16766 Discussions
Drivers for Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz 2.71 GHz
Gigi144
I'm looking in Intel website for the following drivers:
sm bus controller
pci memory controller
Simple Communications PCI Controller
for the mother board in the subject because a yellow triangle with exclamation mark is shown aside these devices but I'm unable to find them.
PC is a HP Pavilion 510-310nl with Windows 10 Home ver. 22H2
Any suggestions?
Many thanks.
n_scott_pearson
First, unless you've done so already, you should install the latest BIOS package provided on the HP downloads page for your system (here).
Second, you need to download and install (in order, with a reboot in between) the following packages:
  1. Intel Chipset Device Software (HP calls it 'Intel Chipset Driver').
  2. Intel Management Engine Interface (HP calls it 'Intel Management Engine Interface Driver').
Hope this helps,
Gigi144
After some troubles I encountered downloading the files, due to the lack of the folder where they were going to be saved, I succeedeed but at the end an exclamation mark remained on the other devices, so I found the way to eliminate them unflagging them from some Apple devices I had connected to the PC.
