16785 ディスカッション
Hello i have a question about the high temperature my processor reaches when its under pressure like gaming, i want to know is that normal behaviour or i have some kind of a problem?
MMick3
ビギナー
1,834件の閲覧回数
I have Intel® Core™ i7-7700K CPU @ 4.20GHz, and it reaches about 90-95 °C going up to the red zone on the performance monitor, i want to know do i have some kind of problem with the CPU or the fan because it constantly overheats under pressure or thats just the way the CPU is?
0 件の賞賛
6 返答(返信)
n_scott_pearson
スーパーユーザー
1,706件の閲覧回数
90c is not unreasonable, but 95c is concerning. Do you have any level of control over the configuration of the cooling subsystem (typically in BIOS Setup)?
MMick3
ビギナー
1,706件の閲覧回数
Yes as a matter of fact i do and i tried to push the fan to work at maximum speed at any time and its still overheating.
n_scott_pearson
スーパーユーザー
1,706件の閲覧回数
Have you tried cleaning the blowers and cooling channels using a can of compressed air?
MMick3
ビギナー
1,706件の閲覧回数
I have done that around a month ago it still looks clean, i dont think that's the problem.
n_scott_pearson
スーパーユーザー
1,706件の閲覧回数
Ok, if you have them cleaned out and you've done all you can using the BIOS configuration capabilities, the next step is replacing the TIM on the top of the processor. This is not something you should do if you are still under warranty. If you are under warranty, you should be talking to your laptop vendor regarding this issue.
MMick3
ビギナー
1,706件の閲覧回数
Alright ty very much for the advice, i also thought to check about hidden background processes maybe something the windows defender didnt caught i think that can also be the main source of the problem with the overheating i guess or maybe bad optimization of the game.
返信
