16764 토론
Driver for 5 Series/3400 Series Chipset HECI Controller
Andrew4666
초보자
49,320 조회수
Hi All
I hope someone can help me.
I noticed drive issue in the device manager - PCI Simple Communication Controller.
I tried to reinstall driver but no luck.
I checked the device id PCI\VEN_8086&DEV_3B64&SUBSYS_C0A2144D&REV_06\3&11583659&0&B0  and it is referring to  5 Series/3400 Series Chipset HECI Controller.
Can someonce advise where can i download the correct driver for this device?
My system is WIN  7 64 bits.
Thank you all .
0 포인트
13 응답
n_scott_pearson
수퍼 사용자
49,302 조회수
Attached is what I had in my archive for 5 Series chipsets.
Andrew4666
초보자
49,296 조회수
0 포인트
Chris79
초급자
37,447 조회수
Thank you Scott.
I had the same problem.
Your HECI 6.0 did the job for me.
Regards, Chris79
0 포인트
AdrianM_Intel
직원
49,234 조회수
Hello Andrew4666,
Were you able to try the steps suggested by Scott Pearson? If the issue persists, please provide the model of the motherboard/system you have.
Adrian M.
0 포인트
Andrew4666
초보자
49,202 조회수
Hi Adrian
Thanks for the response.
I have no luck using Scott provided steps, problem still persists.
Please find my motherboard information as below.
Thank you for your assistance. Let me know if you need more information.
Andrew
0 포인트
n_scott_pearson
수퍼 사용자
49,180 조회수
@Andrew4666How did you try to install this version of HECI?
0 포인트
Andrew4666
초보자
49,172 조회수
Hi Scott
I saved the files in a local folder. Manually update the device's driver via device manager and point to the folder that I saved in local.
Andrew
0 포인트
n_scott_pearson
수퍼 사용자
49,149 조회수
And what specifically did it say when you tried to install it?
0 포인트
Andrew4666
초보자
49,118 조회수
Hi Scott
Please find below the message i received when installing the driver.
Andrew
0 포인트
n_scott_pearson
수퍼 사용자
49,114 조회수
Name already exists? I don't understand.
Are you seeing this name in Device Manager (under System Devices)?
0 포인트
Andrew4666
초보자
49,089 조회수
Hi Scott
Nope, I didn't see device in under System device.
I tried to update the driver again for the "unknown device", but now I see a different message.
Andrew
0 포인트
AdrianM_Intel
직원
49,187 조회수
Hello Andrew4666,
Thank you for your response.
The support for Intel® 3400 Chipset has been discontinued Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request.
https://www.intel.com/content/www/us/en/support/discontinued-products.html
Upon checking the information provided I can see that this is a Samsung computer so my recommendation is to contact the OEM (Original Equipment Manufacturer) Samsung and look for the chipset driver on their official website, especially since this is a chipset driver, the OEMs customize the drivers for their systems.
Based on the error code 28, it indicates that the driver is not installed.
https://www.samsung.com/us/support/
Adrian M.
0 포인트
n_scott_pearson
수퍼 사용자
49,069 조회수
Something you've installed previously is asserting this name. This is a new one on me. I have no idea what to do about it. Does anyone else?
0 포인트
응답
