16771 Discussions
Fails with xeon e5-2640 V4 processors
dcres
When performing the installation of a second processor on the board asus z10pe-d16 occurs the fault that does not recognize the memories assigned to the second processor
Hello d.crespo:
According to the information in our web site the memory the is fully supported by the Intel® E5-2640 v4 are DDR4 1600/1866/2133, as you can confirm on the following link:
http://ark.intel.com/products/92984/Intel-Xeon-Processor-E5-2640-v4-25M-Cache-2_40-GHz# @specifications http://ark.intel.com/products/92984/Intel-Xeon-Processor-E5-2640-v4-25M-Cache-2_40-GHz# @specifications
Also on the following link you will be able to see further information about the memory that is supported by that processor:
http://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-v4-datasheet-vol-1.html http://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-v4-datasheet-vol-1.html
If the memory that you are using complies with those specifications and still the PC does not work properly, in that case since you are using a server board with a dual socket configuration, the best thing to do will be to get in contact with the ASUS's server department, so they can provide further technical assistance on this matter:
ASUS's phone number: 1-877-339-2787
ASUS's support site: https://www.asus.com/us/support/ https://www.asus.com/us/support/
Alberto
Hello d.crespo:
I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto
