5 Antworten
AlHill
Superuser
1.710Aufrufe
Well, if this is a laptop, then there is nothing you can do as the processor is soldered to the motherboard.
If you are a desktop, then you might be able to add a graphics card.
However, the best solution is to plan for an upgrade to something with an 8th gen processor or later.
[Windows 11 is the new Vista]
nipung10157
Einsteiger
1.707Aufrufe
hmm can i change processor
AlHill
Superuser
1.702Aufrufe
As I said, the processor is soldered to the motherboard.  Contact the manufacturer of your device to determine if they offer some option for replacement.  It is not likely, but is worth a try.
nipung10157
Einsteiger
1.701Aufrufe
can i change motherboard
AlHill
Superuser
1.698Aufrufe
"can i change motherboard"
That is the part where I said contact the device manufacturer.  Only they can tell you.
Antworten
