16777 Discussions
Excessive loading CPU i5 6600
aalex24
Hello!
Recently acquired i5 6600 and motherboard b150m-a d3. It worked , but the processor does not reveal itself properly and in some games unnatural loaded 100% . With what it can be connected and how to fix it ?
Examples : Overwatch load of 80-90 % , with a program stream OBS 100% load and lag and the game , and stream . Have a friend on the 4690 and 3570 - the CPU load of not more than 60 % .
The same problem with Dark souls 3 .
And some games 2012-2015 year show downloads by 100%.
Hello, AlexDeFenDeR :
  • Are you using any particular setting for the games?
  • Could you please let us know the Intel® HD Graphics driver version you are running? Please go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed.
Amy.
aalex24
Hello,Amy!
I used different graphics settings , but in any case there is too heavy load on the processor .
And at the expense of drivers , I have it turned off in the BIOS so that it does not load the processor .
Could there be a problem is that I am using ddr3 memory ? I know that Intel does not recommend the use of skylake processors ddr3, but the system is working? I'm afraid that if the problem is not the case, then I will spend the extra money for the purchase of the motherboard and DDR4 . Therefore, I do not want to exclude that the problem in a processor , or even in something .
Well, the recommended the memory for your processor is;
If you are running DDR3 that could be the source of the issue. Is there any chance you can run your motherboard with the memory specification mentioned above?
Amy.
Were you able to track this down?
Let me know your findings.
Amy.
