16764 Discussions
[Gaming laptop with i7-7700HQ and nVIDIA GTX-1070 graphics] I get 100 degrees C core temperature when running 3DMark TimeSpy
HSand
[Gaming laptop with i7-7700HQ and nVIDIA GTX-1070 graphics] I get 103 degrees C core temperature when running 3DMark TimeSpy...
It is a Clevo P950HR gaming laptop.
Is this result really ok? Or should I contact the reseller?
See attached HW Monitor
Hello hensan,
Thank you for contacting Intel Support,
I understand that you are having problems with the temperatures of the processor, I apologize for any inconvenience this may have caused.
Now, we do not recommend to run third-party temperature or benchmark tests as they are designed to push the processor to the limit and could somehow affect it. For this, I would like you to download the following software:
https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU-?product=66427
After downloading it I would like you to run a stress test, this way we will make sure if the unit is working properly and the temperatures it handles.
I hope you find this helpful.
David V
Hello hensan,
I am following-up with your case and I see that we have not heard back from you,
Is there anything else I can help you with?
Were you able to solve your issue?
Do not hesitate to reply for further help!
David V
