16794 Discusiones
Games Crashing......Please Help...
Empleados
6.448 Vistas
Hi, Recently changed my PSU to a CoolerMaster eXtreme Power Plus 600W. Since then, I have been experiencing problems with my comp whenever I try to play any game.
Whenever I am playing any game, The game is crashing after a little while. This has been happening with every game.
This is the Config of my PC.
Intel Core2Quad Q8200@2.33Ghz
XFX 630i 7100
2GB Kingston DDR2 800Mhz
XFX Geforce 9600GT 512MB GDDR3 650Mhz
Seagate 160GB 7200
Windows 7 32-Bit Ultimate
I am not able to play any games on my PC. Please help.
  Other Information    The temperature of my CPU under 0% load is 49-54C, and under 100% load goes up to 83C. Are these temperatures normal? The GPU remains at 55C under 100% load. The CPU Fan is running at 3300RPM.
Games Tried : Bionic Commando, GTA 4, Gears Of War.
My normal Desktop is working fine. I able to browse the internet without any glitches whatsoever.
Please suggest some solution.
17 Respuestas
Empleados
3.546 Vistas
So this issue never happened before you changed the PSU? if so have you still got the other PSU to be able to test with?
Empleados
3.546 Vistas
I ll try that. but are the temperatures normal ??? One more question comes in my mind that can a PSU(that too from coolermaster) cause such a wierd prob to a PC????
Empleados
3.546 Vistas
I have used the graphic card and the PSU on the other PC, with the same games, and the games worked perfectly fine.
I changed the TIM of the processor and now the temp stays 44C under idle.
I recently also got my hdd replaced.
Now, either the problem is with the processor, or the mobo. PLease somebody help...!!
DSilv11
Colaborador Valioso III
3.546 Vistas
Your low end temps look very normal but 85C is pressing the therimal trip.
Try running your system with the case open and see if CPU is running cooler.
It could be a problem with the fan air directions and the new PS.
Most chassis fans exhust the air out of the system and pull it in through the front.
If your new PS has a larger cooling fan flow it might be creating a condition where the chassis fan can't get enought air accross the CPU.
Other option is the cpu heat sink may not be seated completly. (but that should be unrelated to changing the PS)
DSilv11
3.546 Vistas
Looks like I did not read far enought down the POST.
So you CPU under load is better now also? (< 70)
If temps ae OK now,I would start suspecting memory caused crashes
Try a memory stress test and see if you also have issues.
Empleados
3.546 Vistas
Hi Doc_SilverCreek, thanks a lot for your reply.
I used the the same card and the same PSU with another machine and everything worked like a charm.
Regarding the memory error, usually memory error causes frequent restarts, no display problem, and beep sounds. None has happened till now.
I ran the game without using the graphic card, still the problem prevailed. The amazing part is that, after the game crashes, the computer works very normal.
I doubt the mobo. What say?
DSilv11
3.546 Vistas
So when the game crashes, it reboots the system?, freezes the game? Game exits back to windows ?
Motherboard start up memory test only check a portion of the system memory usually 1 byte out of every 1000, although some boards have the option to enable a full memory test. The reason they don't normally test everything is your POST time would go to about 5 minutes and ~ 95% of all memory errors will be detected doing 1 k tests.
Games tend to be very memory intenstive so that one bad byte of ram can send your program out into the weeds.
Drivers and BIOS issues can cause similar issues so I would make sure you have all the newest drivers and BIOS code loaded. (and this is the easiest fix as it cost nothing)
If your board has a extended memory test, i would give it a try and / or try memtest86 http://memtest86.com/ http://memtest86.com/ which is one of the most robust memory test I have see (especially at the FREE price)
Empleados
3.546 Vistas
Have you checked that the memory and other components are seated properly? i say this just incase you knocked anythign when swapping the PSU around. Between it working and then not working did you change anything else at all on the system?
Empleados
3.546 Vistas
After the game crashes, the computer doesnt reboot. Neither the game freezes. I get a message saying tht the *.exe has stopped working. I will try running the mem test to check the RAM. I also updated to the latest BIOS and all the drivers on my PC are latest.
Regarding the proper seating of all the components, everything is just perfect. I changed nothing in the system except the PSU.
1 Fact that is left to be disclosed.
The PSU (400W) I had earlier got overheated and stopped working. The pungent smell of something burnt was coming out of it. After this incident, I got the new PSU. Is there a chance that the earlier PSU had damaged my mobo or RAM or Processor?
DSilv11
3.546 Vistas
There is a chance low voltage before the PS died may have done damage.
Memory is still most likely
Although HDD being corrupted or damage is a possibility with the supply failing
Does your game play off a CD? Optocal drives can also be sensitive to power damage.
Then I would suspect mother board and last processor. (processors are real tough)
Empleados
3.546 Vistas
My, game is not playing off a CD. HDD is not possible as in the first place, I suspected the HDD itself and sent it for replacement. I will check the memory and let you know very soon. I hope that you are correct. Thanks a lot for your support.
Empleados
3.546 Vistas
Ran the memtest for more than 3 hours. The test went up till 430.8%..!! There were no errors detected.
Now what??? What remains is the mobo and the processor. How do I determine??
DSilv11
3.546 Vistas
MEMTEST86 is a very stressful test.
If the system ran it for 4 hours with out issue, I would suspect the game itself.
What game are you trying to play and have you checked for game patches ?
RGiff
Colaborador Distinguido I
3.546 Vistas
Can you run a test and see how many FPS you are getting out of the 9600GT , Most modern games require 60 FPS or better.
RGiff
3.546 Vistas
I'd Be looking at the graphics more than the RAM or PSU or Mombo?? Most Gammers run crossfire or SLI , in order to get that sweet spot of 60 - 80 frames per second. for Games.
Empleados
3.546 Vistas
hi games crashing, your graphics card is way to hot thats why your game is freezing. try opening the side of your pc and make sure your fans are working. sometimes they get very dusty causing them to stop spinning. if this is the case use your hoover gently suck all the dust and debri out of your tower. its definitley a cooling problem. best of luck.
CMorg1
Principiante
3.546 Vistas
I Have Recently Purchased Football Manager 2014 For My Laptop,
I Have Installed The Game And Also Installed Steam, However, When I Try To Load The Game A Blue Screen Appears Saying I Need To Check BIOS Updates, Memory, Hardware Vendors etc,
I Have Not Been Able To Play The Game Yet,
I Have Contacted Sega And They Have Told Me To Resolve The Issue Via Intel,
I Am Very Unsure Regarding Computers And Need Help,
Craig,
mailto:morg48@hotmail.com morg48@hotmail.com
Responder
