16769 Discussões
Does the Z370 and Z390 series motherboard automatically support turbo boost for i5-9600K? A lot of the motherboards I see just says it's compatible.
DGlid
Principiante
2.179 Visualizações
1 Responder
Leonardo_C_Intel
Moderador
1.309 Visualizações
Hello DGlid Thank you for posting in the Intel Community. The Intel® turbo boost technology is included on the Intel® Core™ i5-9600K Processor (https://ark.intel.com/products/134896/Intel-Core-i5-9600K-Processor-9M-Cache-up-to-4-60-GHz-) to be enable on the system this has to be done on the Motherboard BOIS in order to confirm if this feature has to be manually enable or if it is automatically enable you need to confirm it with the motherboard Original Equipment Manufacturer (OEM). Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Responder
