The Driver and Support Assistant tells me "Sorry, something went wrong while trying to scan". I've tried it multiple days; no difference.
System specs
Core i3-3110M 2.4 ghz
ram 4 GB
Win 10 Home ( v 21H1 )
build 19043.1526
Hello randallw,
Thank you for the information provided, in this case, please try the following:
1. Clear the browser cache and close the browser.
2. Try rescanning Intel® Driver & Support Assistant (Intel® DSA)
If this doesn't result in the Intel® DSA scan working correctly, try the following:
1. Uninstall the existing Intel® Driver & Support Assistant (Intel® DSA) tool in the system using the Uninstaller tool.
2. Download and install the latest Intel® DSA version
Some additional steps that can be taken if the Intel® DSA scan still isn't working correctly:
1. Ensure the Intel® DSA Service shows a status of Running.
a. In Windows Search, type Services and scroll to find Intel(R) Driver & Support Assistant.
b. Confirm the Status shows Running; start the service if necessary by right-clicking.
2. Check to see if any Windows* updates are pending.
3. Restart the system.
Josue O.
链接已复制
Hello randallw,
Thank you for posting on the Intel
- Was it working before?
- When did the issue start happening?
- Were any changes made recently to the system?
- Browser being used.
- Browser version.
Josue O.
Hello randallw,
Josue O.
Intel® Driver & Support Assistant will not work on all Windows 10 browsers. Try Chrome or Edge.
Hello randallw,
Josue O.
Hello randallw,
I am glad to hear that the issue is now solved and everything is working fine.
Josue O.
