16766 Discussions
Help with Heatsink Installation E97381-001 for the I7-970 (LGA 1366)
I'm installing this Heat-Sink which I purchased when I worked with a national retailer as part of the Intel Edge program. The small manual which claims to be ''installation instructions" provides absolutely no instructions for the heat-sink installation. Although it's somewhat self-explanatory, I'm looking for guidance on which direction the fan on the front (or rear) of the heat-sink is supposed to point when the heat-sink is installed. Does it make a difference?
The miniscule manual refers me to the following address http://www.intel.com/go/integration http://www.intel.com/go/integration which then tells me I have to register as a technology provider which I am no longer. There is no english language guidance in the manual regarding the heat-sink installation, just pictures which do little to point me in a particular direction for the positioning of the fan.
Any help is extremely appreciated.
Adolfo_S_Intel2
The integration manuals that we have are the ones located at:
http://www.intel.com/support/processors/corei7/sb/CS-030866.htm http://www.intel.com/support/processors/corei7/sb/CS-030866.htm
But I believe that is the same one that you have in printed version.
Regarding the fan, it does not matter the side that you install it.
Thanks for your reply Adolfo!!
