16790 Discussions
Core Ultra memory performance drops after power cycle
AndreyR
Débutant
1 857 Visites
Hello
I have the following problem CPU 265K, Asus TUF GAMING Z890-PLUS WIFI
I activate the XMP 8400 profile and set D2D and NGU 32
Everything works fine, I turn off the PC and then turn it on, the write speed drops and the latency increases.
But if the PC is completely de-energized and then turned on, Everything is restored, and so on until the first shutdown.
0 Compliments
9 Réponses
ArchieD_Intel
Modérateur
1 772 Visites
Hi AndreyR,
  • Is this working fine before?
  • Have you tried disabling XMP to see if the issue still persists?
  • Did you overclock the processor?
  • What are the troubleshooting steps that you tried so far?
  • Is your BIOS currently updated?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
0 Compliments
AndreyR
Débutant
1 718 Visites
  • Hello Archie D
  • The PC is new, the problem arose immediately and many people have it.
  • If you disable XMP the problem disappears, the problem starts if the memory frequency is higher than 8000 MT/s
  • Dis you overclock the processor?
  • No, I just increased D2D and NGU to 32.
  • I changed the power settings in the BIOS and Windows, but only a complete shutdown of the PC with disconnection from the network helps
  • BIOS latest
  • The problem looks like this
0 Compliments
AndreyR
Débutant
1 715 Visites
0 Compliments
ArchieD_Intel
Modérateur
1 708 Visites
Hi AndreyR,
Thank you for the feedback. I will investigate this and will update you as soon as possible. Thank you for your patience.
Archie D.
0 Compliments
AndreyR
Débutant
1 666 Visites
please sort this out
Respectfully,
AndreyR
0 Compliments
AndreyR
Débutant
1 386 Visites
Looks like I won't get an answer to my question, or?
0 Compliments
ArchieD_Intel
Modérateur
1 312 Visites
Hi AndreyR,
Upon checking the information, it appears there is a discrepancy between the BIOS versions. The screenshot indicates BIOS version 2005, whereas the SSU logs show version 2207.
To ensure accurate testing and optimal performance, we recommend updating your system to the latest BIOS version. Once updated, please conduct the tests again with the 200S boost enabled and the desired XMP profile, without making any additional tweaks.
After completing these steps, kindly inform us of the results so we can assist you further.
Thank you for your cooperation and understanding.
Archie D.
0 Compliments
ArchieD_Intel
Modérateur
1 088 Visites
Hi AndreyR,
I just wanted to follow up to see if you had a chance to review the information I posted. Your feedback at your earliest convenience would be greatly appreciated. Thank you.
Archie D.
0 Compliments
ArchieD_Intel
Modérateur
823 Visites
Hi AndreyR,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Archie D.
0 Compliments
Répondre
