16842 Discussions
Core I7-7700 processor virtualization thechologies support issue
PKhar3
I have a Core I7-7700 processor and according to the https://ark.intel.com it's announced to have all virtualization thechologies support, yet it doesn't work and if I check my system with Intel(R) Processor Identification Utility I can see that my I7-7700 Does support no one virtualization technology. How come?
P.S. There are active options Intel virtualization and Intel VT-D in the bios and they are enabled. But I have no virtualization support in OS.
AlHill
As you say, it documented to have all the VT-x you want:
https://ark.intel.com/content/www/us/en/ark/products/97128/intel-core-i7-7700-processor-8m-cache-up-to-4-20-ghz.html
You may want to run: https://downloadcenter.intel.com/download/19792
I can think of two possibilities: Your motherboard BIOS is the problem, or you have hyper-v on. Once hyper-v is on, you will not see the VT-x as available in the IPDT.
Doc
PKhar3
Thanks for your answer! You was almost right.
I reinstall Windows and virtualization technologies got working. Unfortunately, once I installed the Windows Sandbox it stopped working again.
And Windows Sandbox removing didn't help to solve the issue, so I'll reinstall Windows again.
Therefore not only hyper-v can make problem but Windows Sandbox too.
AlHill
Glad you got it working. The sandbox uses hyper-v as well. And, once you install hyper-v or sandbox, it is almost impossible to turn them off or uninstall them.
Doc
PKhar3
Thanks a lot. Fortunately I managed to totally remove Windows Sandbox as well as hyper-v with the next manual https://support.bluestacks.com/hc/ru/articles/115004254383-%D0%9A%D0%B0%D0%BA-%D0%BE%D1%82%D0%BA%D0%BB%D1%8E%D1%87%D0%B8%D1%82%D1%8C-Hyper-V-%D0%B2-Windows-
The article is written in russian, as it's my first language I have so I had no problem with the article, and it really worked at least for me. It might be useful for somebody else with the same issue.
AlHill
Glad you have it removed. I gave up on mine, and did a reinstall.
Doc
