16758 Discussions
Frequência de memória Xeon
Hodriguez
Olá a todos ! preciso de ajuda, o processador
Xeon® E5-2630 v3 trabalha com o ddr4 e tem frequência 1600/1866mhz, No caso estas frequências e para o padrão DDR 3 ? To meio perdido nisso, ou estas memorias e para as ECC ? me ajudem por favor. brigado!
n_scott_pearson
No, these are indeed DDR4 frequencies. The processor has support for ECC memory built into it, but whether you can actually use memory with ECC support is dependent upon the motherboard that you are using.
Hope this helps,
n_scott_pearson
Hope this helps,
Hodriguez
thanks a lot friend for your help. God bless you. you helped me a lot
