16841 Discussions
Disable I2C bus using I2C Serial IO Control drivers in the INTEL Chip.
rrama29
Required: - Way to turn off I2C functionality
Way: - Turn off I2C functionality in coffee lake I2C chipset based Serial IO Control driver.
Is there any document available on design resource center which details/discuss about I2C host controller driver?
n_scott_pearson
The i2c controllers are documented in the Chipset (PCH) and Processor I/O ​data sheets. Generational data sheets can be accessed from here: https://www.intel.com/content/www/us/en/products/docs/processors/core/core-technical-resources.html.
H​ope this helps,
