16771 Diskussionen
Driver for 5 Series/3400 Series Chipset HECI Controller
Andrew4666
Anfänger
49.394Aufrufe
Hi All
I hope someone can help me.
I noticed drive issue in the device manager - PCI Simple Communication Controller.
I tried to reinstall driver but no luck.
I checked the device id PCI\VEN_8086&DEV_3B64&SUBSYS_C0A2144D&REV_06\3&11583659&0&B0  and it is referring to  5 Series/3400 Series Chipset HECI Controller.
Can someonce advise where can i download the correct driver for this device?
My system is WIN  7 64 bits.
Thank you all .
13 Antworten
n_scott_pearson
Superuser
49.376Aufrufe
Attached is what I had in my archive for 5 Series chipsets.
Andrew4666
Anfänger
49.370Aufrufe
Chris79
Einsteiger
37.521Aufrufe
Thank you Scott.
I had the same problem.
Your HECI 6.0 did the job for me.
Regards, Chris79
AdrianM_Intel
Mitarbeiter
49.308Aufrufe
Hello Andrew4666,
Were you able to try the steps suggested by Scott Pearson? If the issue persists, please provide the model of the motherboard/system you have.
Adrian M.
Andrew4666
Anfänger
49.276Aufrufe
Hi Adrian
Thanks for the response.
I have no luck using Scott provided steps, problem still persists.
Please find my motherboard information as below.
Thank you for your assistance. Let me know if you need more information.
Andrew
n_scott_pearson
Superuser
49.254Aufrufe
@Andrew4666How did you try to install this version of HECI?
Andrew4666
Anfänger
49.246Aufrufe
Hi Scott
I saved the files in a local folder. Manually update the device's driver via device manager and point to the folder that I saved in local.
Andrew
n_scott_pearson
Superuser
49.223Aufrufe
And what specifically did it say when you tried to install it?
Andrew4666
Anfänger
49.192Aufrufe
Hi Scott
Please find below the message i received when installing the driver.
Andrew
n_scott_pearson
Superuser
49.188Aufrufe
Name already exists? I don't understand.
Are you seeing this name in Device Manager (under System Devices)?
Andrew4666
Anfänger
49.163Aufrufe
Hi Scott
Nope, I didn't see device in under System device.
I tried to update the driver again for the "unknown device", but now I see a different message.
Andrew
AdrianM_Intel
Mitarbeiter
49.261Aufrufe
Hello Andrew4666,
Thank you for your response.
The support for Intel® 3400 Chipset has been discontinued Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request.
https://www.intel.com/content/www/us/en/support/discontinued-products.html
Upon checking the information provided I can see that this is a Samsung computer so my recommendation is to contact the OEM (Original Equipment Manufacturer) Samsung and look for the chipset driver on their official website, especially since this is a chipset driver, the OEMs customize the drivers for their systems.
Based on the error code 28, it indicates that the driver is not installed.
https://www.samsung.com/us/support/
Adrian M.
n_scott_pearson
Superuser
49.143Aufrufe
Something you've installed previously is asserting this name. This is a new one on me. I have no idea what to do about it. Does anyone else?
Antworten
