16771 Discusiones
Driver for 5 Series/3400 Series Chipset HECI Controller
Andrew4666
Novato
49.416 Vistas
Hi All
I hope someone can help me.
I noticed drive issue in the device manager - PCI Simple Communication Controller.
I tried to reinstall driver but no luck.
I checked the device id PCI\VEN_8086&DEV_3B64&SUBSYS_C0A2144D&REV_06\3&11583659&0&B0  and it is referring to  5 Series/3400 Series Chipset HECI Controller.
Can someonce advise where can i download the correct driver for this device?
My system is WIN  7 64 bits.
Thank you all .
0 kudos
13 Respuestas
n_scott_pearson
Superusuario
49.398 Vistas
Attached is what I had in my archive for 5 Series chipsets.
Andrew4666
Novato
49.392 Vistas
Thank you Scott, I will try it out .
Chris79
Principiante
37.543 Vistas
Thank you Scott.
I had the same problem.
Your HECI 6.0 did the job for me.
Regards, Chris79
AdrianM_Intel
Empleados
49.330 Vistas
Hello Andrew4666,
Were you able to try the steps suggested by Scott Pearson? If the issue persists, please provide the model of the motherboard/system you have.
Adrian M.
Andrew4666
Novato
49.298 Vistas
Hi Adrian
Thanks for the response.
I have no luck using Scott provided steps, problem still persists.
Please find my motherboard information as below.
Thank you for your assistance. Let me know if you need more information.
Andrew
n_scott_pearson
Superusuario
49.276 Vistas
@Andrew4666How did you try to install this version of HECI?
Andrew4666
Novato
49.268 Vistas
Hi Scott
I saved the files in a local folder. Manually update the device's driver via device manager and point to the folder that I saved in local.
Andrew
n_scott_pearson
Superusuario
49.245 Vistas
And what specifically did it say when you tried to install it?
Andrew4666
Novato
49.214 Vistas
Hi Scott
Please find below the message i received when installing the driver.
Andrew
n_scott_pearson
Superusuario
49.210 Vistas
Name already exists? I don't understand.
Are you seeing this name in Device Manager (under System Devices)?
Andrew4666
Novato
49.185 Vistas
Hi Scott
Nope, I didn't see device in under System device.
I tried to update the driver again for the "unknown device", but now I see a different message.
Andrew
AdrianM_Intel
Empleados
49.283 Vistas
Hello Andrew4666,
Thank you for your response.
The support for Intel® 3400 Chipset has been discontinued Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request.
https://www.intel.com/content/www/us/en/support/discontinued-products.html
Upon checking the information provided I can see that this is a Samsung computer so my recommendation is to contact the OEM (Original Equipment Manufacturer) Samsung and look for the chipset driver on their official website, especially since this is a chipset driver, the OEMs customize the drivers for their systems.
Based on the error code 28, it indicates that the driver is not installed.
https://www.samsung.com/us/support/
Adrian M.
n_scott_pearson
Superusuario
49.165 Vistas
Something you've installed previously is asserting this name. This is a new one on me. I have no idea what to do about it. Does anyone else?
Responder
